Thread: Help me to decide on components
    Question Help me to decide on components
    I am not a gamer, I need a pc just to browse and edit videos of my blog. My budget is 40k without monitor,mouse and keyboard. What will be the best build around this budget??? I may increase my budget +-10k if needed.
    • GiDDY_SOUL's Gadgets
      • GIGABYTE B350 GAMING 3
      • AMD Ryzen 1600
      • 8GB Corsair Dominator RAM X2
      • 320GB Samsung F1 X2 RAID + PNY 240GB SSD
      • HIS R9 290 BIOS undervolt tweaked
      • LG 21.5' IPSHD LCD
      • Realtek HD Audio 8CH (Built-in)
      • Creative Inspire 5.1, Cosonic 775
      • A4tech Glaser / GiGABYTE GM-M8000
      • Xbox360 Wireless
      • Cosair HX1050
      • Transcend Jetstore 250GB
      • Windows 10 Pro
      • The Best Cost efficient PC of the Time..
      • Doze
      • 700
      • 700
    GiDDY_SOUL's Avatar
    Ryzen 5 2400G or Ryzen 5 1600 with compatible components.
    Giddy can be traced back to the same Germanic root *gud– that has given us the word God
      • MSI MORTAR MAX B450
      • RYZEN R7 2700
      • 8X2 CORSAIR VENGEANCE 3200
      • 1 TB WDD BLUE , 128 GB RIPJAWS M.2 SSD
      • GALAX GTX 1660TI EX WHITE
      • SAMSUNG 943SWX
      • KZ ZSN PRO
      • GENERIC DELL
      • A4TECH GENERIC
      • COOLER MASTER B500
      • SPEED TECH ONLINE
      • 10mbps
      • 5mbps
    as you are not using the pc for gaming i guess you can take this build
    cpu : intel i5 8400 15.5k
    mobo : gigabyte b360mds3h 8.6k
    ram : gskill 8gb 3k bus 8.7k
    hdd : 1tb wdd blue 4k
    psu : any branded psu within 3k
    total : 39.8k
    optional
    get a samsung ssd probably evo 860 or something which will help you to boot fast and would work heavily on writing and reading your videos
      • ASUS P8Z77-V Pro
      • Core i5 3570 @4.0 GHz
      • G.Skill ARES 2400 MHz 8GBx2
      • SAMSUNG 850 PRO 256GB
      • AMD RX 570 4GB 1300/1750 1.03v
      • HP Compaq LA26306x 23"
      • Realtek ALC898
      • GAMDIAS Hephaestus P1
      • Cougar Minos X2
      • Skylark
      • 30 Mbps
      • 60 Mbps
    If you look to edit videos, specially using Adobe Premiere 2018, please buy an intel CPU.
    Contrary to popular belief, AMD is no longer king when it comes to video editing anymore. Adobe Premiere in it's recent update has enabled intel's integrated QuickSync support which gets the job done faster than any competing AMD CPUs with a dedicated GPU (CUDA).
    However, this is depending on the type of workload you're putting on your system. If you are going to render a video with effects that relies on the CPU instead of GPU, this will vary.
Page generated in 0.11097 seconds with 13 queries.
