Results 1 to 6 of 6
Thread: CPU Fan (Problem)
    • Ghz's Gadgets
      • MSI Z77A-G41 (Cooler Master Storm Enforcer)
      • Intel Core i5 2400 @ 3.10Ghz (Stock)
      • Corsair Vengeance 8GB (2x4GB) DDR3 - 1600
      • Samsung F3 1TB | WD 500GB USB 3.0
      • Asus GTX 660 2GB GDDR5
      • DELL LED E1912H (Dual Monitor Setup)
      • Creative Sound Blaster Audigy 7.1
      • Creative SBS A520 5.1 | a4tech HS100
      • Logitech (Call of Duty) - MW3 Edition
      • Razer DeathAdder Wired Optical With SteelSeries QCK Mass
      • Logic Gamepad
      • Corsair 750w
      • Asus DVD-RW | Sony Combo
      • 500GB WD USB 3.0 | 8GB Transcend
      • Powerpac (1200VA)
      • Windows 8 x64 & Windows 7 x64 (Dual Boot)
      • My World ! My Life (-_-)
    Mar 2013
    Default CPU Fan (Problem)
    ohk, so recently um having some problem with my CPU fan... after attaching my GTX660 cpu er fan er sound ektu beshi e bere geche, its i5 2400.. temp age 32-35 thakto but ekhon stand-by a 50-52 thake r power on korar 2-3min porr fan er sound off hoye jai... but start a onek owaj kore
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    @Ghz Reset your cooler with new thermal paste. Probably its loose.
    • Muhammad Zunaid's Gadgets
      • ASRock H55M-LE
      • G Skill Ripjaws [4GBx2]=8GB
      • Samsung SyncMaster T220
      • Inbuilt Realtek Codec
      • Altec Lansing VS4121
      • Tt esports KNUCKER
      • Genius standard mouse
      • Canon Lide110 Scanner
      • RA 1000VA + Powertree 650VA
      • want to upgrade soon!
      • LINK3
    Muhammad Zunaid's Avatar
    check ur fan rmp using software like speedfan or hwmonitor. check if the cpu cooler and fan is loose or not? inserting ur gpu to ur pcie slot shouldnt have any effect on cpu temps unless u displaced cpu-cooler seating somehow.. finally, if all else fails, go with above post ^^
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    @fahimspider @zunaid
    shob e thik aache, PC on korle awaj hoi thn 3-4min porr thik hoye jai...
    pc on korle gher gher sound hobe & rpm check korle dekha jachhe rpm kom ei problem? eta notun kisu na
    moylar jonno hote pare...
    or majhe mjahe emni e hote dekhsi
    fan er upor alto toka(fan means not the blades aarki) dile theme jawar kotha
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Do as he said.^^ Clean the cooler.
    Is temp ok?
    Run Intel Burn test and post your idle and highest temp.
  1. ups problem ???
    By Bijoy Faith in forum Others PC Hardware
    Last Post: April 24th, 2012, 00:47
  2. Nvidia Driver Problem or Graphics Card Problem ??
  3. Having Problem
    By all_izz_well in forum BTCL
    Last Post: March 24th, 2011, 03:36
  4. is anyone having this problem?
    By Speed in forum ISPros
    Last Post: March 4th, 2011, 17:44
  5. problem!!!!
    By Walking Death in forum Software
    Last Post: May 2nd, 2009, 11:22
Page generated in 0.18579 seconds with 14 queries.
