My Samsung hard drive is not running correctly. automatically disconnecting after a few minutes. how to repair it?
You'll need a new drive, repair is not really feasible. If you need to get your data off of the drive you can use ddrescue, which is usually included with popular linux distros. If the data in your drive is very valuable or you have no idea about what I just said, then don't try anything yourself and use a Professional data recovery service. If you don't have enough money for that, then forget about the data and do regular backups for your new drive like vanguard told you to.
Edit: This post assumes there's no problem with the SATA data cable+connector and SATA/Molex power connector and the power supply.
