Results 1 to 20 of 21
Thread: (wireless) Router with Speed Management + PPPoE support!
    Noblesse Oblige
    • CvP's Gadgets
      • ASUS Crosshair HERO VIII
      • AMD Ryzen 3950x
      • GSkill Trident Z Neo 4x16GB DDR4 @3733MHz
      • Lots of SSD
      • EVGA 980Ti 6GB
      • ASUS ROG 4k + 2x 1080p
      • Internal
      • Logitech Z906
      • Razer BlackWidow Ultimate
      • Logitech G903 x2
      • XBOX Gears of War Editions
      • Seasonic X 850W 80Plus Gold
      • Logitech C920; Blue Yeti
      • Emerson 3000KVA Online
      • Link3/Dot
      • 300000+
      • 100000+
    CvP's Avatar
    Arrow (wireless) Router with Speed Management + PPPoE support!
    What I wanna do is to increase my net speed to 256/256, hook it on a router (wireless preferably).
    so that others in my home can login to the net when needed.
    since these connections are general PPPoE (with username/password + mac binding),
    I will require a router that supports all of these (with auto dial PPPoE).
    I also want some form of bandwidth management for the connections from the router.
    and finally, it'll be great to have a wireless router with one ethernet (rj-45) port so that
    i dont need to buy wireless NIC for my own PC.
    I'll be doing some google searching. just wanna know if anyone of you have
    any experience..recommendations..price-idea etc.
    • Mazhar's Gadgets
      • MSI MEG X570 Ace
      • AMD Ryzen 3950X
      • G.Skill TridentZ Neo 4x8GB DDR4 3600
      • WD SN750 2TB
      • AMD 5700XT
      • LG GL850-B
      • SMSL M200/SP200
      • DCA Aeon 2 Closed
      • Corsair K70 Rapidfire
      • G502 SE
      • Xbox One
      • Seasonic Prime Plus Titanium 650W
      • Windows 10 Pro
    Mazhar's Avatar
    Toronto
    Default Re: (wireless) Router with Speed Management + PPPoE support!
    I really dont know about the availability of routers in BD, but for a not too steep price, the good ones available here are belkin, netgear, linksys, buffalo, zyXEL and zoom. speedtouch is also ok, but the others mentioned here are better
    I myself use a belkin router with 4x RJ-45 ports, and use one of them to connect to my computer since it cuts out a bit of latency and of course I do not have to get a wireless NIC card
    Most good wireless routers will ship with one, or a few RJ-45 ports, so you shouldnt have a problem
    If needed I can bring you one from here, let me know if u have any preferences
    edit: I think for BD any basic wireless router should do, like this one
    edit2: ok, sorry for skipping through ur post as i just realised u need some other features too like speed management, ill let u know about the routers
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    One of my friend use a TPlink wireless router ... current price is 3000 tk.
    Its range is upto 54 meter. supports static IP/Dynamic IP/PPPOE with user name/pass. It has many other options like advanced security management. It has one WAN port and 4 LAN port so you wont need to buy adapter for PC (for upto 4 PC). This router is fully manageable that means it has built in options that can be moded via any browser.
    I am using it right now (borrowed). You can take it for me for a test drive if you want. My final opinion is : this thing is enough for home use.
    There is another router available for home users from dlink, price 4500, range 100 meter.
    About bandwidth management: I dont understand what type of speed management you want, if you want to share your net line with others, then a desktop software like ccproxy can provide everything you need. The router above has some built in speed management system, never checked that out.
    Sola Boot Muri™
    • Deep -xCross-'s Gadgets
      • ECS G41T-R3
      • Intel Pentium D E5400 (@2.7Ghz)
      • Transcend 2GB DDR3 (@1066MHz)
      • Western Digital Caviar BLACK 1TB & Seagate GoFlex Desk External 3TB
      • Sapphire ATi Radeon 5550
      • DELL P2211H 21.5" LED LCD (@1080p)
      • Creative Audigy Value 7.1
      • Creative GIGAWORKS T3 / Bose IE2
      • Microsoft Comfort Mouse 6000
      • Thermaltake Lightpower 430W
      • GreenPower 600VA powered by a 85AH IPS Battery which gives me 3.5hours of backup
      • Windows 7 Ultimate 32bit (Pirated)
      • Not so bad for normal usage. I don't have any time to play games right now.
