Thread: Where to buy and build PC parts
    • ASH SOLVEM's Gadgets
      • ASUS B450 M PRIME
      • AMD RYZEN 2700
      • 16 GB
      • 1 TB WD BLUE, 256 GB WD M.2 GREEN SATA SSD, 500 GB TRANSCEND SSD
      • GIGABYTE AORUS RTX 2080 SUPER
      • 1080p ASUS sth,144Hz
      • What dis?
      • Razer Kraken V2 ( never buy this crap )
      • Razer Huntsman ( not elite 😥😥)
      • Steelseries Rival 600
      • PS4 peasant controller
      • 750W antec goooold
      • Good old days 😥😥😥
      • WINDOWS 10 WINDOWS UPDATE EDITION
      • Whatever you do, never buy the case I bought
      • Carnival
      • 1024x1.25
      • No idea
      • 144
    Feb 2018
    Post Where to buy and build PC parts
    Skipping all the introductions, I am supposed to buy a gaming PC this coming month and for the past few days, I have scrounged the internet to build the very best PC with the given budget. I finally have all the components jotted down ( except for the PSU ) but as i never built a PC, I need someone to build it for me. My friend suggested me to build my PC in Global Brands or Star tech. Are they any good?Secondly, a lot of the components are from different retailers, so would I face trouble if I build my PC in GB or ST as they have to then get a lot of my requested components from other re-sellers.
      • Samsung 970 EVO 1TB+ 830 (128GB)+2TB mech HDD
      • Evga 1080 TI Sc 11GB
      • TELUS optical
      • 75Mbps
      • 30mbps
    mention your min/max budget for recommendation that would adhere better to your needs. global and star tech both are pretty good. Alternatively you can use this site to have an idea as to how much your total PC will cost . https://pcpartpicker.com/
    if you need something that is not available in BD or looking for high end stuff at better price than local stores let me know.
      • ASUS B450 M PRIME
      • AMD RYZEN 2700
      • 16 GB
      • What dis?
      • Good old days 😥😥😥
      • Carnival
      • 1024x1.25
      • No idea
      • 144
    Feb 2018
    Do they also build PC? If so, which one has the better staff for such job. Cuz I'm buying an expensive PC, I do not want to get a misplaced hardware or a broken pin. Also, do they consider buying from other retailers cuz I found a computer case in Ryans Computer website?
      • TELUS optical
      • 75Mbps
      • 30mbps
    check out https://www.facebook.com/OSGS.BD/ they are basically a gaming branch of Global. pretty much all upper class computer stores in IDB like Global, Star tech , ucc carries high end parts and they know what they are doing and all the parts comes with warranty. All you have to do is go there with a big fat wallet/cc.
    • Iskander's Gadgets
      • MSI 760GM-P23 (FX)
      • AMD FX-6300 3.5GHz
      • 8(2x4GB) Corsair Value DDR3 1600MHz
      • WD Blue 1TB
      • Zotac GTX 1050 Mini
      • ViewSonic VX2270Smh-LED
      • Cooler Master G550M 80PLUS Bronze
      • 500GB Samisung External HDD
      • Prolink 650VA
      • Windows 10 Pro, Linux Mint (Dual Boot)
      • Asianet BD
      • 6Mbps
      • 6Mbps
    Iskander's Avatar
    Aug 2015
    BinaryLogic BD & OSGS BD are pretty good at helping you choose the right parts for gaming within your Budget
Page generated in 0.18658 seconds with 13 queries.
