Thread: Headphone help
    Default Headphone help
    Uhh....Hey guys. I was actually looking for headphones. Preferably full sized ones. I intend to get something better when I have money at the end of the year but for now...What can i get for 1500ish?... Intend to use it pretty much exclusively on my pc. I don't know how picky I can get with such a small budget but anything with crisp sound and balanced bass and treble is gold. Mostly intended for music (I really don't care how good my pistol sounds while playing Farcry >_> ). Genres I listen to are pretty much Alternative, Indie, Folk, Punk Rock, Hardcore and Death metal. Thanks in advance ;-;
    Member Shoaib's Avatar
    Khulna
    Quote Originally Posted by Waffles View Post
    For full size headphone -
    if you can bring one from abroad then, Monoprice 8323.
    If you can increase your budget then Panasonic RP-HTF600-S
    There are no good full size headphone available in here in BD AFAIK.
    for IEM-
    Consider them if you can bring one from abroad - Philips SHE3590 or Monoprice 8320, Brainwavz Beta,JVC HA-FX40,Meelectronics M6.
    If you want to buy from BD then Logitech UE200, 2 years warranty, great choice for your taste. Detailed sound, Sparky highs, balanced bass, awesome mids.
    Thanks for the through reply man. How exactly could I get things from abroad? I know one shop that can get stuff off Amazon/Ebay for you. But it seemed like somewhat of a ripoff as he takes like 110 Tk per dollar. Is this my only option? Don't really have relatives/friends abroad to get it for me. Oh and, I would prefer over the head ones as I really do not need portability at all and Iems generally break a lot faster.
    Quote Originally Posted by Shoaib View Post
    Did you mean it the other way around? The HTF seems to be cheaper than the Monoprice on Amazon.
    Bumping....Someone please answer ;-;
    • Ic3_STrik3R's Gadgets
      • Gigabyte B8-Gaming
      • Intel Core i5 6400 3.3Ghz 6MB L3
      • G.Skill Trident Z RGB 8GB 2400Bus
      • Intel 530 180GB SSD, 500GB WD Blue
      • Gigabyte GTX 750Ti 4GB Windforce edition
      • Toshiba PB20E 32" HD Ready TV
      • Realtek 32bit Audio
      • SONY MHC-v818 Hi-Fi/Gigaworks T20/Genius HF1800A/Genius HF-1250/Genius SP-960BT/TT Isurus Pro
      • Chinese OEM RGB Mechanical KB
      • GX-Gila / DX-ECO Wireless Rechargeable
      • XboX One Controller x4
      • Thermaltek LightPower 450W
      • Samsung Ext DVD RW
      • Transcend 16GB USB3 PD, Genius NB1020 Webcam
      • Digital X 800VA
      • Not Checked
      • Just building it for work
      • 16 MBPS
      • 15 MBPS
    Ic3_STrik3R's Avatar
    • ramiz's Gadgets
      • MSI 880GMS - E35
      • AMD Phenom II X4
      • 2 + 4GB Transcend DDR3 1333MHZ
      • Samsung 500GB
      • Gigabyte Radeon 6770
      • Benq GL930
      • Built In Realtek
      • Panasonic RP HTF600
      • 2 Genuine Xbox360 wireless controllers
      • Thermaltake lite power 430W
      • Sony DVD RW
      • Xbox 360 wireless receiver for windows
      • Windows 7 64 Bit Ultimate
    ramiz's Avatar
    Oblivion
    Phillips SHE3580 white.............By far the best sound you can get within your budget....will cost 1200tk........AFAIK full sized headphones will cost upwards of 3K. If you increase your budget then buy HTF600S..awesome headphone..will cost 4.5-5.1K.
    Member ian25's Avatar
    Oct 2012
    philips SHE3580/ original to ki multiplan e pawa jabe? sathe ki kno warrenty ase? tnx @ramiz
  1. help me buy a 5.1 headphone
    By abruzzi in forum Help - General Shopping
    Last Post: October 30th, 2012, 14:10
  2. Headphone around $35
    By vergil007 in forum Help - General Shopping
    Last Post: May 24th, 2012, 18:43
  3. Headphone at $60
    By Zimmer™ in forum Help - General Shopping
    Last Post: May 10th, 2012, 21:40
  4. need to buy a headphone
    By mr_08 in forum Others PC Hardware
    Last Post: March 7th, 2012, 23:45
  5. where to buy a dj headphone ??
    By superhuman in forum Help - General Shopping
    Last Post: February 2nd, 2012, 22:11
Page generated in 0.18674 seconds with 14 queries.
