Results 1 to 20 of 33
Thread: A little help with wifi/wimax
    • Alex Ovoy's Gadgets
      • Gigabyte HM 77
      • Intel core i5
      • 4gb
      • 1TB
      • Sapphire HD7850
      • LG 21.5"
      • Genius Imperator
      • Windows 8
      • 130kbps
    Alex Ovoy's Avatar
    Jan 2013
    Default A little help with wifi/wimax
    I m going to buy my first android next month .. and I have a 512kbps banglalion postpaid modem .. How will I use banglalion with my phone ? do i need a router or any other hardware?
    anyone ???
    • Frank3nst3in's Gadgets
      • MSI 760GM-P33
      • AMD Athlon II X4 640
      • Samsung 500GB F3, WD Blue 1TB, Seagate Barracuda 1TB, Hitachi 160GB
      • ECS EliteGroup GTX 550Ti
      • ASUS VX229H 21.5
      • Creative SB X-Fi Titanium
      • Panasonic HTF600, SoundMagic E10
      • CM Storm Devastator MS2K
      • CM Storm Devastator MB24
      • Windows 8.1
      • 64 KBps
    Frank3nst3in's Avatar
    You'll need a 4G/Wimax router to create a hotspot.
    Depending on your modem, with a USB/WAN interface.
      • Gigabyte HM 77
      • Intel core i5
      • 4gb
      • 1TB
      • Sapphire HD7850
      • LG 21.5"
      • Genius Imperator
      • Windows 8
      • 130kbps
    Alex Ovoy's Avatar
    Jan 2013
    so I must buy a router koto dam ?
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    Or you can buy a LAN card. Laptops have them integrated.
    Wimax routers will cost you at least ~2.5k.
    • TheNutKicker's Gadgets
      • Intergated
      • Intel Core 2 Duo T6500
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • Genuine Vista 64 Bit
      • 10
      • 138
    TheNutKicker's Avatar
    Quote Originally Posted by Alex Ovoy View Post
    anyone ???
    Use Connectify and Walla you are ready to go, reps pl0x
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    Quote Originally Posted by TheNutKicker View Post
    How do you do that if there isn't any lan/wan output?
      • Intergated
      • 4GB DDR2
      • 320 GB 5400 RPM
      • 1600x900
      • Keypad
      • 10
      • 138
    Quote Originally Posted by Frank3nst3in View Post
    Ooops forgot that he uses desktop in that case lan card or router needed.
    • nafis087's Gadgets
      • Gigabyte H81 S2PV
      • Intel Core i5 4460 3.2 GHz
      • 8 GB Adata DDR3 1600MHz X 2
      • Toshiba 2TB + Toshiba 2TB + Samsung 320GB + Transcend 320GB (portable)
      • MSI GTX 760 TFIV GE 2GB DDR5 OC
      • ASUS VX229H (1920x1080)
      • Microlab TMN-1 2:1, A4Tech HS-19 & A4Tech HS-30
      • A4 tech bloody b120
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • Transcend 16GB USB 3.0
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    use it via Laptop.
      • Gigabyte HM 77
      • Intel core i5
      • 4gb
      • 1TB
      • Sapphire HD7850
      • LG 21.5"
      • Genius Imperator
      • Windows 8
      • 130kbps
    Alex Ovoy's Avatar
    Jan 2013
    i dnt have laptop .. and another question I have normal blion usb postpaid modem .. do i have to change modem .. give me a lil idea about router.. price and brand @Frank3nst3in @nafis087 @TheNutKicker
      • Gigabyte H81 S2PV
      • Logitech F510
      • CM V650w
      • ASUS 24x DVD-RW
      • XpressBD
      • 5 mbps
      • 1 mbps
    nafis087's Avatar
    I also have the same modem as yours, but i use it with my laptop when i need to convert it to WIFI (through "Connectify Me" of course). But you need to buy a WIFI device to make that work in your PC which will cost you no more than 1.5K i think, because some days ago i was also looking for a way to use WIFI via my PC then Taher Bhai of StarTech told me about that device. But later i figured out that i can easily make my own Hotspot via my laptop so i did not bought it.
