i can't watch demos even though i have the maps...error dey that can't open file
plz help
playdemo dust2_3d_1 1
Playdemo: Time scale 1.000000
Playing demo from dust2_3d_1.dem.
dust2_3d_1.dem is not a demo file
eita error dei plz help![]()
plz help
Last edited by HeLL]deathknight; January 26th, 2009 at 09:44. Reason: Automerged Doublepost
hmm ok but i don't think airokom hobar kotha
ato valo valo exped player ache BG...surprised no reply from dem :S
from where did you download this demo?? the file might be corrupted or maybe it was recorded in an older version..
dled it from gotfrag.com o ya bolte vule gesi its for CS 1.6![]()
well then i'm afraid i cant help you... -_-
If it's CS, then you need to copy the whole extension, and for CS the cmd is different from CSS.
In CSS it's
playdemo <demoname>
In CS it's
viewdemo <demoname.dem>
See the difference?
thanks sensei vai![]()
but still it says its not a demo file :S
Do u have 1.6 and CSS both? Is it that u r trying to play it in SOURCE? Then it wont work.. i guess... and if it is 1.6, then, make sure u have the updated version with the Steam.
Wait... wait ..." dust2_3d_1.dem " weird name... give us the link of the demo... let us try it first..
U said u downloaded it from gotfrag right? I have almost every recent demos, and i did see such name at present..
Can u pls confirm the link? Maybe i can helP....![]()
Oi Toky, Steam lagbe naa, latest Non Steam with latest protocol is enough.
DeathKnight, bhalo kotha bolse Toky (Bruticus), 3D'r CS demo? =S. I bet it's OLD! Coz 3D plays only CSS, and now they broke up. =\\.
Heidai... ekhon to ora CSS khele.. no 3D in CS......
in tht case the demo shud be wayyyy old.....and wont run in re3cent versions of 1.6 i guess....
hey guys CS S ee akta try korlam still not working wait i will give you the link to the demo
] playdemo col-3d-russka
CDemoFile::Open: couldn't open file col-3d-russka.dem for reading.
http://www.gotfrag.com/css/xact/dl/d...53dd0059a7d086
i think theres something wrong with your link but i do believe i have the demo and it is this one ...
there is nothing wrong with the demo.. its just that you dont have the file copied in your .../cstrike folder ... :closedeyes::closedeyes:
thanks a lot Z vai and sensei other vais who bothered to help. vule main folder ee rakhsilam
akhon thread close kore den![]()
no need to close it if anyone ever has any problems regarding demos they can post in here ..![]()
i hav a question. suppoese i'd like 2 watch the 8th round again. now, is there any way 2 do that without restarting the demo? And after restarting, is there any way 2 "fast forward" 2 get 2 the 8th round?
Its CSS btw.
Its AIM. Not GG AIM, GG_AIM or GG.
There are 2 ways of watching a demo.
playdemo <demoname.cfg>
viewdemo <demoname.cfg>
If you choose playdemo, you can't use the forward and backward keys.
If you choose viewdemo, you can use the forward and backward keys. =)
So, in conclusion, play demos using, "VIEWDEMO <demoname>".
... no viewdemo in CSS.
In, CSS you just use, "PLAYDEMO <demoname>". And if you press, SHIFT + F2, the controller will come up.
