Results 1 to 6 of 6
Thread: 140mm Red LED case fans in Bangladesh
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Default 140mm Red LED case fans in Bangladesh
    Like the title says, I need a Red LED case fan that has to be 140mm x 25mm. The fan speed (RPM) does not matter but it have to be transparent and very bright like TT Thunderblades or Akasa AK-FN075. Any help will be much appreciated. Thank You.
    P.S.: If anyone has Red Cathodes that they want to sell can you PM me your offer or post a link to your selling thread. Thank You.
    • Rorschach's Gadgets
      • MSI B85 GAming
      • Core i3 4130 3.2Ghz
      • Corsair vengeance 2*4gb = 8gb Ddr3 1600Mhz
      • 128Gb Crucial M4 SSD + 2TB Hitachi HDD + 2* 2TB Seagate HDD+2TB Seagate HDD+(4TB+3TB) Seagate HDD
      • EVGA GTX 980 SC ACX cooler
      • Sony Bravia W670A 32inch
      • Sound Blaster X fi Titanium
      • Panasonic HTF600 + Creative 4:1 Speaker
      • Ducky
      • V3
      • Xbox 360 Controller In PC via Receiver
      • TT Toughpower XT 675W 80+Bronze
      • Asus Dvd-RW ; NZXT Sentry 2
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • BUCT 2Mbps real ip
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    Yate loon 140mm RED Led Fan .. 1000RPM maybe , silent edition .. 3pin connector ... And its LED's brightness is as like as TT Thunderblade's Led .. Price : 900 taka(fixed).
    YAte Loon D14SL - 12
    1000rpm
    49Cfm
    25DB
    বাট রিমেমবার, জলিল নেভার ডাই, আর মরলেও ডাই এনাদার ডে।
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Thanks for your reply. Offer koto din ase ? Amar taka jogar korte aktu time lagbe and price ektu komano gele bhalo hoto.
      • MSI B85 GAming
      • Ducky
      • V3
      • Thermaltek Armor
      • Luminious 1000VA
      • Windows 10 64Bit
      • 12.5MBPS
      • 12.5MBPS
    Rorschach's Avatar
    Oct 2011
    U can take As much time as u need . no huury .. But the price is Fixed .
    • Raziel's Gadgets
      • Asus P8Z77 - V
      • Intel Core i5 2500K @4.2GHz
      • Sapphire Vapor-X HD 7970
      • Asus MS228H 21.5''
      • Realtec HD Audio
      • Microlab Solo 7c
      • Logitech K220
      • X7 XL-747
      • Logitech F510
      • TT Toughpower 750watt
      • 2 GB + 8 GB
      • Micro 1000v
      • Link 3 1MB NDP
      • 100/200
      • 1.2 Mbps
    Raziel's Avatar
    Dhanmondi, Dhaka
    i've one 140mm red one. It's a stock fan of TT Spedo. But one of the 4 LED is broken.
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Thank you everyone but I wont be buying any. Just found out that my casing does not have any cut-outs at the top for 140mm fans, only 120 or 200mm
  1. Replies: 66
    Last Post: January 11th, 2013, 20:17
  2. about case fans
    By codename5302 in forum Help - General Shopping
    Last Post: April 28th, 2012, 07:13
  3. Loud Case Fans any solution?
    By Rakin the Devil in forum Technical Support
    Last Post: March 19th, 2011, 03:00
  4. Searching Case Fans
    By craNIUM in forum Others PC Hardware
    Last Post: July 3rd, 2009, 11:02
  5. GELID Launches Green UV WING Case Fans
    By Black Neon in forum Others PC Hardware
    Last Post: August 14th, 2008, 19:58
Page generated in 0.17674 seconds with 14 queries.
