Results 1 to 20 of 34
Thread: GTA IV (FPS Problem)
    • Ghz's Gadgets
      • MSI Z77A-G41 (Cooler Master Storm Enforcer)
      • Intel Core i5 2400 @ 3.10Ghz (Stock)
      • Corsair Vengeance 8GB (2x4GB) DDR3 - 1600
      • Samsung F3 1TB | WD 500GB USB 3.0
      • Asus GTX 660 2GB GDDR5
      • DELL LED E1912H (Dual Monitor Setup)
      • Creative Sound Blaster Audigy 7.1
      • Creative SBS A520 5.1 | a4tech HS100
      • Logitech (Call of Duty) - MW3 Edition
      • Razer DeathAdder Wired Optical With SteelSeries QCK Mass
      • Logic Gamepad
      • Corsair 750w
      • Asus DVD-RW | Sony Combo
      • 500GB WD USB 3.0 | 8GB Transcend
      • Powerpac (1200VA)
      • Windows 8 x64 & Windows 7 x64 (Dual Boot)
      • My World ! My Life (-_-)
    Mar 2013
    Default GTA IV (FPS Problem)
    Hey guys, um having some tough time with GTA Iv, currently um using Sapphire 5870 2GB Vapor-X + 19" LED (720p) - check my gadget
    Logically 5870 diye GTA IV 720p teh max-out kore khela jabe but amar serious FPS drop kortase, i tried forums and cracks still no solution... Lights on korle 40>20/24 FPs drop kore, kichu kichu place a constand 45+ thake abar Raater time a onek drop kore need solution
    • Mohiuddin's Gadgets
      • Xeon X5650
      • 8gb gskill ripjaw
      • Western Digital 1TB blue
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Gigabyte 1200w OdinPro
      • Apatoto nai
      • Netvision
      • Janina, 3Mbps may be
      • Don't upload...
    Uttara,dhaka
    Did u apply 1.5v patch and crack?
    It improves gpu usage and shadows.
    Moreover u have to tweak a bit to get smooth experience. Like car density , view distance etc etc to find a suitable combination.
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Can u please give me a download link by the why do I need to tweak the setting ? :O Shob High graphics a dile 5870 handle korte parbe nah amar ager laptop Sony Vaio teh 4670 1GB Dedicated chilo oita teh 1024x768 (Shob Mid/High) constand 23/24+ FPs chilo
    r 5870 teh 800x600 same problem
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    ^link janinah, google search dao '1.5 gta4 patch crack' u may find . Amio emne khuje namae silam.
    About settings, find the spot of minimum-quality-lost with maximum-performance-gain. Or, u may try different graphics drivers and ocing cpu if it is the cause of bottleneck.
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    You serious ? 5870+i5 2400 Bottleneck ? Btw um using the latest AMD driver, dekhi 1.5 patch try kori thanks mate
    @Mohiuddin Will this work ? http://www.4shared.com/rar/rEyfYZf6/GTA_IV_PATCH_1004CRACK_RAZOR_1.html ?
      • Xeon X5650
      • 8gb gskill ripjaw
      • Zotac GTX670 4GB
      • now with TV
      • 2:1
      • Apatoto nai
      • Netvision
      • Don't upload...
    Uttara,dhaka
    U may not noticed that i am from mobile. It is tough to browse those sites. But from the site adress it seems 1.4v?
    Not latest drivers, try 12.1 or 12.11 .
    • Yaaya's Gadgets
      • Gigabyte H81 S2PV
      • Intel Core i3 4150
      • Twinmos 4x2 DDR3 1600mhz
      • Western Digital Cavier Blue 1TB+1TB
      • Sapphire AMD Radeon R7 265 Dual-X 2GB
      • Del 18.5inch LCD
      • Antec VP550C EC 550 Watt
      • Asus DVDRW
    Yaaya's Avatar
    Jun 2012
    Hidden Leaf Village
    try patch 4 it will give really good speed boost. I personally tried patch 4,6 and 7. Patch 4 gives good fps and patch 6 and 7 just lowered my framerate
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Quote Originally Posted by Yaaya View Post
    It will be really helpful if you can provide me a working download link, onek patch ase, konta work kore m confused, ATM my net is abit slow as using Robi
    • Yaaya's Gadgets
      • Gigabyte H81 S2PV
      • Del 18.5inch LCD
      • Asus DVDRW
    Yaaya's Avatar
    Jun 2012
    Hidden Leaf Village
    Quote Originally Posted by Ghz View Post
    patch: www.thegtaplace.com/downloads/f4249-gta-iv-pc-patch-v1040
    crack: www.mediafire.com/?jxzjezmzuzd
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    2ta e download kore crack ta present crack er sathe replace r Patch ta apply korbo .
