Results 1 to 11 of 11
Thread: Is there really a major difference between a 1333bus speed ram and a 1600bus speed ram??
    • rabbyx7's Gadgets
      • Gigabyte GA-B75M-D3H rev1.1
      • Intel Core i3 3220 3.3ghz
      • A-Data XPG 1600MHz DDR3 4x 2GB = 8GB
      • Western Digital 500GB 7200rpm 3gb/s; Western Digital Cavier Blue 1TB; Transcend 500GB USB 3.0
      • SAPPHIRE HD 7870 2GB GDDR5 DUAL-X OC GHZ EDITION
      • Sony Bravia 32inch FULL HD LED; Asus VX229h 21.5 FULL HD IPS
      • REALTEK HIGH DEFINITION
      • Thermeltek Esports Shock Spin Blazing Red
      • MERCURY 8X00
      • SKYTECH
      • Xbox One Wireless Controller
      • Cooler Master V550 550W 80+ Gold
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • Windows 7 64bit Ultimate
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    Default Is there really a major difference between a 1333bus speed ram and a 1600bus speed ram??
    I mean is it worth the trouble to spend the extra bucks to go for a 1600bus ram instead of a 1333bus speed ram? and not to mention getting a mobo which needs to support 1600bus......plz to discuss in detail.....
    what I mean is that I know there is difference(duh!), but Is the difference worth it? of course talking about a pc only used for gaming...
    There is a difference but a small one.
    All the details you need: http://www.anandtech.com/show/6372/m...gp-with-gskill
    1600mhz is worth it but not anything above it.
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    im upgrading my pc and while deciding which mobo to choose I noticed that there is a price difference of at least 1.5k-2k between a 1333 supported mobo and a 1600 supported mobo... not to mention the ram price also differs at least 1k....
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    @rabbyx7 can you mention the details of upgrade you intended to do?
    I mean if you are keeping the current processor or changing it?
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    im getting a i3 3rd gen 3220ghz.... confused about the mobo... there are mobos which support LGA1155 price varying fro 4.9k to 6.7k.. the only difference it seems is the ram bus it supports(1333/1600).. and usb (2.0/3.0) personally, I don't need a 3.0 usb port.... so yeah, the only think I need to consider is the memory bus, hence this post...
    Well if it isn't a problem, then go for it.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Quote Originally Posted by rabbyx7 View Post
    Get a B75 chipset and be happy.
    • QuadStorm's Gadgets
      • Gigabyte H81M-S2PV
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Go for the gigabyte b75m-d3h..
    • Ghz's Gadgets
      • MSI Z77A-G41 (Cooler Master Storm Enforcer)
      • Intel Core i5 2400 @ 3.10Ghz (Stock)
      • Corsair Vengeance 8GB (2x4GB) DDR3 - 1600
      • Samsung F3 1TB | WD 500GB USB 3.0
      • Asus GTX 660 2GB GDDR5
      • DELL LED E1912H (Dual Monitor Setup)
      • Creative Sound Blaster Audigy 7.1
      • Creative SBS A520 5.1 | a4tech HS100
      • Logitech (Call of Duty) - MW3 Edition
      • Razer DeathAdder Wired Optical With SteelSeries QCK Mass
      • Logic Gamepad
      • Corsair 750w
      • Asus DVD-RW | Sony Combo
      • 500GB WD USB 3.0 | 8GB Transcend
      • Powerpac (1200VA)
      • Windows 8 x64 & Windows 7 x64 (Dual Boot)
      • My World ! My Life (-_-)
    Mar 2013
    Get gigabyte b75m-d3h + 2x4GB (Twinmos 1600Mhz)
    • rabbyx7's Gadgets
      • MERCURY 8X00
      • SKYTECH
      • ASUS 18X DVD ROM
      • Banglalion WIMAX
      • APOLLO
      • 5.9
      • HAPPY :)
      • Banglalion WIMAX
      • 256
      • 24KBPS
    rabbyx7's Avatar
    Dec 2011
    Quote Originally Posted by Ghz View Post
    cant afford gigabyte d3h is it okay with gigabyte d3v?
  1. Need For Speed: The Run
    By SadIkMahdI in forum NFS - The Run
    Last Post: May 10th, 2014, 03:34
  2. Replies: 20
    Last Post: February 7th, 2012, 21:54
  3. Need For Speed: The Run
    By SadIkMahdI in forum Racing
    Last Post: November 21st, 2011, 20:20
  4. Replies: 9
    Last Post: July 2nd, 2010, 12:07
  5. The End Of NEED FOR SPEED
    By Speed in forum Older NFS Games
    Last Post: December 18th, 2008, 14:01
Page generated in 0.21971 seconds with 14 queries.
