Thread: PSU Problem
    • saadbillah's Gadgets
      • Intel D945GCNL | Intel GL40
      • Core 2 Duo E6300 1.86 GHz | Pentium Dual Core T4200 2.0 GHz
      • 2 GB | 2 GB
      • 120 GB | 320 GB
      • ASUS EN8600GT 512MB Silent Edition | Intel GMA4500
      • F&D F3000U 5:1
      • Generic Crap
      • Windows XP | Windows 7
      • 64
      • 18
    saadbillah's Avatar
    Default PSU Problem
    aj k theke amr psu theke ajob metalic sound ber hochhe, onek ta freeze e kacher jinish thakle j rokom vibration er awaj hoy se rokom. Casing e 4 ta screw thake PSU hold korar jonno, se gular dui ekta ke ektu loose korar por ekhon sound astese r jasse. but 4 ta screw tight kore dile sound ta continuously hochche.
    ki koronio???
    Vous n'avez pas vraiment connaître quelqu'un qu'en le combattant.
    Default Re: PSU Problem
    PSU পাল্টাও। ভিতরে কোন পার্টস আলগা হয়ে গেসে। এমনো হতে পারে কিছু একটা খুলে গেসে। but still PSU suppying electricity. better u change it...
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    Most probably PSU er internal Fan kono kisur sathe collision kortese... You need to open that PSU and check that out.
      • Samsung 970 EVO 1TB+ 830 (128GB)+2TB mech HDD
      • Evga 1080 TI Sc 11GB
      • TELUS optical
      • 75Mbps
      • 30mbps
    get a blower if possible to clean it up....nd yes check the fan/'s.
    if u have a buzzing sound den its most likely ur secondary filtering caps are about to go
    sky high.... u can repair it by urself if its a expensive psu (though i guess its not)
    Get a simple generic psu which should suffice for ur setup.
  1. Got Problem
    By s.a_rocky in forum Older NFS Games
    Last Post: January 29th, 2009, 11:20
  2. Is There Any Problem in PS3
    By Enamul007 in forum PlayStation
    Last Post: December 30th, 2008, 16:25
  3. GAY Problem
    By SenSeiFAR in forum Technical Support
    Last Post: October 9th, 2008, 11:17
  4. dl problem in RS
  5. problem - cd-key, Plz Help
    By saadbillah in forum CS 1.6
    Last Post: July 24th, 2008, 17:37
Page generated in 0.16646 seconds with 14 queries.
