Results 1 to 16 of 16
Thread: (help)facing weird problem after buying lappy.
    • hasan_1223's Gadgets
      • intel DG41RQ__
      • intel core 2 quad Q8200
      • 2*2GB=4GB
      • samsung 500GB SATA
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Micro Kingdom 670S
      • Samsund DVD-RW
      • Appolo 800VA
      • windows XP SP2 / Backtrack 5r3
      • Uttara cable Network
      • 23
    hasan_1223's Avatar
    Oct 2012
    Default (help)facing weird problem after buying lappy.
    Last friday, bought a hp pavillion dv6-7002tu lappy from rishit. After buying faced 1st problem which is when i connect lappys charger to socket , i get current shock from the whole surface of lappy. I talked them about it. They said our house does have any arthing. They said to connect socket from neighbours. After checking this , i do not get any current shock but feels some very low electrick force. When i disconnet the charger from the socket i don't feel any force. And the 2nd problem is the dvd burner. When i insert any dvd , burner does not respond and after sometime windows explorer hangs. So i had to restart windows to do other work. O after explorer hangs , i ender the process of explorer then run it again. after that i don't find the burner on the removeable drive list.
    BG member, help me... what should i do? Should i tell them to replace dvd burner or lapptop. ....
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    hp laptop e kisu unlucky models ase .... seems like ur ta serokm ekta
    change it asap
    Better you change the laptop and claim r.m.a and you should have asked here before buying the laptop as hp brand has negative response in this whole forum anyway what happend is just happend , did you tested the hdd with hd tune pro software? And how is the temperature of that laptop?
    • Sybaris Caesar's Gadgets
      • Intel DH61WW B3 Rev.
      • Intel Core i5 2400 3.10 Ghz
      • Thermaltake Commander
      • Logitech G402
      • Original Xbox 360 Wireless
      • Cooler Master G550M
    Sybaris Caesar's Avatar
    Nowy Warsaw
    Quote Originally Posted by hasan_1223 View Post
    you could'a asked us you know.
    My probable next build: Qisan MagicForce 68 (Outemu switch) / Teamwolf Zhuque+ 87 TKL (Outemu) / Monoprice Select series full size (Outemu/Gateron) / Drevo Gramr 84 TKL (Outemu) • Logitech G102 Prodigy • Deepcool Dukase V3 / Thermaltake Versa U21 • Superlux HD 681 • Creative Sound Blaster E1 • LG 22MP68VQ • SteelSeries QcK • Generic executive chair • others TBA
    djrock please don't bother me. You are in my ignore list so I don't have to see literal poop.
      • intel DG41RQ__
      • 2*2GB=4GB
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Samsund DVD-RW
      • Appolo 800VA
      • 23
    hasan_1223's Avatar
    Oct 2012
    Quote Originally Posted by blood stain child View Post
    vai rishit ki amar laptop change kore dibe na dvd burner change kore dibe. And what is r.m.a ? Could u give a link of hd tune pro so that i can see the temperature.
    see health result http://downloads.guru3d.com/HD-Tune-Pro-download-2674.html and check temperature http://downloads.guru3d.com/HWMonitor-1.18-download-2543.html
    And moreover laptop to ar desktop na je chailei parts change korbe, if warrenty thake and used not more than 1week then laptop change kore dewa uchit, laptop change rishit dibe ki dibe na aita apnar problem er upor and oder nijeder policy er upor depend korbe
      • intel DG41RQ__
      • 2*2GB=4GB
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Samsund DVD-RW
      • Appolo 800VA
      • 23
    hasan_1223's Avatar
    Oct 2012
    bujechi. Tader kase phone dichilam. Tara bollo laptop ta oikhame niye jaite. . And ami bg te emon kono thread e pai na je laptop er review dai. Tai asara amar sis to hp brand sara to kisu e buje na.
    i hate rishit....
    about the burner they should replace it.
    but about the shock, try using rubber sandal/avoid direct contact to earth.
