Results 1 to 14 of 14
Thread: Help (PSU Fan)
    • Ghz's Gadgets
      • MSI Z77A-G41 (Cooler Master Storm Enforcer)
      • Intel Core i5 2400 @ 3.10Ghz (Stock)
      • Corsair Vengeance 8GB (2x4GB) DDR3 - 1600
      • Samsung F3 1TB | WD 500GB USB 3.0
      • Asus GTX 660 2GB GDDR5
      • DELL LED E1912H (Dual Monitor Setup)
      • Creative Sound Blaster Audigy 7.1
      • Creative SBS A520 5.1 | a4tech HS100
      • Logitech (Call of Duty) - MW3 Edition
      • Razer DeathAdder Wired Optical With SteelSeries QCK Mass
      • Logic Gamepad
      • Corsair 750w
      • Asus DVD-RW | Sony Combo
      • 500GB WD USB 3.0 | 8GB Transcend
      • Powerpac (1200VA)
      • Windows 8 x64 & Windows 7 x64 (Dual Boot)
      • My World ! My Life (-_-)
    Mar 2013
    Unhappy Help (PSU Fan)
    Recently I pulled out 2x80mm fans from my old broke PSU, so its without molex (that 4pin connector).. so all I need is that - is it possible to use it without molex ? how can I attach it to my psu ? I tried google mama, still fail :/
    • neorage's Gadgets
      • Gigabyte GA-P55M-UD2
      • Intel Core i7 860 @ 2.93Ghz
      • Corsair Vengeance 2x4GB DDR3 1600MHz (9-9-9-24)
      • Samsung 830 128GB SSD (Boot Drive) & Samsung F3 1TB
      • ECS GTX560 1GB
      • View Sonic VA703m 17" LCD
      • Realtek ALC888B
      • Havit HV-H611d
      • A4Tech Bloody V3
      • Thermaltake TR2 550W || Antec One S3
      • Asus DRW-24B1ST
      • Corsair Flash Voyager 16GB USB 3.0
      • Prolink 650VA
      • Windows 7 x64 SP1
      • IS Pros
      • 1.25 Mbps
      • 512 kbps
    neorage's Avatar
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Bump ! any solution ?
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    @Ghz do you want to connect it to another chasis? Is it with 3 pin connector?
    To avoid confusion can you upload the pics of the fan with connectors?
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Quote Originally Posted by fahimspider View Post
    Usually, PSU teh cooling fan ta thake, oita ami chasis a amar PSU er sathe conntect korte chai... FAN er just 2ta wire RED AND BLACK
    • Cpt.Mactavish's Gadgets
      • Intel DG31PR
      • Intel C2D
      • 2GB
      • Samsung 250GB
      • Realtek HD
      • Generic Tiner Box
      • Asus DVD RW
      • Prolink
      • Windows 8
      • Cpu:5.4,Gpu:7.1,HDD:5.9
      • Happy with it!
    Cpt.Mactavish's Avatar
    4pin Molex khuje bair koren.kahini shesh
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    ^^Same Advice. Connect Red and Black wire to a 4 pin molex. I will upload a pics, but I have to do it later.
    Check the fan spec if it is a 12V Fan connect the RED wire to molex yellow & Black to black. If it is a 5V fan connect the RED to the molex RED.
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Yh, I guess ur one will work, aajke try korbo, by the way do upload a pic if possible
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    @Ghz Uploading The Pics. Hope it help
ID:	28107Click image for larger version.
ID:	28108Click image for larger version.
    Sorry for the quality. you can directly put the wires in the pin.
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    BRO...AMAR kache je 2ta fan aache, oitar kono connector nai, just 2ta Black and red wire, ami jani ki vabhe fan attach korte hoi with molex -_- but dont knw how to do it without molex
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    @Ghz Put the wires in a molex as in the pics. OR go to a electric shop and ask them to put the wires in the molex.
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Ohkay thanks for ur help mamma miya ...
    • Forhad666's Gadgets
      • Gigabyte GA-B75M-D3H
      • Intel Core i5-3470 3.20GHz
      • G.SKILL Ripjaws Series 8GB (2 x 4GB) DDR3 1600
      • Hitachi 1TB SATA 7200 RPM
      • Sony Bravia R352B 40 inch (1920x1080), LG W2053TQ (1360x768)
      • On-board audio
      • 12 Years Old 2x1 Creative :p
      • A4Tech V3 Bloody Multi-Core Gun3
      • Logitech - Gamepad F310
      • Thermaltake SMART 430W
      • Asus 24xDVD-RW
      • Apollo 800VS
      • Windows 7 64 Bit
      • 100 kbps
      • 100 kbps
    Forhad666's Avatar
    Mar 2013
    sorry GHz for the offtopic question..
    psu fan ta kon dike facing (upward or downward) hole valo hoye??
    amar casing-er niche psu- installation place n niche akta air ventilation-er system ase..
    still amii psu fan ta downward kore install korte parii naii..!!
    fan ta upward (processor facing) hoyate kii kono problem hobe??
Page generated in 0.23913 seconds with 14 queries.
