Results 1 to 16 of 16
Thread: Need rechargable batteries for xbox wireless controller...;)
    • QuadStorm's Gadgets
      • Gigabyte H81M-S2PV
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Default Need rechargable batteries for xbox wireless controller...;)
    amar xbox 360 controller er jonno rechargable battery dorkar...ami 4ta btery nite chai...kon brand er battery nibo? i need an external charger for them also...budget about 4k.
    pls help me...bored with AA batteries..thnx
       0 Mobile
    • @bhi's Gadgets
      • Gigabyte Z87X-UD3H
      • Samsung 30nm 2x4GB
      • Gigabyte HD7950 3GB WF3
      • Samsung 20" LED BX-2035
      • Creative SoundBlaster Z
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Seasonic X-650 km3 80+ Gold
      • Luminous Solo 1200 VA
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    get sanyo eneloops 4 piece with charger should not cost more than 3k, you will get those in renowned camera shops. Take the 2000mah ones.
       0
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    @bhi...can you name some shops?...would be helpful
       0 Mobile
    I once used sony batteries with a walkman. They served me well. You can find them in sony showrooms.
       0
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Search over bashundhara city, many camera shops are there like Camera Zone, New camera world, Digital something...also you can get sony cyclenergy those are available in level 6 Sony Center.
    If you get eneloops get the 2000mah with 1500 cycle ones >>>http://www.amazon.com/eneloop-Pre-Ch...3364569&sr=1-3
       1
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    @bhi..I will also use them for my camera sometimes...will sanyo be enough?
       0 Mobile
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    Quote Originally Posted by QuadStorm View Post
    eneloops are mainly used by photographers for their dedicated flash since they provide faster recycle, so now you decide .
    If you want higher capacity than 2000maH then you have to look for sony, their highest is 2800mah afaik
       0
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Quote Originally Posted by @bhi View Post
    I have read some review over the net...and i think eneloop is excellent...i am going for them...also can you name a good charger? or how much i have to spend for a good charger?
       0 Mobile
    • @bhi's Gadgets
      • Microlab Solo 7C
      • Logitech K-120
      • Logitech mx518
      • Windows 8.1 x64
      • Link3 512kbps
      • ~60
      • ~55
    @bhi's Avatar
    On My Chair
    eneloops also come with charger, there are two types 4 piece batteries packaged with charger which should cost around 3k, and only 4 piece battery should cost around 1.8k.
    check the amazon link i provided earlier that one is packaged with charger.
       0
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    Ok then, i will search for it...will give feedback..so much thnx @@bhi
       0 Mobile
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    @@bhi ....i just went to us.sanyo.com...i saw that it is a PANASONIC USA page holding the eneloop battery infos....why is that? Is Sanyo a product of PANASONIC?
    i found it...at this page at the bottom...(sorry to disturb you...)
    http://panasonic.net/sanyo/corporate...history06.html
       0
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    @@bhi ....how are you? I am gonna come to dhaka tomorrow....could you pls give me some brand shops in Bashundhara City?..that would help me...i have searched all over CTG....but couldn't find one branded battery....so pls help me...thnx
       0
    • chosen1's Gadgets
      • foxcon H55
      • core i3 540 3.07
      • Transcend 4 GB DDR3 1600 BUS( 2*2 GB)
      • HITACHI 1 TB
      • NVIDIA GeForce GT 440(apatoto),
      • Acer s273hl 27 inch
      • Creative Inspire M4500
      • ORIGINAL Xbox 360 wireless+Razer Onza Xbox360 Tournament Eddition+ 2X ps3 dualshock controller
      • Samsung Truedirect DVD RW
      • 16 GB Transcend Pendrive
      • Windows 8
      • currently gaming in Xbox 360 , PS3, PS4,soon gonna update the pc though
      • Local
      • 146
    chosen1's Avatar
    I use Energizer..... valo charger dya recharge korle marattok chole
    http://www.energizer.com/batteries/r...r-plus-aa.aspx
    Basundhara city te must pawa jawar kotha
    http://www.energizer.com/batteries/rechargeable-batteries/Pages/power-plus-aa.aspx
       0
      • Core i5-4460
      • Toshiba 1TB
      • Asus VX229H
      • A4tech
      • ProLink Evotis
      • GameMax GM-650
      • Banglalion Modem
      • Windows 8.1 64bit
      • 120
    Mar 2012
    Chittagong
    @@bhi vaia, battery kinlam...3.4k...the camera world..level 6..b city..tobe exact amazon er model ta painai..tai khutkhut kortese..use korle bujha jabe..dekhe original e mone holo..apnar help er jonno onek thanks..
    @aayman got the needed good..you can close the thread..thnx
       0 Mobile
    Closed
       0
  1. Replies: 4
    Last Post: September 27th, 2012, 15:58
  2. Sale (Used) Xbox 360 Wireless Controller
    By Rakin7 in forum Shop - Gadgets
    Last Post: December 31st, 2011, 14:30
  3. Replies: 5
    Last Post: August 14th, 2011, 23:24
  4. xbox 360 wireless controller on pc??
    By mr_08 in forum XBOX
    Last Post: May 29th, 2010, 14:45
  5. Sale (Used) xbox 360 wireless controller
    Last Post: April 24th, 2010, 00:08
Page generated in 0.25199 seconds with 14 queries.
