Results 1 to 1 of 1
Thread: Intermittent connection with my Zoom 5350
    • asif105878's Gadgets
      • Intel X45
      • Intel Core i5-450M Processor 2.40GHz with Turbo Boost Technology up to 2.66 GHz
      • 4GB DDR3 800MHz
      • 500GB 7200rpm, 1+1.5+2 TB external
      • Intel GMA HD
      • ASUS VH238H, 14.0” diagonal High-Definition HP BrightView LED Display (1366 x 768)
      • Altec Lancing, A4Tech Hs-30
      • CM Storm Trigger, Logitech, 101-key compatible with island-style full-size keyboard
      • Logitech M125
      • DualShock 3, XBOX controller, Wii Remote and Nunchuck, Mad Catz X360 CoDBO PrecisionAIM Controller
      • 65W
      • Sony Walkman, Portable HDD, USB flash drive
      • N/A
      • Win7 Home Premium x64
      • 4.5
      • stuck with it atm :(
      • Comocast
      • 3125
      • 1500
      • 50
    asif105878's Avatar
    May 2010
    Somewhere in Michigan
    Default Intermittent connection with my Zoom 5350
    I have been using a Zoom 5350 cable modem/router combo (http://www.zoomtel.com/products/5350.html) with my Charter internet connection for more than a year now. I did not have any issues with it for the first 4-6 months. But after that I keep having connection issues. The unit keeps dropping both wired and wireless connections. Unplugging and plugging in the Ethernet cable resolves the issue for the wired connection. Sometime I need to reset the modem. These problems used to happen every few weeks before but now they happen a few times everyday. These happen mostly when I stream videos from YouTube or Twitch or sometimes when I FTP files to my Xbox. A few times it happened while I was playing DotA 2 when everything else was turned off. Not sure if those could be the reasons.
    I reached Zoom technical support, they could not help much except offer to replace it. Zoom sent me a new unit but I have the same problems with it. A Charter technician checked my line a few days ago and found no problems with it. The signal for my connection has been boosted from Charter a few times already. I used a Charter modem for one week, and during that time this connection issues happened twice. I have seen people having similar issues with gateways in general, some have suggested deactivating IP flood detection but I have disabled it from day one.
    When I drop connection, all the lights in the modem light up correctly. So I think it could be a problem with router side of my unit since the modem part is apparently working. The signal levels of the modem are not the same as what I get using the Charter modem but they are acceptable.
    Below are some screenshots from the modem settings page
    Any ideas as what could be the problem?
    Anime-Planet.com - anime | manga | reviews
  1. Citycell Zoom Ultra
    By abir in forum ISP
    Last Post: May 26th, 2012, 19:11
  2. Need some feedback about Zoom Ultra
    By Camouflage in forum ISP
    Last Post: May 26th, 2012, 17:38
  3. Replies: 19
    Last Post: April 24th, 2012, 16:38
  4. Help about Zoom ultra
    By d3adus3r in forum Internet
    Last Post: November 11th, 2011, 00:11
  5. Need info about Zoom Ultra
    By Rumen in forum Internet
    Last Post: September 19th, 2010, 21:26
Page generated in 0.15482 seconds with 15 queries.
