Results 1 to 19 of 19
Thread: Bioshock infinite writted discs problem
    Default Bioshock infinite writted discs problem
    i have been trying to play bioshock infinite in writted discs because malaysian discs are still not available on shop
    i tried 2 discs from 2 different place but couldnt play this game installing it..it says game disc error :/
    and again if i dont install , normally i couldnt play it used to hang in some place and says disc error try cleaning up etc...
    whats problem in there??? tried different discs but only this game got the problem
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    Change the disk with problem. Copy the game in HDD and then install it.
    Verified Retailer
    • MDK's Gadgets
      • MSI Z87-G43
      • Core i7 4770K
      • Team Xtreem 8GB x2 2400
      • Crucial M4 120GB, WD Cavia Green 2TB
      • Sapphire AMD Radeon 7970
      • ViewSonic VX2260WM
      • MS Xbox Wired Controller, MS Xbox Wireless Controller
      • Thermaltake Toughpower ST 750W
      • Lite-on DVD-RW, Pioneer BD-RW
      • Genuine Windows 8.1 Pro 64bit with Media Center
      • 158
    MDK's Avatar
    I am guessing you don't have a jtag or RGH system. if you burned using the old truncate method then there is a possibility that it won't work. Some games don't work when they are truncated. Other than that you might be using melody discs which are very low quality disc and might give you errors.
    • Hellblazer1971's Gadgets
      • Intel DG31PR
      • Intel Core 2 duo 2.66 Ghz
      • 3 GB DDR2
      • 2 TB
      • Nvidia GT240 512MB DDR5
      • Samsung 17inch LCD and Bravia Kdl-32v5500
      • Realtek
      • Creative Inspire 4:1
      • XBOX 360 Controller
      • ASUS 24B1ST DVD RW
      • Windows 8
      • It's getting old...
      • LINK3
      • 1 mbps
      • 1 mbps
    Hellblazer1971's Avatar
    May 2010
    Try to avoid any menu screen on the game.if u stay longer than 2 sec in a in-game menu screen it will pop up errors.Actually what it does is---some random disc check while the game is idle (when a menu pops up).But you can avoid all these fuss if you burn the game in a verbatim mkm-003 or 001 with ihas burner.
    http://xboxpirate.eu/forums/topic/14..._20#entry13324
    • chosen1's Gadgets
      • foxcon H55
      • core i3 540 3.07
      • Transcend 4 GB DDR3 1600 BUS( 2*2 GB)
      • HITACHI 1 TB
      • NVIDIA GeForce GT 440(apatoto),
      • Acer s273hl 27 inch
      • Creative Inspire M4500
      • ORIGINAL Xbox 360 wireless+Razer Onza Xbox360 Tournament Eddition+ 2X ps3 dualshock controller
      • Samsung Truedirect DVD RW
      • 16 GB Transcend Pendrive
      • Windows 8
      • currently gaming in Xbox 360 , PS3, PS4,soon gonna update the pc though
      • Local
      • 146
    chosen1's Avatar
    bad dvd...try to get another copy of local burned disk...malasian playbox dvd ashleo mone hoy na khub ekta laav hobe karon ogula locally burned copy thekeo aro beshi crap marka hoy ajkal
    • hasan_1223's Gadgets
      • intel DG41RQ__
      • intel core 2 quad Q8200
      • 2*2GB=4GB
      • samsung 500GB SATA
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Micro Kingdom 670S
      • Samsund DVD-RW
      • Appolo 800VA
      • windows XP SP2 / Backtrack 5r3
      • Uttara cable Network
      • 23
    hasan_1223's Avatar
    Oct 2012
    i would say. Get any blank dvd which has dvd+R Feature. Not dvd-R . Those are good for performence. And try to burn it with the low speed. Like 4x., or 8x.
    Well a new kind of problem appeared! The auto save does not work after a the second level i guess, and it does not have a manual save option like before(BRRILLIANT!!). I used to have the same problem with Bioshock 2 but manual save saved me that time.
    I googled and managed to find this- http://www.gamefaqs.com/boards/60505...inite/65892498
    Lets see if it works. In the mean time please let everyone know if anyone from here is having the same prob....
    • chosen1's Gadgets
      • foxcon H55
      • core i3 540 3.07
      • HITACHI 1 TB
      • Windows 8
      • Local
      • 146
    chosen1's Avatar
    well i experienced a problem like this...elizabeth ke 1st tym release korar por game theke bahir hoye abar game e dhuke ""continue"" dile onek pichon theke game start hoyto...kono solution py ny...tarpor deklam j ""load game"" theke latest location select kolre ey problem r hoy na....for example if u quite the game in the middle of ""Soldier's Field"" tahole pore continue dile onek agge theke shuru hobe..kintu load game theke Soldier's Field load korle recent save game pawa jabe.
    Quote Originally Posted by chosen1 View Post
    But after a while you will have the same problem I am guessing. Well, I found the solution all by myself!!(do rep me if it worked for you)
    Its all for the time issue we modded xbox owner have. Xbox requires internet connection to maintain proper time(so lame). If you notice when you turn the xbox the date is NOV 22 2005 and the time is always the same too, most probably 5 pm or something. Now here is what you need to do :
    1. Go to storage and select the Bioshock Infin, you will see all your saves.
    2. Select one by one and look at the right bottom to spot the time/date.
    3. Once you have managed to spot it, find the one with the most latest time.
    4. This is the trick - If the file with the latest time is for example 7.30pm, just go to your time setting and make the time 7.35pm. THAT'S IT!!!
