Thread: PC restarting problem!!
    • QuadStorm's Gadgets
      • Gigabyte H81M-S2PV
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Default PC restarting problem!!
    i am using a ups with my pc...i also have ips working..when the power fails(loadshedding) pc restarts...even when power returns...what problem that can be? i cant find any clue.
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    Quote Originally Posted by QuadStorm View Post
    ups problem....it cant provide the needed energy to the psu within the short time.....
    I also had the same problem, don't use your UPS along with an IPS. If your IPS has a smart/PC mode, then use that to power the PC during power cuts.
    • Gladiator''s Gadgets
      • Asrock z68 extreme4 gen3
      • intel corei5 [email protected] 3.1Ghz with SC
      • PQ 4gb ddr3 with1333Mhz including hs
      • Western digital 500gb blue cavier
      • sapphire hd 7770 1Gb ddr5
      • SAMSUNG
      • onboard Realtek
      • MICROLAB
      • Lexma am 546
      • a4 tech kbs 720
      • xfx 650w
      • Lite on
      • Power tree
      • WINDOWS 7 Ultimate 64bit
      • wired"Techzone" and wireless GP isp
    Gladiator''s Avatar
    Dec 2011
    Psu or ups both can be the reason behind ur described problem or ur system is too power hungry, means ur ups is not been able to provide sufficient power to let the system sustain at its full working state during the power failure. Well let me explain it a bit first. Psu has a specific nature of power holding capability. This means a psu can hold power during power shortage for a very short period of time, lets say its about 15 ms which is of course very negligible to human eye but its long enough for the speed of electricity to fill the circuit. As well as every ups has definite transfer time let’s say its 5 ms, which can be variable in different units.
    So what happens is when u turn of the main power source (like load shedding) the system will not turn off directly. The psu will let it run for 15ms more. Like I said before ur ups has to transfer ample power within that 15ms period. If that happens ur system will not restart. What might be happening in ur system is either ur psu is failing to hold power for sufficient amount of time for the ups to transfer the backup power or ur ups is not capable enough to transfer power that quickly during the holdup time of psu. Anyway this is just a possibility. There could be some other reasons at the back those irritating hiccup.
    "I am not great enough to be humble"
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    sometimes it doesn't happen..and sometimes happen...i have to check removing ups.
    Quote Originally Posted by Gladiator' View Post
    good explanation! But let me shed some more light on it. if the problem is coming from the UPS side then chances are high that either the batteries are worn out or the connectiing terminals are oxidized or crappy Caps or micro fracture of soldering joints on the UPS power switching area. And if it's from PSU side, then chances are high it's coming from the secondary side of the PSU.
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    my ups is 4 months old
    How old is ur psu? Also mention make and model number.
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    5 months...corsair 450 watt.
  1. windows loading forever and restarting!!!!!!!!
    By giant in forum Technical Support
    Last Post: November 24th, 2012, 17:22
  2. Nvidia Driver Problem or Graphics Card Problem ??
  3. Complete files becoming incomplete after restarting PC
    By Rubab in forum Technical Support
    Last Post: August 18th, 2011, 16:23
  4. PC Restarting Problem
    By anik_lc in forum Technical Support
    Last Post: July 10th, 2011, 02:42
  5. help: ipod is auto restarting
    By rafaat in forum Technical Support
    Last Post: May 9th, 2009, 21:49
Page generated in 0.21375 seconds with 14 queries.