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Still same problem anyone HELP ??
    • Overlord's Gadgets
      • Asrock Z370 Pro4
      • Geil 8GB DDR4 2400
      • MSI GTX 970 OC Gaming 4G
      • ASUS VX229H IPS 21.5 LED
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Samsung 22X DVD RW
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Reinstall windows. Patch the game upto 1.7 thats it.
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Quote Originally Posted by Overlord View Post
    For my case screen was freezing every 2 seconds. Though I can run any games on ultra graphic settings. Will patching solve this issue?
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Quote Originally Posted by radeef View Post
    Patch solves most of the issues. BUT New drivers can cause problems as the game is pretty old now. Patch it up to 1.7
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Can u please provide me working patch link please as facing hard time with my Internet
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    Apply Patch 1.0.6.0 First. Then apply 1.0.7.0
    1.0.6.0 - http://www.fileplanet.com/195520/190...uto-4---Patch-
    1.0.7.0 - http://support.rockstargames.com/ent...-5-2-Japanese-
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    I downloaded 1.4 patch, when I tried installing it - it says Rockstar software something is missing... So above patch will have some problem ?
      • Asrock Z370 Pro4
      • Built in HD Audio
      • MicroLab 2.1
      • AutoKey Gaming
      • USB Gamepad
      • Corsair VS450
      • Weli Power 800VA
      • Satisfied
      • Antaranga
      • 3 Mbps
      • 3 Mbps
    Overlord's Avatar
    I dont know bro. What i did was Installation of GTA 4 and apply 1.6 & 1.7. Good luck
    • Yaaya's Gadgets
      • Gigabyte H81 S2PV
      • Del 18.5inch LCD
      • Asus DVDRW
    Yaaya's Avatar
    Jun 2012
    Hidden Leaf Village
    is the game fullrip version or original setup version
    • rumy's Gadgets
      • Asus p8b75m-V
      • intel i5 3470
      • Transcend 8 GB ddr3 1600mhz
      • Hitachi 2 TB
      • Gigabyte GTX 660 OC ddr5 2GB
      • Dell E1912H 18.5 inch
      • Microlab m 108
      • Gigabyte M5050
      • Logitech f310
      • Cooler Master GX 550 , 80+ Bronze
      • ASUS DRW-24B5ST
      • Transcend 32 GB
      • Power Guard 650 VA
      • Windows 7 Ulitimate 64 bit
      • Processor 7.5, Ram 7.8, Graphics 7.9, Gaming Graphics 7.9, Harddisk 5.9 ( according to WEI, win7 )
      • Zip Cyber Cafe (Bengal Group Limited)
    rumy's Avatar
    Sep 2012
    bro download this.
    http://kat.ph/gta-iv-patch-1-0-3-0-crack-t2585937.html
    copy GTAIV_Patch_1030 to game location.
    install it.
    Then copy paste crack.
    it fixed my fps drop issue.
    let me know, kaaj hoise kina
  1. Nvidia Driver Problem or Graphics Card Problem ??
  2. My GPU Problem
    By LizZzaRd in forum Technical Support
    Last Post: October 5th, 2011, 06:13
  3. problem after OC
    By @nonymous™ in forum Technical Support
    Last Post: January 10th, 2011, 18:58
  4. is the problem in my ps2 or dvd?
    By eagle_gaze in forum PlayStation 2
    Last Post: January 9th, 2011, 20:30
  5. problem!!!!
    By Walking Death in forum Software
    Last Post: May 2nd, 2009, 11:22
Page generated in 0.28576 seconds with 14 queries.
