Thread: Heating problem and applying thermal paste.
    Default Heating problem and applying thermal paste.
    Hey, I have an Asus K42JY laptop. Its two years old. For the first year everything was absolutely fine, played games in high without a problem. Then suddenly u started having problems. While playing games, i would start lagging a lot with a scratching sound for like 15 seconds, then back to normal for 10 seconds. This kept on continuing. So i started looking for solutions online and the best one i found was my GPU was heating up too much, and to save the GPU it lagged. (Maybe i didnt explain it right). Anyway it told me to reapply my thermal compound. So i went to IDB, looking for the thermal pounds and stuff, i found some costing 30tk., 100tk. with korean or chinese stuff written on them. I even went to some of the shops and some of them replied that GPU dont even have thermal compound. Anyway, i just made one of them clean my fan and came back home. This is improve my temps. (Previous temps; idle; 65 C - 70 C load - 80 C - 90 C. Now idle; 50 C - 60 C load 65 C - 75 C). I'm still not satisfied as now this temps are based on me playing games on low. Anyway so i went online and bought Arctic Silver 5 (AS5) Paste and Articlean Cleaner.
    http://www.amazon.co.uk/Arctic-Silve...=thermal+paste
    My question is, is AS5 a good compound and does anybody know how to apply it an laptop GPU and CPU. Also, please do let me know id i'm missing something or you guys have a better solution.
    Thank you, i will really appreciate your help on this.
    • codename5302's Gadgets
      • Gigabyte X99-UD5 Wifi
      • Zotac 980Ti Amp Extreme
      • Fiio Andes E07K
      • Corsair RM850
      • 2 * Prollink 1200VA
      • Windows 7 64Bit
      • It works!!
      • 154
    codename5302's Avatar
    AS is a really good TIM. but to apply it to your laptop cpu and gpu, just put a little bit of TIM, then use something like credit card (something strong) to rub and spread equally to all the surface and reassemble your heatsinks with your cpu and gpu. tricky part is to disassemble and reassemble your laptop.
    • Ghz's Gadgets
      • MSI Z77A-G41 (Cooler Master Storm Enforcer)
      • Intel Core i5 2400 @ 3.10Ghz (Stock)
      • Corsair Vengeance 8GB (2x4GB) DDR3 - 1600
      • Samsung F3 1TB | WD 500GB USB 3.0
      • Asus GTX 660 2GB GDDR5
      • DELL LED E1912H (Dual Monitor Setup)
      • Creative Sound Blaster Audigy 7.1
      • Creative SBS A520 5.1 | a4tech HS100
      • Logitech (Call of Duty) - MW3 Edition
      • Razer DeathAdder Wired Optical With SteelSeries QCK Mass
      • Logic Gamepad
      • Corsair 750w
      • Asus DVD-RW | Sony Combo
      • 500GB WD USB 3.0 | 8GB Transcend
      • Powerpac (1200VA)
      • Windows 8 x64 & Windows 7 x64 (Dual Boot)
      • My World ! My Life (-_-)
    Mar 2013
    Sorry for the off-topic
    amar ekta toshiba core 2 duo laptop aache :/ age thik chilo but recently 3months dhore onek gorom hoitase..i mean idle 55c+ thake :/ r render/kono pressure work korle 80/90 chole jai Mobo+processor.. do I need to change any paste ?? any solution ?
  1. Want to Buy Thermal paste
    By shafi in forum Shop - Gadgets
    Last Post: January 8th, 2013, 18:54
  2. About Thermal paste
    By tanimr2002 in forum Others PC Hardware
    Last Post: March 1st, 2011, 11:03
  3. Sale (New) Thermal Paste and thermal paste cleaner
    By Mazhar in forum Shop - Gadgets
    Last Post: January 28th, 2011, 17:15
  4. Help applying thermal paste
    By n33l in forum CPU
    Last Post: December 23rd, 2010, 19:00
  5. Want to Buy Thermal paste
    By awestruck in forum Shop - Gadgets
    Last Post: February 6th, 2009, 03:05
Page generated in 0.16044 seconds with 14 queries.
