Thread: Need quick help about buying a controller
    Default Need quick help about buying a controller
    I want to buy a controller for my pc.But I can't decide which one to buy.I had my eye on Xbox 360 wireless and Wii Remote and Nunchuck.The Wii Remote and Nunchuck are the controllers for Wii console but they can be used on pc games through a software name GlovePie.But I want my controller to be future proof.On this case I think the Wii Remote and Nunchuck will be best because they work through a compatible bluetooth adapter on pc games.At present there is a list of compatible bluetooth adapters for them.I think even after 5 or 6 years they will work if I just change the bluetooth adapter and get a compatible one for them.The Wii remote and Nunchuck gives a very very realistic gameplay as they are motion controllers.What do you think?
    Default Re: Need quick help about buying a controller
    which game would you play with a gamepad?
      • Asrock Z370 Extreme4
      • Intel 8700K @5.0ghz w/ Cryorig R1
      • 2x8GB Trident Z 3600Mhz @3200CL14
      • Phillips x2 HR
      • Zowie Celeritas II
      • Razer Viper Ultimate
      • Xbox One
      • Corsair AX860
      • Windows 10 1909
      • AalokIT
    I say go for the 360 controller. You won't enjoy a lot of games fully like Fifa, NFS etc with the Wiimote.
  1. Upgrading.Need quick help!
    By outragedhuman in forum CPU
    Last Post: July 3rd, 2009, 16:40
  2. FIFA 09 Best Controller for Fifa 09 ? (PC)
    By darkcrunk in forum Older FIFA Games
    Last Post: February 6th, 2009, 00:31
  3. Quick Review --WesternDigital 500GB Vs Samsung 250GB F1
    By Muradd9 in forum Others PC Hardware
    Last Post: February 3rd, 2009, 03:44
  4. CPU FAN Speed Controller!!!
    By minitt in forum CPU
    Last Post: January 24th, 2009, 01:12
  5. 'Quick Reply' disabled?
    By DevilJIN in forum Feedback
    Last Post: July 2nd, 2008, 01:02
Page generated in 0.12506 seconds with 14 queries.