    You might consider contacting with either Azhar Bhai(Multiplan) or Taher Bhai(Eastern Plus) regarding this matter.
    You can also use Router but that will cost you MORE but in that case there is no need for you to use any 3rd party softwares like "connectify me" & the hotspot area would be a bit bigger. So thats the plus point of using a Router.
      • Gigabyte HM 77
      • Intel core i5
      • 4gb
      • 1TB
      • Sapphire HD7850
      • LG 21.5"
      • Genius Imperator
      • Windows 8
      • 130kbps
    Alex Ovoy's Avatar
    Jan 2013
    does this device have any name? @nafis087
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    Quote Originally Posted by nafis087 View Post
    use it via Laptop.
    OP doesn't have a laptop.
    Don't buy a WAN/Wifi card, get the router. You can use wifi without any third party soft and get access to many things.
    TL-MR3040
    TL-MR3220
    These are available at Ryans.
      • Gigabyte HM 77
      • Intel core i5
      • 4gb
      • 1TB
      • Sapphire HD7850
      • LG 21.5"
      • Genius Imperator
      • Windows 8
      • 130kbps
    Alex Ovoy's Avatar
    Jan 2013
    banglalink usb modem diye ei router gula use kora jabe? @Frank3nst3in
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    Banglalion or banglalink?
    Banglalion is 4G/Wimax, Banglalink is EDGE/2.5G.
    • QuadStorm's Gadgets
      • Gigabyte H81M-S2PV
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    TL-MR3040
    TL-MR3220
    price jana ase?
    netgear er nai? netgear valo naki tplink?
      • Gigabyte HM 77
      • Intel core i5
      • 4gb
      • 1TB
      • Sapphire HD7850
      • LG 21.5"
      • Genius Imperator
      • Windows 8
      • 130kbps
    Alex Ovoy's Avatar
    Jan 2013
    soory i meant banglalion .. a friend said blion has their own router n i need to use that to create hotspot..is that true? or can i use any router for that?
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    Quote Originally Posted by QuadStorm View Post
    price jana ase?
    Check Ryans' site.
    If you are using the USB modem, you can use a router.
    What your friend said is not right.
      • Gigabyte HM 77
      • Intel core i5
      • 4gb
      • 1TB
      • Sapphire HD7850
      • LG 21.5"
      • Genius Imperator
      • Windows 8
      • 130kbps
    Alex Ovoy's Avatar
    Jan 2013
    I found a router in the liflet of Ryans .. model : TP-Link TL-WR720N .. Price 1600 tk .. will this do? @Frank3nst3in
      • MSI 760GM-P33
      • ASUS VX229H 21.5
      • Windows 8.1
      • 64 KBps
    If you're using USB modem then no.
    720 has a WAN interface, not USB.
    Question How to connect mr-3040 with qubee /banglalion
    Ami mr-3040 router kinachi, amr kacha qubee usb modem asa, kintu connect korta partachina,
    qubee ar usb modem a to light e jolena, bt qubee rover modem / banglalion ar usb modem lagale jole kintu kono kaj hoy na.
    help me.
  1. Question about Qubee Wimax's WiFi PLZ HELp
    By Constant in forum WiMAX
    Last Post: June 28th, 2012, 00:53
  2. Sharing Wimax connection to a Wifi router
    By Kruger in forum Technical Support
    Last Post: April 23rd, 2012, 13:47
  3. Replies: 30
    Last Post: April 3rd, 2011, 20:21
  4. Help me to choose a best wimax
    By Banglavai in forum Internet
    Last Post: August 11th, 2010, 14:53
  5. Broadband vs WiMAX : What do you think?
    By AmareX in forum Internet
    Last Post: March 12th, 2010, 19:41
Page generated in 0.29370 seconds with 14 queries.