      • Link3 1532kbps Night Doubler
      • 180-360
      • 180*360
    Deep -xCross-'s Avatar
    Gulshan, Dhaka
    ami jodi ei router ta kini tahole ki amar PPPoE connection diye ekshathe 3ta pc use korte parbo??
    seeing is believing..
    Noblesse Oblige
    • CvP's Gadgets
      • AMD Ryzen 3950x
      • Lots of SSD
      • EVGA 980Ti 6GB
      • Internal
      • Logitech Z906
      • Logitech G903 x2
      • Link3/Dot
      • 300000+
      • 100000+
    CvP's Avatar
    Quote Originally Posted by @màréX View Post
    I wouldn't want other people to stop logging into net when my PC is turned off.
    Quote Originally Posted by xCross View Post
    yes.
    • AmareX's Gadgets
      • 1000 GB Samsung
      • A4tech GameMaster
      • XFX XGear
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    If you share your line direct from router (possible with this one) then you wont have to keep your pc running. Speed can be auto negotiated (when a new user connects, speed splits) or you can manage speed manually from router.
    • Mazhar's Gadgets
      • MSI MEG X570 Ace
      • AMD Ryzen 3950X
      • WD SN750 2TB
      • AMD 5700XT
      • LG GL850-B
      • SMSL M200/SP200
      • DCA Aeon 2 Closed
      • G502 SE
      • Xbox One
      • Windows 10 Pro
    Mazhar's Avatar
    Toronto
    Just FYI, most midrange routers from a good company offer hardware bandwidth management to an extent, and if they dont u can always flash to a 3rd party router firmware which does allow bandwidth management
    • SinEater's Gadgets
      • ASUS P5K-VM
      • Pentium E 2200
      • 6 GB DDR2, 800 MHz
      • Samsung 500 GB + 500 GB
      • 450 GTX
      • Samsung 933SN LCD
      • Realtek, integrated
      • T6200 5.1
      • Razer Lycosa, Razer Arctosa
      • Razer Lachesis, Razer Death Adder L/H
      • Microsoft SideWinder
      • Corsair 650 W
      • Asus Combo Drive
      • Qubee 1mbps
      • 20
    SinEater's Avatar
    Mogbazar, Dhaka
    We used to have one in the Enercon office, CvP. I think you remember it. But I am not sure about the PPOE dial-up. But the other features meet your demand. It acts like any normal low-end router.
    Click here to find out how a noob plays the Anti Mage
    Honesty and Modesty were the best policy...they still are.
    A single stupid man can ask more questions than a thousand wise men can answer
    <nfs>.......for life..
    • Walking Death's Gadgets
      • Gaytell Chumma v.1
      • Quad ballz [newly purchased :)]
      • Poshu pakhi pali na[vegeterian]
      • huggies diper storage capacity 1 TB
      • Amar choshmar power 2.00 HD UVray protection
      • Ja dekhi tai[sometimes nightfall]
      • Sound abar kobe card hishebe available moja los naki?
      • Amar kono hearing problem nai anyway Hearing AID 4.1
      • Computer e key use hoy jantam na.
      • My mouse has no balls
      • Ami
      • Biogas
      • fiber optic
      • Gaysaccent 8 shitabyte
      • Bio Gas dual
      • Halay pagol hoise naki? ki koy
      • Comment korlum
      • Paile khun kormu
      • 100 kilo BITE
      • Na kono BITE khay na khali dey
    Walking Death's Avatar
    Enshrouded
    Quote Originally Posted by <nfs>SinEater View Post
    I remember it[ekbar para disilam bhule]
    Like a wolf in sheep's clothing
    I try to hide my deepest sins,
    Of all the things that I've done wrong
    And I know where I belong.
    http://www.last.fm/user/deathwalking
    Sola Boot Muri™
      • ECS G41T-R3
      • Western Digital Caviar BLACK 1TB &amp; Seagate GoFlex Desk External 3TB
      • DELL P2211H 21.5&quot; LED LCD (@1080p)
      • 180-360
      • 180*360
    Gulshan, Dhaka
    okay.. another question..
    if i use that router is it possible to use 2 separate PPPoE connection (e.g: [email protected] and [email protected]) and use together in a single/double pc??
