HI
I want to buy a 32" Smart TV. Do you have any idea which brand and model i should buy? I need 1080p full HD. Budget around 30 k
Thanks in advance
HI
Thanks in advance
A VIRUS WHICH HAS NO DEFINITION
Either Sony or Samsung. Sony has Android but is laggy iirc. Samsung has Tizen, less laggy than android but less app support. Nonetheles popular apps are supported. Sony is good for watching action scenes (sports, action movies etc) but has more input lag (bad for gaming). Out-of-the box better picture quality settings. Dark scenes are to be desired.
Samsung has less input lag (good for gaming), not horrible out-of-the box picture settings (but worse than sony). You can get calibration settings from RTINGS and other websites at least. Dark scenes are quite dark (darker than sony) cause Sony uses IPS whereas Samsung use VA.
IDT either have smart TVs at 32". The least is 40" AFAIK.
Current 32 inch most of tvs are 720p.Dont take those, take 1080 resulation tv, Try to get Lg 1080 tv those are a bit expensive but good quality.
