Results 1 to 15 of 15
Thread: CPU FAN Speed Controller!!!
      • Samsung 970 EVO 1TB+ 830 (128GB)+2TB mech HDD
      • Evga 1080 TI Sc 11GB
      • TELUS optical
      • 75Mbps
      • 30mbps
    Default CPU FAN Speed Controller!!!
    any 1 have any good software to control Stock intel CPU fan (4 pin) speed.
    mines never goes above 2500 although it can do 4500 RPM max....regardless of temp.
      • Gigabyte
      • Q6600
      • 3GB DDR II
      • 320GB
      • 8600GT :(
      • Cosonic
      • Logitech RumblePad
      • BDCom
      • 20KB/s
      • 3MB/s
    xk::v (G展mmjaw)'s Avatar
    Default Re: CPU FAN Speed Controller!!!
    It depends on the type of fan you have.
    Some of them alter their own speed according to the temperature, some of them have their speed adjusted by the motherboard.
    How many wires run into your fan? If it's three wires then there is no way to control its speed. If it's four wires then connecting the speed control wire to +5V should do the trick.
    http://banglagamer.com/forums/image.php?type=sigpic&userid=19&dateline=1231856079
      • TELUS optical
      • 75Mbps
      • 30mbps
    its a 4 wire fan.....
    blk
    yellow
    green
    blue
    i want to change the fan speed only when im gaming not ALL the time..................
    any 1 used speedfan...know how to configure??? or other alternative??? (disabled Q fan in bios still runs at 22oorpm
    Attached Images Attached Images
      • Gigabyte
      • Q6600
      • 3GB DDR II
      • 320GB
      • 8600GT :(
      • Cosonic
      • BDCom
      • 20KB/s
      • 3MB/s
    like i said the speed control wire if you connect to 5v it will do the trick
    and control soft are basically for reducing the rpms
    • Uchiha Obito's Gadgets
      • ASUS P7H55M
      • A4Tech X7
      • 1 x Samsung DVD-RW
      • Transcend 16GB JetFlash 700
      • Windows 7 x64 + Linux x64
      • Didn't see till now.
      • RIG OK and Console Awesome.
      • BTCL ADSL 512kbps, 1mbps
      • 60KB/s and 120KB/s
      • Secret
    Uchiha Obito's Avatar
    Sep 2008
    Mymensingh, Bangladesh.
    that;s no problem man
    mine is MAX 1800RPM fan and my CPU temp never goes over 46*c
    and my RPM shows only <900RPM
    • Mazhar's Gadgets
      • MSI MEG X570 Ace
      • AMD Ryzen 3950X
      • G.Skill TridentZ Neo 4x8GB DDR4 3600
      • WD SN750 2TB
      • AMD 5700XT
      • LG GL850-B
      • SMSL M200/SP200
      • DCA Aeon 2 Closed
      • Corsair K70 Rapidfire
      • G502 SE
      • Xbox One
      • Seasonic Prime Plus Titanium 650W
      • Windows 10 Pro
    Mazhar's Avatar
    Toronto
    ok minnitt, i know what ur looking for. basically speedfan is a good idea, but ur best bet is to simply get a fan speed controller...i have one which i can let u borrow, its in dhanmondi at a friends place. if ur interested, pm me back
    edit: http://www.frostytech.com/articlevie...articleID=1291
    its basically something like this, but an older version
    Well i use Speed Fan. Wel if the CPU fan is 4 pin then its PWM type and if its 3pin then its DC type. After installing Speed Fan go to configure -> advanced...then in the drop down menu click ur motherboard chip there u will find the PWM or DC type ..Then just just change the value to manually controlled and clik remember it. Now u can control ur speed...
    • Black Neon's Gadgets
      • Gigabyte GA-Z87X-UD3H
      • Intel 4570 3.2 GHz Core i5 4th Gen.
      • 16 GB Corsair Vengeance DDR3 [1600]
      • [W.D. Caviar Blue 2 T.B. X4] + [W.D. Caviar Blue 1 T.B. X1] + [Transcend StoreJet USB 3 1 TB X3]
      • Sapphire HD7870 GHZ EDITION OC VERSION 2G GDDR5
      • ASUS VX229H + ASUS VX229H [Dual Display]
      • Creative Inspire 6.1
      • Logitech G510 Gaming Keyboard and Logitech G13 Advanced Gameboard
      • Logitech G 500
      • Logitech Rumble PAD 2 &amp; Microsoft XBOX 360
      • Thermaltake Toughpower Grand 750W
      • ASUS 18X SATA DVD-RW and Samsung 22X USB Extarnal DVD-RW
      • Transcend StoreJet 35 ULTRA
      • Apollo 1200 V/A
      • Windows 7 Ultimate Edition X64
      • I hate Benchmark
      • IT's OK For Me....