    • acE.Shanny's Gadgets
      • Intel Core 2 Q8400 2.66GHz
      • 2*2GB 800bus DDR2 TRANSEND
      • 1TB+1TB+80GB
      • 17&quot; LCD
      • Realtek built-in
      • Logitech G19
      • SteelSeries Sensei
      • 500W TT TR2
      • 800VA Rahmia Afroz
      • 10/10
      • 64kBps/128kBps
      • Half of Download Speed
    acE.Shanny's Avatar
    Dhaka, Bangladesh,
    CvP don go with Wireless.If u go who wil host 5v5 ???
    Could you refrain from spamming here?:closedeyes:
    • Master Chief's Gadgets
      • Asus Strix Z270H
      • Intel Core i5 7600K @4.7 GHz
      • 16GB DDR4 3200MHz
      • Samsung 960 Evo 256gb m.2 SSD, Samsung 1TB+320GB
      • Nvidia GTX 2x1070 SLI
      • Asus ROG Swift PG348Q+LG2261
      • Logitech G930 + Creative T6060 5.1 Speakers
      • Logitech G602
      • Xbox One Controller
      • Thermaltake Smartpower 830W
      • Asus dvd rom,Samsung dvd writer
      • Powerguard 1200VA
      • Windows 10 Ultimate 64 bit
      • 400
      • 400
    Uttara
    Nop using two connections is not possible.I use a Linksys WRT54G which has acess restrictions tab in which you can block certain programs/website/service for a list of pcs or block those pcs all together but it does not have manual speed setting like limiting a pc to 10kB/s when two pcs are using it router will split the speed automatically.Before buying you should download the router's manual from the internet and there you can see the options and features it has.That way you can choose the correct router for you.
      • Asrock Z370 Extreme4
      • Intel 8700K @5.0ghz w/ Cryorig R1
      • 2x8GB Trident Z 3600Mhz @3200CL14
      • Phillips x2 HR
      • Zowie Celeritas II
      • Razer Viper Ultimate
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    I was about to recommend Master Chief's router. It is probably the most popular router to date and still recieves firmware updates. You can also install DDWRT firmwares in them and get even more functionality out of them. It allows mac address cloning and PPPoE dialer so that you can connect any device and use it. Don't know about speed management, but it's likely to be there.
    I had a WAP54G and it constantly dropped connections, like every 2 hours I'd have to restart the modem. DDWRT firmware improved it a LOT!. I think even Linksys also recommends these firmwares.
    @xCross: There are devices which let you connect two connections and double your bandwidth. But the last I checked up on them was on 2006, so I completely forgot the details. Maybe this'll help. http://forums.whirlpool.net.au/forum...s.cfm?t=190355
    Its different and needs you to use 'load balancing'.
      • Asus Strix Z270H
      • 16GB DDR4 3200MHz
      • Logitech G602
      • Powerguard 1200VA
      • 400
      • 400
    Uttara
    It depends on your type of connection but i highly doubt this guy from the whirlpool forum had pppoe connection so he did not need to dial to get connected.
    Specialized routers can do it but they are expensive and don't think they are available in BD.
    http://www.peplink.com/solutions/int...oad-balancing/
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://www.speedtest.net/result/7506335550.png)
      • 25m+100m
      • 25m+100m
    coldfire7's Avatar
    Get a Linksys WRT54G (Open Source) router then mod it with DD-WRT..
