Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 46
Thread: Building a CPU for Animation and VFX
    Dec 2012
    Dhaka, Bangladesh, Bangladesh
    Default Building a CPU for Animation and VFX
    Hey, looking for a new system.Mainly for doing Motion graphics, 3d animation, Visual effects,Video Editing and No Gaming!!
    Approximate Purchase Date: within a week
    Budget Range: 60,000 TK
    System Usage from Most to Least Important:
    motion graphics (After Effects CS6), 3d animation (, Maya 13, Real Flow, Vray,) and digital painting (Photoshop CS6), Video Editing Premier pro CS6
    Parts needed: processor, motherboard, ram, casing , psu , Cooler (if needed)
    Parts Not Required: : GPU, keyboard, mouse, monitor, speakers, OS, Hardrive ,optical drive
    Current parts : Nvidea geforce 220GT, 1TB + 320 GB SATA HDD
    Preferred Website(s) for Parts : http://123.49.57.230/binarylogic/index.htm
    Monitor Resolution: don't need monitor, I have a 17 inch square monitor
    currently i am not planning to buy a quadro gpu. maybe two months later i gonna buy it. so let me know if my current Nvidea geforce 220GT is enough or i have to change it immediatly.
    Thanks
    Processor - Core i7 3770 (26000tk)
    Motherboard - Gigabyte GA-B75M-D3H (Rev 1.1) (6700tk)
    RAM - Corsair Vengeance 4GB x 4 1600Mhz CL9 (8500tk)
    Casing - Thermaltake Commander GS-II (3800tk)
    PSU - Thermaltake TR2 500W or Cooler Master GX-550W (6000-6500tk)
    CPU Cooler - Cooler Master Hyper 212 Evo (3000tk)
    Overall - 54-55000tk . save that extra money .
    Try 2 add some money & get a Crucial M4 128GB SSD @ 12500tk . I guess this is the best choice for u
    Dec 2012
    hey ,
    thanks for your reply!!
    OK! i Have some quesions!
    Motherboard : ASRock Z77 Pro3: LGA 1155, Intel Z77 Express
    Intel Core i5-3570K : 3.4 GHz Base Clock Rate, 3.8 GHz Turbo Boost, 6 MB Shared L3 Cache
    these two are my choices.
    can you plz tell me about
    ASRock Z77 Pro3 vs Gigabyte GA-B75M-D3H
    Core i7 3770 vs Intel Core i5-3570K.
    actually i hv found this config at >
    http://www.tomshardware.com/reviews/...ming,3440.html
    can u tell me something about overclocking?
    as far as i know the "K" series intel processors work well while overclocking.what i wanna know is do i need overclocking at all?
    and why should i go core Intel Core i5-3570K or intel core i7 3770k instead of Core i7 3770?
    • Ghz's Gadgets
      • MSI Z77A-G41 (Cooler Master Storm Enforcer)
      • Intel Core i5 2400 @ 3.10Ghz (Stock)
      • Corsair Vengeance 8GB (2x4GB) DDR3 - 1600
      • Samsung F3 1TB | WD 500GB USB 3.0
      • Asus GTX 660 2GB GDDR5
      • DELL LED E1912H (Dual Monitor Setup)
      • Creative Sound Blaster Audigy 7.1
      • Creative SBS A520 5.1 | a4tech HS100
      • Logitech (Call of Duty) - MW3 Edition
      • Razer DeathAdder Wired Optical With SteelSeries QCK Mass
      • Logic Gamepad
      • Corsair 750w
      • Asus DVD-RW | Sony Combo
      • 500GB WD USB 3.0 | 8GB Transcend
      • Powerpac (1200VA)
      • Windows 8 x64 & Windows 7 x64 (Dual Boot)
      • My World ! My Life (-_-)
    Mar 2013
    Quote Originally Posted by lazycow456 View Post
    hey ,
    "K" series is for Overclocking, so if you have plan for overclocking get 3570K+Asrock/Asus z77, but I guess you don't need that as you will be doing graphics work, so better you take 3770+Gigabyte B75, look at @Xperience , as you mentioned in the post you dont need PSU, add the money and get a 128GB SSD
    I5 3570k 22k
    asrock z77 ex6 17k
    16gb corsair 10k
    tt frio ock 6k
    corsair 500w 6.5k
    total: 61k
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Quote Originally Posted by blood stain child View Post
    I5 3570k 22k
    asrock z77 ex6 17k
    16gb corsair 10k
    tt frio ock 6k
    corsair 500w 6.5k
    total: 61k
    • CODhunter's Gadgets
      • EVGA z370 FTW
      • i7 8700k
      • 16GB G-Skill RGB 3000bus
      • 128GB Corsiar SSD+2TB SSHD+1TB WD
      • EVGA GTX 1070 FTW
      • Samsung 23.6' 4K
      • WV-Klong
      • Razor elite
      • EVGA Supernova 650wat
      • Windows 10 (pirated)
    CODhunter's Avatar
    Nov 2009
    Thanks
    1** nice initiative
    2**try to buy i7
    3**i dont think that gt220 is enough for rendering, try to search cellbazar, uif ur lucky then u'll get quadro at a cheap price
    Quote Originally Posted by Ghz View Post
    where did you see i included gpu,keyboard,mouse,s peaker.os,hdd and optical driver?
