I need a gigabit router so that i can share files/movies etc at high speeds between my PCs at my home using LAN.
I already have a cheap tplink wireless router (wan/lan speed 100 mbps). So a wired router (that doesnt have wifi) would be fine. I can just connect the old wireless router to the new wired router.
The router must have gigabit lan/wan ports and should have a true or at least very colse to gigibit speed and i dont care much about the wirless performance (if it is a wireless router).
Is there any budget/cheap gigabit router under 10K in BD?
I have these in mind: microtik-rb750gr3 (wired), tplink archer c7 (wireless, has 802.11ac)
thnx in advance.
I have visited these places:
https://www.smallnetbuilder.com/lanwan/lanwan-reviews/33140-microtik-rb750gr3-hex-router-reviewed?showall=&start=1
https://thewirecutter.com/reviews/best-wi-fi-router/#budget-pick-netgear-r6700
https://www.smallnetbuilder.com/wireless/wireless-reviews/32498-tp-link-archer-c7-v2-reviewed
https://www.digitalcitizen.life/review-tp-link-archer-c1200?page=1
https://www.startech.com.bd/Mikrotik-RB750Gr2-Router
https://www.smallnetbuilder.com/wireless/wireless-reviews/32211-d-link-dir-860l-wireless-ac1200-dual-band-gigabit-cloud-router-reviewed?showall=&start=1
