Results 1 to 8 of 8
Thread: Which is better for PS3? A monitor or a TV?? plz help!!
    • solidfoxhound's Gadgets
      • Gigabyte H81M
      • Intel PDC G3220
      • Samsung 4GB DDR3
      • WD BLACK 1TB HDD 7200RPM
      • Dell 18.5 inch
      • cosonic CD-750
      • A4 tech normal
      • A4 tech 2X
      • Corsair CX600 PSU
      • Sony DVD+-RW
      • Win 8.1
      • 512Kbps
    solidfoxhound's Avatar
    Sep 2011
    Dhanmondi,Dhaka
    Unhappy Which is better for PS3? A monitor or a TV?? plz help!!
    Should i consider a monitor or a TV for a PS3?? Im LOST...help would be appreciated.
    • waliDJ's Gadgets
      • Gigabyte GA-B75M D3H v1.0
      • Intel Core i5 3450 3.1 GHz
      • Twinmos 4GB 1600 MHz Piano Black
      • WD 200GB
      • Sapphire HD 7950 Dual-X
      • Samsung SyncMaster 933
      • Built in Realtek HD audio
      • Generic Lexma
      • Razer Deathadder, Logitech B100
      • Cooler Master GX550W
      • Samsung 160GB PATA HDD converted to usb
      • Windows 7 ultimate 64 bit
      • Not another family pc, this one is completely mine :D
    waliDJ's Avatar
    TV no doubt
    Nov 2012
    TV. Why would you get a monitor for a PS3? Max resolution is 1280 anyway, so just get an HDTV if you don't have one.
    • Hellblazer1971's Gadgets
      • Intel DG31PR
      • Intel Core 2 duo 2.66 Ghz
      • 3 GB DDR2
      • 2 TB
      • Nvidia GT240 512MB DDR5
      • Samsung 17inch LCD and Bravia Kdl-32v5500
      • Realtek
      • Creative Inspire 4:1
      • XBOX 360 Controller
      • ASUS 24B1ST DVD RW
      • Windows 8
      • It's getting old...
      • LINK3
      • 1 mbps
      • 1 mbps
    Hellblazer1971's Avatar
    May 2010
    if u wanna buy tv go for 40/42+ inch.....most of the console games e jaggy edges thake, big screen kinle ,couch theke boshe khela jabe and the jaggies will be less noticable...as u r sitting far away.
    ps3 er jonne tv kenai valo as it has blu-ray ... u can also experience the glory of blu-ray movie.
    ..hope it helps...
      • Gigabyte H81M
      • Intel PDC G3220
      • Samsung 4GB DDR3
      • Dell 18.5 inch
      • cosonic CD-750
      • A4 tech normal
      • A4 tech 2X
      • Corsair CX600 PSU
      • Sony DVD+-RW
      • Win 8.1
      • 512Kbps
    Sep 2011
    Dhanmondi,Dhaka
    Quote Originally Posted by Hellblazer1971 View Post
    ..hope it helps...
    But...i don't have that much budget right now...can u recommend me some gud 22~24 inch range TVs found in bd markets??
    Member Shoaib's Avatar
    Khulna
    Go for at least 32".
      • Gigabyte H81M
      • Intel PDC G3220
      • Samsung 4GB DDR3
      • Dell 18.5 inch
      • cosonic CD-750
      • A4 tech normal
      • A4 tech 2X
      • Corsair CX600 PSU
      • Sony DVD+-RW
      • Win 8.1
      • 512Kbps
    Sep 2011
    Dhanmondi,Dhaka
    Quote Originally Posted by Shoaib View Post
    why so?? lesser inched tvs does have any disadvantage?
    • saurav's Gadgets
      • intel h77 kc
      • intel core i5 3470
      • 8gb corsair vengence 1600 bus
      • western digital cavier blue 1tb
      • msi n660 2gb/oc
      • 17" samsung lcd
      • thermaltek tough power xt675
      • samsung 22x
      • using INWIN DRAGON RIDER CASING
    well there is not much difference in price between 32" and a 24"....u will win if u buy a 32" trust me
  1. 21.5 in monitor
    By optimus prime in forum Help - PC Buying
    Last Post: August 7th, 2012, 17:29
  2. HD monitor within 16-17k
    By Source code in forum Miscellaneous Topics
    Last Post: December 23rd, 2011, 15:54
  3. monitor tax
    By dsw1995 in forum Others PC Hardware
    Last Post: July 16th, 2011, 12:39
  4. Want to Buy lcd monitor
    Last Post: December 6th, 2009, 13:56
  5. Need a monitor
    By Coming back to life in forum Miscellaneous Topics
    Last Post: October 13th, 2009, 12:59
Page generated in 0.18877 seconds with 14 queries.