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    Oops ma bad, ami GPu ke Psu vebechi
    @lazycow456 , tomar processor i7 3770 choose korar main reason holo "Hyper Threading Technology" .
    i5 3570K te HT nai . check it - http://ark.intel.com/compare/65520,65719
    Gaming er jonno 3570K enough . karon gaming e HT almost useless . Animation / Multitasking / VFX er jonno HT ta important .
    overclock korte hole valo mobo lagbe . tokhon 3570k + ASrock Z77 Extreme 4 = 36000tk lagbe . plus valo cpu cooler o lagbe .
    Overclock korte hole shob kisu overclock korte parle valo . tahole RAM tao overclockable hote hobe . nahole overclock kore khub beshi lav nai .
    i7 3770 + B75 = 32700tk . Extra CPU cooler paiteso . ar taka jomai ekta SSD kino Crucial m4 128GB .
    Trust me , this is the best solution .
    When you overclock an i5 3570k processor that not only just overclock its single core also it overclocks its another 3 cores at the same time so overclocked i5 3570k clocked at 4.5ghrz can perform the same or better than non k i7 3770 even if it has no hyper threading.
    i know that . main factor is, for Animation / VFX HT is so important .
    performence same hole OC korar kono mane nai . MB tao valo nite hobe . plus oc korao jante hobe .
    Quote Originally Posted by Xperience View Post
    sandy and ivy te overclock kora dal vat if i can get a same performar processor at 22k then why the hell i will spend more 6k here? When in that price i can grab a good mobo which can support cf/sli, 2400bus rams and more sata and usb ports?
    Ar hyper threading kamon difference ane any performance link please?
    1. 6k pailen koi ? ektu bujhai bolben ?
    2. Jekhane user ekta Quadro GPU kinte chaitese apni shekhane Crossfire/SLI koraben ?
    3. 60k budget e 2400bus er ram nite chan ? :o
    4. Uporer post e dekhlam apnar suggested spec e 16gb ram . oita ki 2400mhz er RAM ?
    First post ta valovabe poren clear hoye jaben .
    btw , Animation / Video Editing er jonno kono SSD nai ?
    or budget to 60k . apni to 61k te chole gelen tao SSD chara :S
    Animation / Multitasking / VFX er jonno HT Technology ar SSD koto important , just google koren
    4. Uporer post e dekhlam apnar spec e 16gb ram . oita ki 2400mhz er RAM ?
    First post ta poren clear hoye jaben .
    Animation / Multitasking / VFX er jonno HT koto important , just google koren
    1.i5 3570k 22k and i7 3770 28k 28-22= 6 ar ai 6k mobo er jonne
    2.cf/sli akhon korbe na but future e je korbe na aitar ki nischoyota ase? And i am saying about the feature he will use it or not its his own decision
    3 and 4.2400bus ki oc kora jabe na corsair ram gula?
    Now google e search dia amar point gula clarify hoye amake hyper threading er animation and vfx e gurutto and upokarita o i5 3570k and i7 3770 non k te ki poriman tulonamulok bisleshon sohokare akta result dao
    can u read my post first ?
    1. i7 3770 = 26000TK
    2. bar bar boltesi jekhane user ekta high end Quadro nite chaitese oikhane ki karone CF/SLI koraben ?
