Results 1 to 16 of 16
Thread: Problem With Hard disk
    • Menace Slinger's Gadgets
      • Gigabyte B75
      • Intel Core i5 3470
      • Twinmos 2 X 4GB 1600 mhz
      • WD 2 X 1 TB + Hitachi 1 TB + Samsung 320 GB
      • Nvidia GeForce GTX 650
      • Samsung LED 18.5 Inch X 2
      • M-Audio Fast track
      • Just Beats ( Beats by Dr. Dre)
      • A4 Tech KD 800L
      • Logitech B100
      • Generic USB Gamepad
      • Thermaltake Litepower 450 WT
      • SAMSUNG
      • Audio technica AT 2020 Microphone
      • Ideal 5308B 800VA 7Ah
      • Windows 7 Ultimate
      • Casing : InWin MANA 136
      • Earth Telecommunication
      • 4 MB
      • 4 MB
    Menace Slinger's Avatar
    Jan 2013
    Angry Problem With Hard disk
    So I have two Hard disks in my PC. They were working well for last 1 month. But for last 1 week, I am facing problem with my 2 nd hard disk. Sometimes when I boot, My both hard disks are found, and sometimes not. I have checked the cables for 3 times and after disconnecting and reconnecting, the 2nd hard disk works. But after 2 or 3 days all of a sudden I will see that hard disk is missing from my computer.
    Today I was watching a movie from that hard disk. Suddenly it stopped. And I went to my computer and the drive was missing !
    My 2nd hard disk in 320 GB and its properly formatted. The whole hard disk is 1 partition. Please help ! I am fed up of opening the casing again and again !
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    Change the cable of the problematic drive. you can also try other sata ports in the mobo.
    I had the problem and the solution was changing the psu as it failed to feed my two hdd you may also have this problem or update the mobo bios and change the sata cables that may help you
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    Quote Originally Posted by Menace Slinger View Post
    Sata cables .. nd psu er jeita thake oita current paitese nah .. psu er onno kono power cable lagia dekhen ..
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    I use Thermaltake 450 W PSU. Do I need to upgrade it ? ( My graphics card is Nvidia GTX 650 and CPU i5 3470). I have changed The cables and used other sata ports for like 5 times. But The problem isnt solving I also plugged in other power cables from my PSU to the faulty HDD
    Quote Originally Posted by genocide_cutter View Post
    SATA Cable o change korsi + PSU power cable o change korsi
    Member Shoaib's Avatar
    Khulna
    Then check S.M.A.R.T status.
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    Test your rig in a friend's house which has higher wattage PSU. Or bring his or her PSU in your home and try again. 450w is too low for your setup.
    My probable next build: Qisan MagicForce 68 (Outemu switch) / Teamwolf Zhuque+ 87 TKL (Outemu) / Monoprice Select series full size (Outemu/Gateron) / Drevo Gramr 84 TKL (Outemu) • Logitech G102 Prodigy • Deepcool Dukase V3 / Thermaltake Versa U21 • Superlux HD 681 • Creative Sound Blaster E1 • LG 22MP68VQ • SteelSeries QcK • Generic executive chair • others TBA
    djrock please don't bother me. You are in my ignore list so I don't have to see literal poop.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    have you checked other sata ports of mobo?
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Quote Originally Posted by Dunia_r_JAURA View Post
    Tahole abar PSu kena lagbe
    Quote Originally Posted by fahimspider View Post
    Yup I have checked and changed them 5 times
    Quote Originally Posted by Shoaib View Post
    SMART status check er jonno ekta software namaisi. But kemne bhujbo why this is faulty ?
    So here is the idea. What if I use another PSU just for my faulty hard drive ? I have one Unused PC in my home. I can salvage the PSU from that one ( chienese PSU ) And connect only the faulty disk to it Will that damage my HDD ?
    Khulna
    Download HDDScan. Also check if temp goes high.
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    did u check for bad sectors?
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Temp is 30 C. Seems cooler than the other one (36 c)
    Checking right now.
    Khulna
    Checking right now.
    good temp but also check SMART status.
      • Gigabyte B75
      • A4 Tech KD 800L
      • Logitech B100
      • SAMSUNG
      • 4 MB
      • 4 MB
    Jan 2013
    Bro what should I look for in SMART status ? I mean how can I know the problem ?
    Apr 2013
    Use HDD tune pro to test..
    Khulna
    HDDScan a tei SMART status dakha jay. And jodi kono harddrive a fault thake ta smart janabe. (like Data read error, spinning error, bad sectors etc)
  1. Hard disk problem
    By Badhon_raj in forum Technical Support
    Last Post: April 21st, 2013, 19:55
  2. Hard Disk Problem - Help Needed
    By schizo55 in forum Others PC Hardware
    Last Post: May 14th, 2012, 22:02
  3. Unknown Hard-disk Problem In Win 7
    By Rorschach in forum Technical Support
    Last Post: February 7th, 2012, 15:39
  4. Disk Manager does not detect Hard Disk
    By Flame in forum Technical Support
    Last Post: March 11th, 2011, 11:31
  5. Hard Disk Problem
    By dying4004 in forum Technical Support
    Last Post: August 12th, 2010, 00:09
Page generated in 0.26493 seconds with 14 queries.
