Results 1 to 13 of 13
Thread: Need HELP with Overclocking..i7 3770k
    • xXllSHARPEYESllXx's Gadgets
      • ASRock Z77 Professional Fatality
      • Cooled by CoolerMaster Seidon 120M Intel Core i7 3770k Unlocked 3.50GHz,8MB
      • Corsair Vengence 8x2 GB
      • Intel SSD 120GB 330 Series,1 TB Samsung,2TB Hitachi
      • Sapphire HD7970 3GB GDDR5 PCI-E DL-DVI-I+SL-DVI-D / HDMI / DP OC WITH BOOST
      • Samsung SyncMaster B2230 21.5 inch
      • Have one but don't use it
      • SteelSeries SIBERIA/Microlab FC 861
      • Razer BlackWidow Ultimate
      • Steel Series Sensei [RAW]
      • Razer ONZA Tournament Edition
      • InWin Commander II Bronze 750W
      • Windows 7 ultimate 64-bit
      • aWsOme
      • SmileBD
      • purai ballll
    xXllSHARPEYESllXx's Avatar
    Nov 2012
    Uttara,DHaka
    Default Need HELP with Overclocking..i7 3770k
    Hellow Guys ..
    i'm new at overclocking . i need u'r help with overclock my CORE i7 3770k
    i don't if there is any software i should use ..
    I'm using Coolermaster Seidon 120M for Cooling
    And a 80+ bronze 750 watt
    i wan't to know how much GHZ can get from this ..
    HELP me out Guys .. PLZ
    There's no way to tell how much you can get by specs alone. It's all trial and error. You increase the clock ratio, stress you CPU and see if it is stable.
    Rinse and repeat.
    First of all install some softwares like hwmonitor , cpu z and prime95 and intel burn test then restart your pc and press f2 and go to the bios. Now you will see many options there, go to the cpu config and then click it to manual and now , there you may see fsb which is set to 35 for i7 3770k, now set it to higher your wish but dont touch the bclk. The calculation is simple now if you want to overclock your processor to 4ghrz then set 40 in fsb and it will be overclocked to 40x100=4.0ghrz , if you want to overclock it to 4.5ghrz, set the fsb to 45 and it will be overclocked to 45x100=4.5ghrz. But as you are into the beginning stage so dont go over 45 and dont touch the voltage options for now and after that save and exit the bios. Now disable your turbo boost and run intel burntest and stress your processor for sometimes and see cpu z frequency and also see all 4 core temperatures in hwmonitor , if you see the highest temp in hwmonitor are below 70 and you are not getting any blue screen error, then you are successfully overclocked your processor! For more idea see this http://www.overclock.net/t/1198504/c...asrock-edition
      • aWsOme
      • SmileBD
      • purai ballll
    Nov 2012
    Uttara,DHaka
    ami 45 diye silam multiplier blue screen error dekhaise .. ekhon 40 te diye rakhsi 42 porjonto dile kono shomosha hoyna .. kintu baraile blue screen dekhay .. age kokhono prime 95 emon konoo softwere diye test kori nai maybe thats way i get Bluescreens..??
    You need to adjust your Core Voltage too. Try setting it to 1.3v, ratio at 45 and then run prime95 for 15 minutes and see if it is stable.
    • eXsTatik's Gadgets
      • Msi 990FXA GD80
      • Phenom x6 1090T @ 4ghz 24/7
      • 8gb drr3 1600mhz
      • 500GB x2 raid 0 + 1TB caviar black + 500GB wd passport.
      • GTX 580
      • Syncmaster 2243
      • X-fi titanium
      • 2x microlab solo 7c front and back, 2 x microlab FC subs + pro 1 as center
      • Razer blackwidow
      • Razer imperator/deathadder/a4tech x7/razer boomslang 2007CE/ Razer Abyssus
      • xbox 360
      • 850 Toughpower Thermaltake
      • Glasses.
      • Generator that runs on oil downstairs with 24/7 backup
      • Windows7 64 I still dont really care.
      • Yes if you are wondering I am AMD fanboyish :/. LOL
      • link 3
      • 142
    eXsTatik's Avatar
    Beyond reality
    Keep increasing the multi till you hit bsod, then increase the volts in 0.05 increments, it would be helpful to know which board you are running.
    FTW!!!!!!!!!!
    Jodi stable na thake tailei blue screen ashbe prime95 or intel burn test result e . .tao as aayman vya saying , increase the voltage to 1.30 and then set the fsb again to 45
      • aWsOme
      • SmileBD
      • purai ballll
    Nov 2012
    Uttara,DHaka
    acha kon temp porjonto stable ba vhalo jate kono shomosha hobe na..
    Ivy bridge 4.4 or 4.5 e gale e enough akhon jodi 4.3 teo stable thake oitao ok . .ivy gula sandy er moto 4.8 or 5ghrz kora jay nah. 1.3vcore e jodi 4.4 e ante paro then enough naile arektu baray 1.32vcore e gia dakho , ar temperature test korio
    • Raihan081's Gadgets
      • Asus Maximus VI Hero
      • Intel Core i7 4770k
      • Corsair Dominator Platinum 4x4GB DDR3-1866
      • WD 3TB Red, 256GB Samsung 840 Pro Series
      • EVGA GTX 780 Ti SC Dual Classified ACX in SLI
      • Samsung UD590 UHD
      • Turtle Beach - Call of Duty Spectre
      • Razer Deathstalker Ultimate
      • SS Kana Ltd Ed. Dota 2
      • Corsair AX1200i
      • Windows 8 64 bit
      • Tellus
      • 6656
      • 1536
    Raihan081's Avatar
    stock cooler e ki 4ghz kora possible?
    Quote Originally Posted by Raihan081 View Post
    possible
      • aWsOme
      • SmileBD
      • purai ballll
    Nov 2012
    Uttara,DHaka
    now running at 4.2 GHz not having any problem ... ar tem kokhono 70 er upore uthtesena ... i don't think i need any more then 4.2 core voltage barainai 1.18 e ase.. ar any tricks how to over clock ram i also don't think i don't think to over clock my rams..
    and thanks for the helps...
    Quote Originally Posted by xXllSHARPEYESllXx View Post
    overclocking ram optional dorkar e pore nah
  1. i5 3570k with HD7950 or i7 3770k with HD 7850?
    By mourla in forum Help - PC Buying
    Last Post: February 22nd, 2013, 17:31
  2. Intel Core i7 3770k or 3770 for gaming
    By Xperience in forum CPU
    Last Post: February 14th, 2013, 18:04
  3. How to OC i7 3770K
    By CvP in forum CPU
    Last Post: July 6th, 2012, 14:14
  4. Replies: 5
    Last Post: January 16th, 2011, 03:07
  5. factory overclocking vs. own overclocking ?
    By Leaving BG in forum GPU
    Last Post: April 20th, 2009, 01:45
Page generated in 0.23361 seconds with 14 queries.
