Results 1 to 19 of 19
Thread: Display Problem
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    Exclamation Display Problem
    Toady i am getting a weird problem. After turning cpu on everything goes normal, then suddenly my monitor cannot detect display and goes to sleep. then I pressed restart button and everything back to normal. i even played bioshock at ultimate settings for 1 hour. Everything ok. All of a sudden it happened again. Can someone tell me how to sort out the problem?
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    have u tried re-attaching your gpu???
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Quote Originally Posted by maheer.dhruba View Post
    I have reattached my gpu, ram and every power cable in the cpu and with the monitor. By the way i installed raindrop this morning and some other themes. can they cause problem? It happens after windows boot.
    • Ghz's Gadgets
      • MSI Z77A-G41 (Cooler Master Storm Enforcer)
      • Intel Core i5 2400 @ 3.10Ghz (Stock)
      • Corsair Vengeance 8GB (2x4GB) DDR3 - 1600
      • Samsung F3 1TB | WD 500GB USB 3.0
      • Asus GTX 660 2GB GDDR5
      • DELL LED E1912H (Dual Monitor Setup)
      • Creative Sound Blaster Audigy 7.1
      • Creative SBS A520 5.1 | a4tech HS100
      • Logitech (Call of Duty) - MW3 Edition
      • Razer DeathAdder Wired Optical With SteelSeries QCK Mass
      • Logic Gamepad
      • Corsair 750w
      • Asus DVD-RW | Sony Combo
      • 500GB WD USB 3.0 | 8GB Transcend
      • Powerpac (1200VA)
      • Windows 8 x64 & Windows 7 x64 (Dual Boot)
      • My World ! My Life (-_-)
    Mar 2013
    Well, skin theme etc ei guli use kora uchit nah..they change & disable some registry edits - to uninstall them or setup new windows
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Did you by any chance have low (up/down) voltage in your area ? Does this problem occur randomly or does it only occur when there is load in your PC ?
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Quote Originally Posted by Ghz View Post
    I had already uninstalled the skin and themes before the problem started. my concern is my GPU. can it cause this problem? I have run unigine valley in extreme HD settings. Everything seems to be OK. By the way i am using a aftermarket DVI to DVI cable for last two years.
    No. I am using apollo 1200 va UPS. Problem occurs few second after or during windows boot, but not every time. It happened three times today.
    • Reznov's Gadgets
      • Gigabyte G31M-ES2C
      • Intel Core 2 Duo E8400
      • 3GB DDR2 800mhz (2GB+1GB)
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Adata UV150 (16 GB USB3)
      • windows 7 Ultimate 64bit
      • Mobile ISP
      • Vashae Prokasher Ojoggo
    Reznov's Avatar
    Dinajpur
    Quote Originally Posted by fahimspider View Post
    whats your gpU? ATI RADEON?
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    themes don't usually cause this kinda probs...
    if im not wrong..another member of BG had a similar kind of problem with his gpu(msi 7850)...in his case re-attaching his gpu and driver update solved his problem...
    to be sure its a problem of ur gpu or not..u can run ur pc with the integrated gpu i.e. removing ur gpu...
    Quote Originally Posted by Reznov View Post
    yup his gpu is Sapphire 7950 dual X.
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    পাকি হামেদের স্কিন প্যাক রাইট ? ইফ ইয়েস দেন তুমি ডুমড । উইণ্ডোজকে কোন রিসেন্ট রিস্টোর পয়েন্ট থেকে রিস্টোর কর । আমার মাউন্টেন লায়ন স্কিন প্যাক ফর উইণ্ডোজে প্রায় কাছাকাছি প্রবলেম হয়েছিল ।
    My probable next build: Qisan MagicForce 68 (Outemu switch) / Teamwolf Zhuque+ 87 TKL (Outemu) / Monoprice Select series full size (Outemu/Gateron) / Drevo Gramr 84 TKL (Outemu) • Logitech G102 Prodigy • Deepcool Dukase V3 / Thermaltake Versa U21 • Superlux HD 681 • Creative Sound Blaster E1 • LG 22MP68VQ • SteelSeries QcK • Generic executive chair • others TBA
    djrock please don't bother me. You are in my ignore list so I don't have to see literal poop.
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Reinstall fresh windows without these theme rubbish.
    Prefarably win7 x64 sp1. With 13.2 catalyst beta6.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    ATI HD 7950 Dual X
    I dont have any built in vga support with this motherboard. My drivers are up to date. But to be sure i will try a clean reinstall.
    Quote Originally Posted by Dunia_r_JAURA View Post
    If its PAKI HAMID or not I dont know. I tried raindrop with enigma and Tomb Rider 2013 theme pack.
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    than its a long way to go. i have the same problem and posted before.I didnot get any true solution. reattaching gpu, reinstalling os or catalyst nothing worked. display driver, os, .net framework all are the culprits, suspect atleast.
    logging off by keyboard shortcarts get the monitor on.
    ATI HD 7950 Dual X
    If you find any solution, plz let me know. tag me here or pm me.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    @Reznov what about motherboard? can it cause it?
    I got replacement of this motherboard few months back, though replacement wasn't a new one.
    Reinstalled the drivers and CAP. Lets see for some times if it happens again.
    • Reznov's Gadgets
      • Samsung S19C300
      • A4TECH KM-720
      • A4TECH OP-620D
      • Samsung DVD R/W
      • Mobile ISP
    Reznov's Avatar
    Dinajpur
    my problem didn't arise in win xp. Win7 64bit is charging me a price.
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    I guess, monitor er setting reset koro, or DVI cable change koro 2ta dvi port 2ta teh check koro still problem thakle i guess gpu'r port problem, or onno problem still new kore win setup kore dite paro
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    @Ghz i have already reset monitor cables.
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    monitor setting ? try new windows
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    cant re-install windows now. I have to backup my files and Lots of files in torrent.
    Good news is, it havent occurred in last few hours (After restting the gpu and re-installing the driver). So I am keeping my fingers crossed. If it happens again I will notify you guys here.
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    ja files and documents ache, backup koira naw kokhon abar daak pore
  1. Playstation 3d display
    By mro145 in forum PlayStation
    Last Post: October 16th, 2012, 00:20
  2. No Display!!
    By Reznov in forum Technical Support
    Last Post: May 12th, 2012, 18:30
  3. laptop display problem
    By outragedhuman in forum Technical Support
    Last Post: October 19th, 2011, 22:32
  4. Laptop display problem
    Last Post: May 27th, 2011, 07:20
  5. My N 95 Display Gone Down
    By Speed in forum Miscellaneous Topics
    Last Post: October 8th, 2008, 17:18
Page generated in 0.30675 seconds with 14 queries.