      • intel DG41RQ__
      • 2*2GB=4GB
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Samsund DVD-RW
      • Appolo 800VA
      • 23
    hasan_1223's Avatar
    Oct 2012
    thanks to all. Hm. Emon obostha hoisi ami dvd diya boot o korte parchi na. Joto tara tari somvob oder kache niye jete hobe.
      • intel DG41RQ__
      • 2*2GB=4GB
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Samsund DVD-RW
      • Appolo 800VA
      • 23
    hasan_1223's Avatar
    Oct 2012
    i just want to give a damn fu** to rishit . There customer service is like a hell and they don't know how to how to talk with customer . When i went to their customer care, they said they want to perform a recovery mode. I said i had some important files around 20GB. if they keep it on their hdd. They refused to do that. Then i said to write that in blank dvd. They also refused to do it. I was hopeless :'(
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    finally ki hoilo???what did they do???
      • intel DG41RQ__
      • 2*2GB=4GB
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Samsund DVD-RW
      • Appolo 800VA
      • 23
    hasan_1223's Avatar
    Oct 2012
    Quote Originally Posted by maheer.dhruba View Post
    ki ar hobe 5hr bosaiya rakhsilo. Ki sob aje baje excuse dite lagse bole pc te virus ase tai pura pc ta factory setting mara lagbe. Ami to boisha osthir hoye gelam. jokhon chilla chilli suru korlam. Tara dvd burner replace kore dise. Tara amake bole o nai je dvd burner replace korce. Ami oikhan theke ashar por bujte parlam je replace korse.
      • WD Blue 1TB
      • A4tech bloody v3
      • Logitech f310
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    Jun 2012
    now is ur laptop working properly???i mean ager jhamela ase r??
      • intel DG41RQ__
      • 2*2GB=4GB
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Samsund DVD-RW
      • Appolo 800VA
      • 23
    hasan_1223's Avatar
    Oct 2012
    bolte gele . CD/Dvd kaj kortese. But mathay khali tension kore kobe je aita kaj na kora suru kore? Ar data loss er jonno afsos lagtese. Kisu game ar movie download korcilam sob gese. Pray 20GB DATA chilo..
    Ar sony r dvd burner gula kemon? Agerta sonyr chilo?
    kisu usb external dvd-R ase idb te khujlei pawa jabe 2k to 4k er vitor, khub besi vejal hoile oi gula akta kine fellei hoy ar kisu hoile ora hudai akta format mare aita maximum dokan ei hoy, amar akbar ram increase korte cpu nia gasilam ak dokan e amar tao format disilo oita 6-7 year ager kotha obossho so age kisu koraite nia gale backup rakha ta better
      • intel DG41RQ__
      • 2*2GB=4GB
      • INTEL G41 EXPRESS
      • SAMSNG 1368*760
      • nai
      • Creative SBS A300
      • mercury
      • A4tech
      • Samsund DVD-RW
      • Appolo 800VA
      • 23
    hasan_1223's Avatar
    Oct 2012
    mone thakbe kotha gulo. Thanks.
  1. To those Who are Facing problem inCrysis 3!!PC ONLY!!
    By ATypicalAssasin in forum Technical Support
    Last Post: March 5th, 2013, 22:57
  2. Suddenly Facing A Weird Problem ... Help Appreciated
    By pre in forum Technical Support
    Last Post: March 7th, 2012, 07:26
  3. Suddenly Facing A Weird Problem ... Help Appreciated
    By pre in forum Others PC Hardware
    Last Post: March 6th, 2012, 18:54
  4. Smile: anyone facing browsing problem?
    By AmareX in forum Smile/BDCom
    Last Post: February 5th, 2010, 14:39
  5. Smile: anyone facing browsing problem?
    By AmareX in forum Internet
Page generated in 0.26006 seconds with 14 queries.
