Thread: Tv Card problem
    Default Tv Card problem
    I have a Mercury Tv card.It used to work properly on my old pc with the setting shown on the picture.On my old pc I got sound on the Tv Card and on the pc at the same time.Now after upgrading the pc the Tv Card is running but I am not getting it's sound with the old setting.I have tried different setting of the cables.I have seen that when I connect the Tv Card's cable directly to the woofer only then the sound comes but I can't lower it.Even if I put the volume bar to mute the sound keeps coming very loudly.I want to have Tv Card's sound and pc's sound at the same time,just like before.I have shown the color of the ports in the picture according to the motherboard and Tv Card.I need a solution for this problem.
    Old pc specs:
    Processor:Intel Pentium 4 1.8Ghz
    Motherboard:Intel D845PESV
    Ram:384MB DDR
    Graphics card:Nvidia Geforce 2 MX/MX 400 64Mb
    Power supply unit:Maxin 350 watt
    Upgraded pc specs:
    Processor:Intel Pentium Dual-Core E5200 2.5Ghz
    Motherboard:Gigabyte G31M-Es2C
    Ram:Twinmose 2Gb DDR2
    Graphics card:XFX Geforce 9800GT 1Gb
    Power supply unit:Thermaltake 500 watt
    Default Re: Tv Card problem
    what is your sound card and which driver are you using? you plugged in the sound jack to a line in port of your sound card right? adjust settings for that particular port in sound card configuration software (if it is muted, un-mute it etc.)
    • AmareX's Gadgets
      • 1000 GB Samsung
      • Realtec 8 channel digital
      • A4tech GameMaster
      • XFX XGear
      • Transcend 4 GB Pendrive
      • Sendon Extreme 1000 VA
      • Windows 7 Ultimate x64
      • I am satisfied :)
      • GP
      • 30
      • 30
    AmareX's Avatar
    Between α and Ω.
    I had the same problem with my pinnacle. I solved it by using a 4 pin internal audio connector from my tv card to my soundcards (if you use built in than motherboard) AUX port and selecting AUX as sound source from tv cards sound option. You can try same.
  1. Want to Buy Need graphics card and psu
    By Shade101 in forum Shop - Gadgets
    Last Post: April 16th, 2009, 22:43
  2. Your GFX card(s) History
    By abir in forum GPU
    Last Post: January 21st, 2009, 04:44
  3. want to buy a pci usb card
    By saadbillah in forum Shop - Gadgets
    Last Post: November 21st, 2008, 19:27
  4. Want To Buy AGP Card......
    By [email protected] in forum Shop - Gadgets
    Last Post: November 9th, 2008, 13:25
  5. HD 4830 is out..........What a card
    By Uchiha Obito in forum GPU
    Last Post: November 1st, 2008, 09:01
Page generated in 0.11402 seconds with 14 queries.
