Thread: weird issue with power switch
      • MSI MORTAR MAX B450
      • RYZEN R7 2700
      • 8X2 CORSAIR VENGEANCE 3200
      • 1 TB WDD BLUE , 128 GB RIPJAWS M.2 SSD
      • GALAX GTX 1660TI EX WHITE
      • SAMSUNG 943SWX
      • KZ ZSN PRO
      • GENERIC DELL
      • A4TECH GENERIC
      • COOLER MASTER B500
      • SPEED TECH ONLINE
      • 10mbps
      • 5mbps
    Default weird issue with power switch
    Hello everyone , i am not sure this is the right section to discuss this but anyways i am having a very weird issue with my pc where i have to press power button 2-3 times to start my pc . after the boot everything works normally but i went on vacation out of dhaka for a week and after coming home today i have to continuously press my power button to boot my pc , the thing is after the boot nothing weird happens my pc works just fine as it is but after a shutdown in becomes impossible to turn it on again or i have to press more than 10-14 times and randomly it starts and works
    my pc config is
    intel i5 7400
    gigabyte b250 hd3 motherboard
    8gb gskill ram 2400 bus
    gigabyte gtx 950
    cooler master b500 v2
    cooler masterlite 3
    every parts has warranty and i did my test on my graphics card , ram and motherboard everything just perfectly works fine and also searched in google and couldn't find any exact solution , right now i have to use my pc on hibernate just in case i don't have to face this issue again but i need a permanent solution instead of going to rma as it will at least take a week to get a result and i don't want to wait this much time for this weird problem , any help would be really appreciated
    • NahyaN's Gadgets
      • MSI Z490 TOMAHAWK/ LIAN LI LANCOOL II MESH
      • INTEL CORE-i7 10700/ EK-240 D-RGB AIO
      • CORSAIR VENGEANCE LPX (16GB X 2) 3200MHZ CL-16
      • SAMSUNG 970 EVO PLUS 250 GB/ SAMSUNG 860 EVO 1TB
      • MSI VENTUS 3X RTX 3070 OC
      • ASUS VG259Q 144HZ/ BENQ GW2480
      • AudioTechnica ATH-M40X
      • COOLERMASTER MASTERKEYS S CHERRY MX BLUE PBT
      • RAZER DEATHADDER V2
      • XBox 360 Controller
      • ANTEC HCG 650W
      • ReLive
      • RACE ONLINE
      • ~40 Mbps
      • ~40 Mbps
    NahyaN's Avatar
    Feb 2009
    Just to be clear, by PC power button you mean the button you press on the casing to turn on your computer? The issue could be that the switch is failing or not properly making contacts. What you could do is make contact with the two jumper pins on the motherboard labelled PWR (Consult your motherboard manual). Use something metallic to make momentary contact between those two pins (a screwdriver works) and see if the computer starts normally. If that is so, then just replace the switch from your casing with new jumper cables and a new push switch. You can find those in stadium market's electrical components section or https://www.techshopbd.com/.
    https://www.techshopbd.com/product-categories/switch
    https://www.techshopbd.com/product-categories/cable
      • RYZEN R7 2700
      • SAMSUNG 943SWX
      • KZ ZSN PRO
      • GENERIC DELL
      • A4TECH GENERIC
      • SPEED TECH ONLINE
      • 10mbps
      • 5mbps
    Quote Originally Posted by NahyaN View Post
    yah the button of casing power switch , if i have to go to stadium market i would rather go to service center anyway thanks for the help
    • Ahnaf_i7X's Gadgets
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
      • Leaving BG
    Ahnaf_i7X's Avatar
    Sep 2012
    Leaving BG
    Faulty power button.
    Loved by few,
    Hated by many
    But respected by all!!
      • RYZEN R7 2700
      • SAMSUNG 943SWX
      • KZ ZSN PRO
      • GENERIC DELL
      • A4TECH GENERIC
      • SPEED TECH ONLINE
      • 10mbps
      • 5mbps
    Quote Originally Posted by Ahnaf_i7X View Post
    yah replaced one today fixed the problem so far
Page generated in 0.12401 seconds with 13 queries.
