Pc hanging after 3/4 mnt later of starting. This problem is happening even after a fresh windows installation.
I also tried by cleaning all parts of CPU. but the problem is still happening.
What to do ?
What to do ?
Check hard drive for bad sectors.
I call dibs on bad sectors causing the problem.
Loved by few,
Hated by many
But respected by all!!
Most probably hdd issue or shortage of power from psu , check this 2 parts separately and you will find the solution
Thanks, Dear. Problem solved. Hdd issue..