    BTW , Overclockable Processor + High end Sli/Crossfire er jonno 500w er PSU ? ROFLMAO
    3. 1600Mhz CL9 er RAM 2400MHz korben ? ROFL
    apnar point gula clarify korar jonno google korar kono mane hoina . eta common sense .
    UPOKARITA janar jonno google korun
    Check this - http://www.tomshardware.com/forum/33...ake-difference
    google kore shamne ja paisi oitai disi .valovabe search dile aro onek kisu pawa jabe .
    amar aro kisu question ase apnar kase .
    Baire jaitesi . ektu break
    do you mean a user should have at least 500w+ psu for overclocking i5 3570k in z77 board? And its a common sense that when he will use or if anyone use a cf/sli setup then he will also change the psu i am talking about the feature not saying to buy cf/sli setup what so ever 2400bus was an explanation but reality corsair can easily overclockable to 1866 and my bad that i said 2400. .and i saw at idb that boxed i7 3770 ar selling at 28k and k version are selling at 30k. .now keep rofling and hyper threading never makes huge difference when i5 3570k is overclocked to 4.5ghrz and its very much possible to make it stable to 4.5ghrz
      • GIGABYTE B75M-D3H rev1.1
      • A4Tech KRS-86
      • Thermaltake azureus
      • Antec VP450P
      • Samsung DVD RW+Asus CD RW
      • Win 8.1 pro x64
    @nonymous™'s Avatar
    Unknown
    Thanks
    most of the apps you have mentioned are heavily CPU dependent where all the particle or fluid physics are calculated by the CPU. GPU will have to just display the raster on screen. among those Vray RT is the one & only engine where you may be effectively benefited from a quadro gpu. so try to get a processor as strong as possible. at least a 3770 or better(3930K if possible). getting a quadro will be good but not urgent for your purpose......
    Dec 2012
    wow!!
    this site is amazing!!
    eto olpo shomoye etogula reply!!
    1. uporer comment pore ami kichukhon google korlam Overclocking niye.
    ami jehetu overclocking korte parina tai apatoto overclocking korar kono chinta vabna nai.
    r puro bepar ta besh complex & tricky mone hoise amar kase (google korar pore).
    tobe future a kokhn o OC korar dorkar hobe kina tao bolte partesina.
    2. Hyper threading niyeo google korlam.besh koyek jaigai dekhlam (tomshardware.com) 3d animation/VFX er jnno ora hyper threading k gurutto dise.jodio puro beparta ekhn o amar kache porishkaar na purapuri (karon amar hardware bishoyok gyan temn valo na).
    emn ki aj k dupur porjonto o jantam na OC ki r HT ki!! ekhn halka patla dharona paisi. (thnx to banglagamer.com)
    3. ami jei cpu ta build korte chachchi eita diye motamoti 2/3 bochor chalanor ichcha.tai ektu shomoy niye confusion na rekhe kinte chachchi.
    r emn vabe build korte chachchi jate future a upgrade korte pari.kichu ques ase amar
    1. core i7 3770 or core i7 3770k? (overclocking korata oboshshoi guruttopurno na, "kintu pore jodi dorkar hoy" ei term tao fele dite partesina!!)'
    2. Ram ki 4*4 Nibo na 8*2 nibo?
    3. 3/4 month pore jodi 1ta entry level quadro card/GTX 650 Ti r 24" monitor jodi nite chai taile ki Gigabyte GA-B75M-D3H sheta support korbe ?
    bepok dhonnobaad reply er jonno!! Ami Ovivuto!!
    • Ghz's Gadgets
      • Logic Gamepad
      • Corsair 750w
      • Powerpac (1200VA)
    Mar 2013
    I smell, debate competition
  1. Rig building help.
    By Mohaan in forum Technical Support
    Last Post: October 3rd, 2012, 23:02
  2. HELP! Building a new pc.
    By Platinum in forum Help - PC Buying
    Last Post: April 4th, 2012, 09:05
  3. Best Animation Movie You have Seen
    By sadi_warhead in forum Movies & TV
    Last Post: January 20th, 2012, 04:20
  4. WD Building Flooded!
    By Riese in forum News
    Last Post: November 2nd, 2011, 15:42
  5. Animator VS Animation II
    By LynAs in forum Miscellaneous Topics
    Last Post: October 31st, 2010, 01:51
Page generated in 0.32222 seconds with 14 queries.