    • Arman.Zmn's Gadgets
      • Alienware M17xR3
      • Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz
      • 16gb(4+4+4+4)
      • Samsung SSD 840 EVO 240GB + Samsung 1 TB + Samsung 1 TB
      • AMD Radeon HD 6970M (Dell)
      • Samsung P2350 23'' full HD 1920x1080 + Laptop 17.3&quot; LCD
      • onboard
      • Klipsch Audio
      • Corsair M90 Gaming Mouse
      • XBox 360
      • ASUS DVD RW
      • 3x1TB Transcend StoreJet
      • APC Smart UPS 1500VA
      • windows 7 x64
      • i'm lovin it
      • 3 Mbps
      • 1.5 Mbps
    after googleing for about 1.5 hours found this old thread.....
    i am going to get btcl 1mbps connection next month,, i want to share it to my sister and dad,
    i have the tp-link tl-wr340gd, does any one have done this? and how to do this?
    • abir's Gadgets
      • DELL Inspiron 18.5&quot; LCD |14.1&quot; TFT LCD
      • Realtek Builtin Audio
      • Creative Inspire 2.1
      • A4tech 7K Office (USB)| HP
      • Deluxe DLP 388A 450W
      • ASUS 16X DVD Drive &amp; Liteon DVDW| Asus DVD RAMRW LightScribe
      • 4GB Apacer Pendrive
      • OVO 650VA
      • Windows 7 x64 | Windows XP SP2 &amp; Ubuntu 9.04
      • Smile Internet (Bronze)
    abir's Avatar
    Azimpur
    Quote Originally Posted by Arman.Zmn View Post
    yes I've done it in the lab. not much complicated process.
    u have to configure the router.
    read the router manual, there is detailed procedure.
    u can set up, dhcp, ppoe any type of connection
    I bleed red, Man Utd 4ever..
    Noblesse Oblige
    • CvP's Gadgets
      • AMD Ryzen 3950x
      • Lots of SSD
      • EVGA 980Ti 6GB
      • Internal
      • Logitech Z906
      • Logitech G903 x2
      • Link3/Dot
      • 300000+
      • 100000+
    CvP's Avatar
    at the top right, there's a search field. you can use that
    if you have wireless/more-than-one-port router, after standard router setup (ask EMEM to do it for you; you are paying them after all),
    you just connect other PCs and it just works.
    • Nafis Iqbal's Gadgets
      • Gigabyte GA-H81M-S2PV
      • Intel 4th Gen Core i5 4570
      • Twinmos 8GB DDR3 1600mhz
      • Samsung F3 500GB Sata
      • SAPPHIRE DUAL-X R9 270 2GB GDDR5
      • Samsuing T200 20inch widescreen
      • Creative Sound Blaster Audigy Value 7.1
      • Altec Lansing VS4121 2.1
      • A4tech
      • A4tech 2x click
      • Thermaltake TR2 500W
      • Asus DVD-RW
      • Micro 500VA
      • Windows 7 Ultimate 64-bit
      • 7.7 in Windows 7 Ultimate
      • Link3 Technologies LTD.
      • 1mbps
      • 1mbps
    Nafis Iqbal's Avatar
    Uttara, Dhaka
    nice thread this is! i was also looking for some info about router setup. btw, i want to get a router(the regular ones) to connect a pc(with a cable ) and 3 other wireless devices..so is it possible to share the speed without any problem? i will be using my pc mostly, and connect the laptops some time. and, can someone please tell me what this >PPPoE does? i have no idea
  1. Closed [SOLD OUT] Wireless headphone 5 in 1 on sale
    By DEVIL DESTROYER in forum Shop - Gadgets
    Last Post: January 12th, 2009, 02:18
  2. Replies: 6
    Last Post: August 13th, 2008, 18:02
  3. [SOLD OUT] Selling Xbox360 wireless controller.
    By xK::CREATOR in forum Shop - Gadgets
    Last Post: August 1st, 2008, 21:24
  4. [SOLD OUT] selling Xbox360 Wireless Controller.
    Last Post: May 9th, 2008, 14:58
  5. FIFA 08 The club u support
    By areek in forum Older FIFA Games
    Last Post: March 23rd, 2008, 17:10
Page generated in 0.35265 seconds with 14 queries.
