Results 1 to 13 of 13
Thread: Monitor Problem !
    Default Monitor Problem !
    Kisudin holo amar monitor ta problem kortese . Problem ta holo , pc start korar por 1-2hours pore monitor ta blink kore . ar top left side e Analog-Digital ekta box switch hote thake . 5-8sec theke por por Analog-Digital hote thake .Display blink kore mane monitor jai ar ashe. erokom 10 min howar por monitor er display chole jai ar Analog-Digtal hote thake .
    Amar monitor Samsung T Series - T200 . Amar monitor er cable eirokom .
    Ami graphics card e VGA to DVI Adapter use kori . Graphics card e kono VGA port nai . Graphics card Sapphire 6850 . Monitor e VGA port + DVI port 2tai ase . kintu ami monitor er side e kono adapter use korina .Monitor er VGA port e cable ta use kori .
    1year ageo same problem hoisilo amar ager pc te . tokhon monitor er warranty chilo . ami warranty claim korte gesilam . kintu oder kase nie jawar por monitor thik vabe cholsilo . 2hours chalailam kono problem painai :S
    tokhono monitor er top left e Analog-Digatal hote thakto . ektu por monitor er display chole jai .
    ekhon ar monitor er warranty nai . Monitor ki repair kora jai valo vabe ? samsung er kono repair centre ase ?
    Monitor er arekta side e VGA to DVI Adapter use korle lav hote pare ? VGA to DVI Adapter er price koto hote pare ?
    I am in huge trouble .Plz help me guys
    Quote Originally Posted by Asif 11 View Post
    Vai etosob adapter use na kore ekta dvi to dvi cable kinen. Tailei jhamela shesh.....
    DVI to DVI cable er price koto ? DVI to DVI cable use korle problem solve hobe ?
    Either that converter is faulty or your monitor is getting less electricity or the cable is lose. Three things can help you 1 . Change the converter and use direct dvi to dvi or vga to vga connector 2. Check the power cable either its lose or not 3. Check the power line is it ok or not
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    worst case scenario ..... inverter is failing
    Member rummoi's Avatar
    Nov 2009
    Shahjahanpur
    onek din por kono comment korte boslam.
    amaro same problem hoisilo. monitor ektu por por blink kore, analog-digital, auto adjustment 100% etc. etc. warranty ses howar 3 month age dokan e nia gelam. ora ek soptah er moto rakhlo. ferot dilo. sob ok. warranty ses hoar ek soptah por abar ager problem. amar mone hocchilo monitor er side e jei button gula die amra resolution, color etc. change kori oi button gulate somossa. google e search dilam. youtube e ekta video dekhe monitor ta khullam (b very careful). tarpor monitor er pasher button gular power disconncect kore dilam. problem solved. may be capacitor e problem chilo.
    Quote Originally Posted by blood stain child View Post
    Thanks . DVI 2 DVI cable koi pabo ar valo gular price koto hote pare ? power cable loose hoi nai sure . power line tao check korte hobe .
    Quote Originally Posted by rummoi View Post
    Vai , Exactly , exactly & exactly same problem . Purai SAME. Apni kivabe solve korsilen plz details bolen [email protected]rummoi vai youtube er video er link ta dan plz . Btw , apnar monitor ki Samsung T Series/T200 chilo ?
    I am getting frustrated day by day . pls help me
    • babu.'s Gadgets
      • Gigabyte H81 S2PV/ Gigabyte B75 D3V
      • Core i5 4590/ i5 3470
      • 8 GB Adata XPG 1600 @ CL9/ 8 GB Team
      • 3 TB WD Blue
      • Shaphire R9 270X VaporX
      • LG 22'' mp65HQ/ Dell 17''
      • Altec VS4621, Skullcandy INK,D airphone
      • Tharmaltake TR2 600w/ TT LP 430w
      • Transcend 2TB Portable HDD
      • Windows 10, 7(64 bit)
      • CPU - 7.6, Ram - 7.7, GPU 7.9, HDD - 5.9
    babu.'s Avatar
    Mar 2012
    Khulna
    Quote Originally Posted by Xperience View Post
    Search in IDB or Multiplan center ... price is in between 250 to 500 tk.
    Multiplug er jonno ki kono problem hote pare ?
    Idb er pichoner dorja dia jawar time e jei dokan gula pawa jay oikhanei dvi to dvi cable pawa jabe price are 200 to 600taka but before buying that kono friend er kas theke dvi to dvi cable ene test kora ta better and if internal problem hoy then kisui korar nai oi youtube dia try kora gale kora jaite pare your own risk, ar multiplag sobchey besi problem kore amar akta sound box gase due to imbalanced power supply
    If the monitor is getting power (I.E. - Turning on) the inverter is fine, next you should check is if the inputs are working properly. It could be that the VGA input doesn't work but the DVI does or vise versa. Since ~600 BDT is a rather small price to pay rather than replacing the whole screen I'd say try replacing the cable and see if it works. If it doesn't, just keep the cable for future use and replace the screen or repair it if that's a feasible option.
    OT: Bro what is a sound box?
    Quote Originally Posted by Rakin7 View Post
    sorry that will be speaker not sound box
    Nov 2009
    Shahjahanpur
    amarta samsung 2033sw.
    https://www.youtube.com/watch?v=Ul5LhuCT1y8
    b very careful when opening the case.
    apnar monitor ta ki ekhono valo vabe choltese ?
    Monitor kholar shomoi khub beshi risk ki ase ? naki kono repair centre e nie jabo ?
    BD te Samsung Monitor gula valovabe koi repair kore ?
  1. CRT monitor problem
    By Cpt.Mactavish in forum Technical Support
    Last Post: March 12th, 2012, 11:18
  2. monitor or gpu problem?
    By offcutter in forum Technical Support
    Last Post: September 12th, 2011, 13:51
  3. Monitor Problem
    By zaman_177 in forum Technical Support
    Last Post: February 8th, 2011, 06:55
  4. Monitor problem
    By Dee in forum Others PC Hardware
    Last Post: October 5th, 2010, 08:51
  5. Monitor Problem
    Last Post: June 11th, 2010, 07:18
Page generated in 0.24202 seconds with 15 queries.
