I dont know if it will work (forgive me if it doesn't
).....googled it and found the following solution:
steps to overclocking:
1. Turn off all the powersaving features off. (Check your board manuals for specific names, but they should be something like EIST..SPEEDSTEP..etc)
2. Make sure to run RAM at the right ratio and also the right voltage.
3. Have adequate cooling on CPU, and for high FSB, adequate cooling on Northbridge.
4. Start upping the FSB, check stability in windows with Prime95.
5. If unstable, up the Vcore, keep close eye on your temp with CoreTemp.
6. Around 400fsb..you need to start upping the NorthBridge voltage.
See how it goes..
