Thread: need help for installing android games
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    Default need help for installing android games
    today I installed modern combat 2.and cracked it.pasted the files in sd/gameloft/......but still it wants to dl the files over wifi.what do I need to do?same thing happened while installing mc3.pasted required files in Sd/android/........same thing happened again.need solution
    • Arka karlos's Gadgets
      • gigabyte b75m hd3
      • intel core i3 3220
      • twinmos 4gb piano black
      • western digital blue 1tb
      • sapphire 7870 dual x oc
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • corsair vs450 cp-9020096-uk
      • samsung s222
      • Ideal 800va
      • windows 7 ultimate 64bit
      • teletalk 3g
      • 100KBps
    Arka karlos's Avatar
    As app told you to dl files, that means it didnt find the files in exact location where it need to be. If you have a folder like com.gameloft.android. . . . . than place that folder in sd/android/obb/_ and see if that works.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Quote Originally Posted by Arka karlos View Post
    but readme says they're needed to be pasted in android/data folder.so do i need to put the files in both folders?
    It didn't worked!they still wanna dl via wifi
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    sorry for late reply. No you dont need to put files in both folder. What is the folder name which contains data file? . Maybe there is a conflict between data and apk like different version. Same situation occured to me when installing talking tom. My advise is dl games from renowed site and most importent think read comment that those game did work or not for your model. Btw what is your model?
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    i got them from some dvd.from lycandroid bla bla.and it's just a non-branded tab.with whvga res,1ghz cpu,512mb ram,mali 400 gpu.it's running on ics
    Oh!some contains lots of files.they r to be pasted in data folder.some contains .obb file and r to be put in obb folder.
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Happy with it!
    Can u give me link of any renowned site @Arka karlos
      • gigabyte b75m hd3
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • samsung s222
      • Ideal 800va
      • teletalk 3g
      • 100KBps
    lycandroid was good earlyer but now it is full of rabbish. But assassins creed,gangstar, asphalt 5,bother in arms from lycandroid worked for me. You can try apkmania . Its a good site. Dont think that all high end game will work on that tab because some high end games have varients for scorpian, tegra pro. What is brand and model of your tab?
    And wait for others help.
  1. Replies: 20
    Last Post: August 31st, 2013, 18:45
  2. Best site to download android games.
    By Robin Rayhan in forum Mobile Gaming
    Last Post: August 7th, 2013, 22:13
  3. help me on how to install games on android
    By abruzzi in forum Miscellaneous Topics
    Last Post: April 2nd, 2013, 02:14
  4. Anyone wants to exchange Android Games?
    By xtron in forum Mobile Gaming
    Last Post: November 18th, 2012, 23:52
  5. prob installing games
    By shuvin in forum Technical Support
    Last Post: February 20th, 2011, 11:00
Page generated in 0.19387 seconds with 14 queries.
