Cooler Master MB520 Gaming Case without RGB fans
IMPORTANT!!! PLEASE READ THIS AD CAREFULLY!!!
Cooler Master MB520 Gaming Chassis is for sale
NO RGB FAN OR CONTROLLER WILL BE GIVEN
1 Cooler Master Non-RGB 120mm fan will be given
4 AIGO LED Ring 120mm fan will be given (2 Blue, 2 Red) (optional but preferred)
The Case is in full fresh condition, only 6 months used, working flawlessly
The case is used only for 6 months
IMPORTANT FEATURES:
- Upto 360mm AIO radiator support in the front, supports push-pull fan configuration
- FAN support - 3x120mm or 2x140mm in the front, 2x120mm or 2x140mm in the top, 120mm in rear
- Great performance airflow design with front dust filter, magnetic dust filter on the top
- 2xHDD, 4xSSD support, Tool free SSD mount support
- Excellent DarkMirror Front Panel Design
- Full-Length PSU Shroud
- Graphics Card Support Up to 410mm
- Edge-To-Edge Tempered Glass Side Panel
REASON FOR SALE:
Bought a new case to mount 360mm radiator on the top which can't be done with MB520
PRICE:
4000tk (with 4 AIGO LED fans + 1 Cooler Master Non-RGB 120mm fan)
3200tk (without AIGO LED fans, with 1 Cooler Master Non-RGB 120mm fan)
Price is already low and almost FIXED.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Rule Book
Page generated in 0.15822 seconds with 14 queries.
