Thread: problem with Blacks Ops II....!
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    Default problem with Blacks Ops II....!
    i've got two sets of dvds of the game...
    i)SoftwareGarden, ii)IT Next
    the one from softwaregarden has to be extracted first then install from that...and the it next one can be installed from the dvd...
    tried both, did exatcly the same as it is told in the README file....but both doesnt seem to work....
    when i start the game, black screen shows up with the cursor, and thats it....after the alt-ctrl-del when i go to the taskbar, windows shows the stopped working thing....
    So how have you guys, played it??
    thanks in advance
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    Try this one
    http://thepiratebay.se/torrent/7834995/
    Not sure if it will work though.
    Check the minimum system requirements
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Quote Originally Posted by giant View Post
    I can confirm that ITNext one has problem. I changed it again from (gave a different copy) them and it worked.
    • giant's Gadgets
      • MSI H77MA-G43
      • Realtek ALC892
      • Delux K9020
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    Quote Originally Posted by fahimspider View Post
    Try this one
    [url]Check the minimum system requirements
    requirements niye prob na...amar 2ta frnd er pc te o tro korsi (i3 2100+6670) ar ekta lappy (i5 480m+5650)......
    oi comments gulo porsen??
    Quote Originally Posted by radeef View Post
    ITNext er dvd te tutorial deoa, dvd1 e ar dvd2 te....tao kaj hoy nah :/
    ....ar time zone er ki korsen?? itnext er tae boleh (gmt-4 asuncian) ar sftwrgrdn er ta bole (gmt+8 taiei)....!!!
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    there were 6 updates if i remember correctly why not download those and try one by one.
    Set the date to 13 nov 2012 and then restart and then run the game. No need of changing +8 or +6 times or download d3d crack from skidrow that will work i hope
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    @giant as far I remember first time playing the game I had to change the date and time zone. Few days later skidrow released a crack, which didnt required to change anything.
    I checked my dvds. It was a RSB release. It runs fine. You just need to download crack fix.
    Or you can try this -
    http://kat.ph/call-of-duty-black-ops-ii-update-3-skidrow-t6903665.html
    • giant's Gadgets
      • MSI H77MA-G43
      • Realtek ALC892
      • Delux K9020
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    gamecopyworld got all crack fix..., should i download all of them and replace them 1 by 1!!
    Nov 2012
    You should try what @blood stain child said. Changing the time zone to +6 worked for me, but you could try changing the date too.
  1. Nvidia Driver Problem or Graphics Card Problem ??
  2. problem after OC
    By @nonymous™ in forum Technical Support
    Last Post: January 10th, 2011, 18:58
  3. is the problem in my ps2 or dvd?
    By eagle_gaze in forum PlayStation 2
    Last Post: January 9th, 2011, 20:30
  4. RAM problem need help !!!!
    By TAHMID in forum Others PC Hardware
    Last Post: August 17th, 2009, 04:19
  5. problem!!!!
    By Walking Death in forum Software
    Last Post: May 2nd, 2009, 11:22
Page generated in 0.21080 seconds with 14 queries.