      • Teletalk 3G
      • 128 KBPS
      • 64 KBPS
      • 138
    Black Neon's Avatar
    Pallabi, Dhaka
    u can build ur own fancontroller or buy a Tt Fan controller
      • Samsung KS8000 55&quot;
      • TELUS optical
      • 75Mbps
      • 30mbps
    Quote Originally Posted by Mazhar View Post
    thnxx broo...i really appreciate ur help.
    But 1st ill try to get the job done thru software like speed fan ...then ill look for external controller.
    who can help me to configure speedfan????
    MY cpu fan is typical intel stock 4 wire Heat Sink fan....
    @craNIUM
    bro can u post som screenshots how did u configure ur speedfan ????
    Lightbulb Re: CPU FAN Speed Controller!!!
    Ok first open speed fan [Pic 01]
    Then click the configure botton on ur right as follows then click on the temperature tab. [Pic 02]
    In the CPU u can change ur desired temp and click the show in try so tht u can see ur temp in ur taskbar.
    Then click the FAN tab here u will find ur CPU fan speed RPM beside it undser the chip u will find ur MB chip name [Pic 03]
    Then here on the SPEED tab u can determine ur fan speed minimum and maximum value. [Pic 04]
    Then under the ADVANCED tab u will find a drop down menu in CHIP, select ur MB chip tht u found in the Fan tab under CPU. Then do as follows:[Pic 05]
    If u find trouble just send a screen shot of the ADVANCED tab of ur MB....
    Hope this solves ur problem...
    [IMG]file:///C:/Documents%20and%20Settings/craNIUM/Desktop/01.JPG[/IMG]
ID:	654   Click image for larger version.
ID:	655   Click image for larger version.
ID:	656   Click image for larger version.
ID:	657   Click image for larger version.
      • TELUS optical
      • 75Mbps
      • 30mbps
    bro i did everything like u suggested.....nd able to spin the fan at max 3013 rpm .......i had to set CPU in speed tab.. both
    minimum/max at 100%
    i was wondering is it possible to run the fan at full 4500RPM whenever i wish regardless of temp???????????????
    wel...that doesn't happen with the stock CPU coolers...but for other coolers they operate at full speed....well dnt u have any exhaust fan with 3 or 4 pin connectors connected....tht will really decrease ur overall CPU temp...
    • [email protected]'s Gadgets
      • Gigabyte Z97x-UD3H-BK
      • G Skill 16 GB DDR3 2200MHz
      • Asus Geforce 970 4GB
      • Asus 21.5 inch IPS monitor
      • Logitech G500s
      • EVGA G2 750W 80 plus Gold
    Tom@L's Avatar
    San Francisco, USA
    y do u want to run the fan at full speed ????? is it really necessary ?????
    first of all, the noise will irritate u and 2ndly it is best to leave the cpu fan control to motherboard coz it knows best abt the temperatures ....... running fan at full speed will lower the life of ur stock coolers ......
    even if u overclock, the fan speed will auto adjust itself to run at higher rpm due to higer cpu temperatures ...... so u dont have to worry .....
    from ur system config, i can see dat u r using prescott ........ my suggestion ....... plz sell it ........ it is one of the worst processors Intel has ever made ....... too much heat produce hoy ....... and the heat also destroys surrounding electricial components ......
    • coldfire7's Gadgets
      • ASUSTeK P5QPL-AM
      • Zotac GTX960 AMP
      • Samsung SyncMaster S24A300B
      • Schiit Fulla 2
      • Apollo KS-1200F 2000VA
      • Windows NT 6.1
      • Dual Homed Jinternets (http://www.speedtest.net/result/7506335550.png)
      • 25m+100m
      • 25m+100m
    coldfire7's Avatar
    minimum/max at 100%
    Clock down ur cpu to it's stock speed, I think that's will solve ur cpu's high temp prob (if u r having any temp prob)........
    And by the way maybe ur using the old version of the stock cooler that have lower max rpm about ~3300rmp at max I guess... the cooler ur r talking about is the newer one (4500pm max)... both look a lot alike... I have both of those coolers....
    EDIT::
    Also try ur mbo's driver cd it might contain some soft for seeing ur mbo's hardware stats (fan speed, volts, etc..) nearly every mbo company supplies a soft like that with it's mbos....& if u find a soft like that it might let u control ur cpu & other fans to run at max speed manually.......
      • TELUS optical
      • 75Mbps
      • 30mbps
    well just figured out that unless u have a poor ventilated case ur stock cpu fan wont run at full 4500 rpm...i
    know my fan used to run at 4500 rpm when i had crappy intel board nd no case fan.
    now i have 1 5" 220v case fan 1 gpu blower 7500rpm nd another on rear 80mm, another on top 80mm nd
    then psu also has a 120mm on its bottom....lol dats a lot 4 me.
    asus Q fan tends to keep low noise dats da problem even after disabled in bios.
    as for temp issue ...im not having any cpu throttle...though doin 3.6 4m 3.0
    well its cool to hear the fan ramping up when u game nd cool down when idle....this used to happen with my
    intel board. nd dats the only thing intel mb is good at...lolz
Page generated in 0.21710 seconds with 14 queries.
