Thread: Monitor Ghosting Problem
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Question Monitor Ghosting Problem
    Recently, I have been seeing this ghosting or blurring effect in my monitor only when I am connected to the VGA port.
    Anything connected to the DVI seems to be Ok. Now, I cannot narrow it down to whether it is a problem with my on-board GFX card or VGA port of my monitor?
    Any suggestion is highly appreciated.
    Apr 2013
    Though I know little, my personal experience is that performance differs from connectors to connectors. The display port is highly powerful in fast and most bandwidth,, then comes the HDMI, then DVI... Worst one is VGA... Try to use the best connection. My experience is from Dell u3011's difference between display port and HDMI.. Display can up to 2560x1600.. But HDMI goes only 1920x1200.. And dvi cannot hold even the latter resolution...
    Quote Originally Posted by йЦммєя³¹ View Post
    on-board gfx card. Connect a discrete gpu and see the difference yourself.
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    Thanks will do that
  1. Want to Buy Anti-ghosting keyboard
    By abir in forum Shop - Gadgets
    Last Post: March 8th, 2013, 03:49
  2. Monitor problem
    By wasi006 in forum Others PC Hardware
    Last Post: April 26th, 2011, 09:23
  3. Monitor Problem
    By zaman_177 in forum Technical Support
    Last Post: February 8th, 2011, 06:55
  4. Monitor Problem
    Last Post: June 11th, 2010, 07:18
  5. Ghosting while scrolling
    By minitt in forum Technical Support
    Last Post: September 29th, 2008, 01:52
Page generated in 0.18246 seconds with 14 queries.