    5. Do it every time before you play the game.
    • chosen1's Gadgets
      • foxcon H55
      • core i3 540 3.07
      • HITACHI 1 TB
      • Windows 8
      • Local
      • 146
    chosen1's Avatar
    Quote Originally Posted by muscle View Post
    lol amar to game almost sesh ekdom last er dike asi..amar method ey kaaz hoye gese amar...but 2mar method onno der jonno kaaz korte pare..ey jonno jao rep dya dilam
    Good for you, and thanks...
    thanks everyone....i dunno what actually happened....i just changed the discs from shop and brought a malaysian discs...its working fine :/
    • rextrio's Gadgets
      • gigabyte h61 d2 b3
      • i3 2100
      • adata 4 gb
      • samsung 1 tb
      • sapphire ati hd 5850
      • samsung p2450
      • altec lansing mx6021
      • a4tech
      • razer death adder
      • xbox 360 wired
      • thermaltake toughpower 600watt
      • asus
      • micro 1000va
      • win 7 64 bit
      • broadband
      • 64 kb
      • 30 kb
      • 24
    Jan 2012
    I bought a DVD itnext(release)it had a problem in 2nd disc,so I changed it to NPP(release) & it works fine
    • chosen1's Gadgets
      • foxcon H55
      • core i3 540 3.07
      • HITACHI 1 TB
      • Windows 8
      • Local
      • 146
    chosen1's Avatar
    Quote Originally Posted by rextrio View Post
    ami jotodur jani NPP & IT next xbox 360 er DVD sell kore na ..proper section dekhe post korun plz
    • TAHMID's Gadgets
      • Gigabyte 946
      • Intel Pentium D @ 3.2 GHz
      • 4 GB [2GB+2GB] 800MHz
      • 240 GB [80 GB+140 GB]
      • *busted
      • 40" SAMSUNG LED
      • 5.1 surround sound
      • Chicony
      • MSD cosy multimedia mouse
      • XBOX 360 CNTRLR \m/
      • Thermaltake TR2-500W
      • Asus Quietrack 22x
      • SanDisk CRUZER micro 4GB
      • Power surge.
      • Win 7 RTM 64 BIT
      • Dont Know
      • X360+ 40" LED, wh8 more do u need ?
      • dunno
    TAHMID's Avatar
    ダッカ, Bangladesh
    failed to authorize game after 10 mins playing...kono patch/update ber hoise ?
      • Intel DG31PR
      • 3 GB DDR2
      • 2 TB
      • Realtek
      • Windows 8
      • LINK3
      • 1 mbps
      • 1 mbps
    May 2010
    Quote Originally Posted by TAHMID View Post
    • TAHMID's Gadgets
      • Gigabyte 946
      • *busted
      • 40" SAMSUNG LED
      • Chicony
      • Power surge.
      • Win 7 RTM 64 BIT
      • Dont Know
      • dunno
    TAHMID's Avatar
    ダッカ, Bangladesh
    Quote Originally Posted by Hellblazer1971 View Post
    vai,menu open kori nai....just tower er upor uthei disc unauthorized astese...Majhe majhe tower e uthar agei astese...Cleared cache,and leveled time.
      • Intel DG31PR
      • 3 GB DDR2
      • 2 TB
      • Realtek
      • Windows 8
      • LINK3
      • 1 mbps
      • 1 mbps
    May 2010
    Have u installed the game and playing it from HDD? Then u can try playing mp3 from a pendrive on background(start the mp3 at the dashboard ,decrease the volume all the way down from the xbox music player> then start the game with the mp3 playing at the background).
    If u still get the error even without getting into a in game menu screen,then try deleting the game and play off the disc.
    I played off the disc and got error whenever any menu pops up..........
    So my advice will be that ......u should get a 100% complete burn discs.....
    I think they can help u for completely burned discs https://www.facebook.com/pages/Game-...24400330967628
    • TAHMID's Gadgets
      • Gigabyte 946
      • *busted
      • 40" SAMSUNG LED
      • Chicony
      • Power surge.
      • Win 7 RTM 64 BIT
      • Dont Know
      • dunno
    TAHMID's Avatar
    ダッカ, Bangladesh
    Have u installed the game and playing it from HDD? Then u can try playing mp3 from a pendrive on background(start the mp3 at the dashboard ,decrease the volume all the way down from the xbox music player> then start the game with the mp3 playing at the background).If u still get the error even without getting into a in game menu screen,then try deleting the game and play off the disc.I played off the disc and got error whenever any menu pops up..........So my advice will be that ......u should get a 100% complete burn discs.....I think they can help u for completely burned discs https://www.facebook.com/pages/Game-...24400330967628
    date ekdin kore baray kheltesi protibar...thanks for the suggestion...so far so good
  1. BioShock: Infinite
    By toukir95 in forum FPS
    Last Post: August 3rd, 2015, 22:17
  2. Bioshock: Infinite - Review round-up
    By anik_lc in forum News
    Last Post: March 25th, 2013, 21:42
  3. BioShock Infinite costs $200million!
    Last Post: March 23rd, 2013, 22:13
  4. BioShock Infinite Delayed Once Again
    Last Post: December 7th, 2012, 20:16
  5. Replies: 5
    Last Post: November 27th, 2012, 13:42
Page generated in 0.29480 seconds with 14 queries.
