Thread: UPS Battery Dead
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Default UPS Battery Dead
    My Apollo 800 VA UPS battery is most likely dead. After electricity goes down, the entire PC turns off instantly. It wouldn't even charge. I'm not surely though whether it's the battery or something else. If it's the battery, it has to be replaced. Is there any place in MDpur where I can buy it?
    Thanks.
    it seems battery gone...
    If so, just pull the battery out from the UPS and go to mdpur market to buy a new one along with the old one.
    You need to match the battery config same as old one. You may found new battery from 700tk ~ 1,200tk.
    it probably has one battery. replace it with a 12V 7/8.5AHr battery. Find out any pc shop near ur place!
  1. Want to Buy UPS Battery
    By Raj_11 in forum Shop - Gadgets
    Last Post: October 9th, 2012, 02:20
  2. Sale (Used) Two 7.5A UPS Battery is up for sale (Sealed Lead Acid Battery)
    By minitt in forum Shop - Gadgets
    Last Post: April 21st, 2012, 23:00
  3. Battery for Ups
    Last Post: January 18th, 2011, 22:50
  4. Using car battery in UPS
    By |-<NOSALIS>-| in forum Hardware Modding
    Last Post: July 26th, 2010, 08:26
  5. Closed Laptop and a dead/half dead nokia n72
    By avas911 in forum Shop - Gadgets
    Last Post: December 4th, 2009, 00:11
Page generated in 0.15581 seconds with 14 queries.
