Results 1 to 12 of 12
Thread: Phone Heating up and battery reducing drastically when Using Earphone/Headphones
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    Unhappy Phone Heating up and battery reducing drastically when Using Earphone/Headphones
    Hello guys i use a htc inspire, and when i plug in my earphone(i have tested using 2 earphones so far), the phone heats up very fast from 34 to 43 C in about 5 minutes and the battery drains dramatically from 100-90 in 5 minutes or so which is a real headache for me since i can't listen to songs and videos using earphone, so i'm asking you guys for your expert help and can this phone be repaired here.
    • Metal's Gadgets
      • GIGABYTE [ GA-EP43-UD3L ]
      • INTEL(R) Core(TM)2 Quad CPU Q9505 @ 2.83Ghz
      • APACER 4GB DDR2
      • SAMSUNG 750GB
      • NVDIA GeForce 9500 GT
      • Dell E178WFP
      • CREATIVE Sound Blaster 5:1
      • COSONIC CD-779MV
      • A4Tech KR-83 USB [Black]
      • A4Tech OP-620D
      • ASUS P-50GA
      • ASUS DRW 24B1ST
      • Windows 7 Ultimate
      • ISPROS Limited
    Metal's Avatar
    Feb 2012
    Chittagong
    @TheNutKicker have you ever tried rooting your android to upgrade OS or launcher ? If so I think it is some software problem I am afraid if you messed up with process to follow.
    if not
    then it is hardware problem you have to take it to a expert.
    Power is not only what you have but what the enemy thinks you have.
    Looks like a classic shorting issue on the headphone port, honestly.
    But who knows, could be a software one too.
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Quote Originally Posted by Metal View Post
    if not
    Metal bhai i wish i had rooted it but i have not even thought about it so no , and who do you mean by expert.
    @Asif 11 ami buchi na ki mane 'mob' ar root to kore nai.
    Do you have any equalizer settings in place?
    • emroz_2272's Gadgets
      • Xonar STX
      • Microsoft Sidewinder X4
      • Samsung 24x DVD-RW
      • Acme 1000VA
      • Windows 10 Professional x64
      • Not into benchmarking!
      • Makes me delirious! :) :p
      • Agni Online 3/6 Mbps
    emroz_2272's Avatar
    Gulshan, Dhaka
    Did u put extra pressure while connecting the earphones? Codex may be right.
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    No equalizer no nothing. i've factory reset more than 3 times to no avail and the phone also heats up when i talk to someone more than 10-20 minutes without earphones
    Quote Originally Posted by TheNutKicker View Post
    So that rules out the DAC and the HP port. How hot is it when talking? Uncomfortable to touch? Phones will heat up when talking so need to know if it's within normal range.
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    It went up to about 43 C after 20 minutes of talking with a friend.
    I've deduced that maybe it could be my battery , but I've got no idea where to buy or test one(same one as the desire he)
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Problem still persisting,phones heats up to 43c in 5 minutes while talking and for every minute 2% of battery is depleted while also talking.
    • mr_08's Gadgets
      • Asus B75M+ || Gigabyte G41m combo
      • Intel core i5 2500k @3.3ghz cooled by the CM V6GT || Intel dual core e5500 @4ghz with TT V1AX cooler
      • Gskill RIPJAWS X SERIES 4gbx2 @ 1600mhz || adata xpg 2x2gb @1333mhz 7-7-7-20
      • samsung f3 500gb || wd 1tb , samsung 250gb
      • Sapphire 7970 OC 3GB w/ BOOST || Gigabyte 8800gts 512mb
      • Sony Bravia KDL42W700B || Samsung P2350, Samsung T190
      • integrated
      • Genius G500v || cosonic headphone
      • cm devastator mb24 , a4tech x7 g800 , logitech k260|| a4tech x7 g500,a4tech KB 28g
      • cm devastator ms2k , a4tech x7 X710 || a4tech office mouse, logitech m210
      • logitech g13,logitech rp2,xbox 360 wireless controller,generic usb x 3
      • xfx pro series 650w || delux 450w
      • liteon 24x w/ LT || asus dvd rw
      • Transcend 16gb USB 3.0 || Transcend 16gb usb 2.0
      • Apollo 1200va || Powerguard 650va
      • win7 ultimate sp1 || xp sp3
      • alhamdulillah!duitai chole,kharap na :D
      • Itbasebd || qubee
      • 8mb || 4 mb
      • 8mb || 2mb
    circuit short hoe gese most probably.btw you could use cpuspy to see if theres any rogue app or something like that which is causing the heat [if at all it has anything to do with apps]
    ami chhoto amake marbenna.-_- shob _ buira_gamer_
    Sounds like the PCB is defective, but could be a battery issue as well, before trying anything else, try a different battery.
  1. Reducing eye power
    By Cpt.Mactavish in forum Miscellaneous Topics
    Last Post: January 30th, 2013, 07:44
  2. Sale (Used) Two 7.5A UPS Battery is up for sale (Sealed Lead Acid Battery)
    By minitt in forum Shop - Gadgets
    Last Post: April 21st, 2012, 23:00
  3. C drive space reduced drastically/reducing automatically
    By gamefreak in forum Technical Support
    Last Post: January 31st, 2012, 00:34
  4. heating solution
    Last Post: May 29th, 2009, 16:23
  5. Need Heating Solution
    By GTracer in forum Technical Support
    Last Post: April 23rd, 2009, 03:45
Page generated in 0.22759 seconds with 14 queries.
