Results 1 to 8 of 8
Thread: Please help me choose a 21.5'' monitor within 14k :)
    • Obscura's Gadgets
      • GIGABYTE B75M-D3H
      • INTEL i5 - 3470, 3.2 GHZ
      • 8 GB DDR3
      • Samsung 500 GB HDD
      • MSI Nvidia GTX 660 OC TF III
      • ASUS VS228-H 1920 x 1080 LED
      • Realtek HD Audio
      • Sennheiser HD 201 & Altec Lansing VS2621
      • A4 tech
      • Old badass A4 Tech
      • Hands
      • TT 530 W Smart
      • Windows 7 64 bit
      • Bdcom
    Obscura's Avatar
    Mar 2013
    Default Please help me choose a 21.5'' monitor within 14k :)
    Hello everyone
    a few days ago, my old phillips 15 inch monitor stopped working - it's good in one way because I updated my rig and now need a good 1920 x 1080 resolution monitor. After some research, bangladesh availability wise, two monitors caught my eye - one is Samsung S22B300B from Ryans and Viewsonic VX2250WM from UCC. Both of them seem like good monitors, but this Viewsonic has better reviews on the net from sites like newegg and seems to be the popular monitor.
    http://www.newegg.com/Product/Produc...45&Tpk=S22B300
    http://www.newegg.com/Product/Produc...2&Tpk=VX2250WM
    But i am also very confused. I read this forum, and seemed like viewsonic is not the usual preference, and not many people use this samsung monitor either. Can anyone help me choose between these two, or suggest me a good 21.5'' within 14k please?
    • radeef's Gadgets
      • Gigabyte H67MA-USB3-B3
      • Thermaltake Smart 650W
      • Asus DVD-RW
      • Luminous 1200VA Solo
      • Windows 7 Ultra 64-bit
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    Quote Originally Posted by Obscura View Post
    I think a better 21.5" monitor within your price range will be tough. The ViewSonic one seems better in your price range. But if you intend to buy a better one it will cost 18K-20K and I suggest you can have a look on the Latest Asus ML series IPS monitors.
    • Obscura's Gadgets
      • GIGABYTE B75M-D3H
      • 8 GB DDR3
      • Realtek HD Audio
      • A4 tech
      • Hands
      • TT 530 W Smart
      • Windows 7 64 bit
      • Bdcom
    Obscura's Avatar
    Mar 2013
    Quote Originally Posted by radeef View Post
    Thanks for the reply bro, I was also looking at the ML229H, but the price is kind of too high, and availability might be a problem. I might be able to increase my budget in a few weeks, but that is if neither one of these work out.
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    It's a good decision to wait.
    • giant's Gadgets
      • MSI H77MA-G43
      • Intel Core i5 3470 @ 3.6ghz
      • Realtek ALC892
      • Delux K9020
      • Thermaltake SE 630W
      • Asus DRW-24B3ST (24x)
    giant's Avatar
    Feb 2012
    Khulna, Bangladesh
    i would say this-http://www.computersourcebd.com/phil...3LHSU_900.html ...14.5k ba er kom e paben....
    • Obscura's Gadgets
      • GIGABYTE B75M-D3H
      • 8 GB DDR3
      • Realtek HD Audio
      • A4 tech
      • Hands
      • TT 530 W Smart
      • Windows 7 64 bit
      • Bdcom
    Obscura's Avatar
    Mar 2013
    hmm, i'm wondering is the 5k extra worth it? other than the looks of the monitor.
    • radeef's Gadgets
      • Asus DVD-RW
      • PC Mark 7 - 4558
      • Qubee 1Mbps
      • 100 - 125 Kbps
      • Depends :|
    radeef's Avatar
    I meant quality actually
  1. Need help to choose a SSD
    By Mr. Orange in forum Others PC Hardware
    Last Post: December 21st, 2012, 15:41
  2. Replies: 4
    Last Post: December 10th, 2012, 18:47
  3. What should I choose?
    By TaherTheRetard in forum Help - PC Buying
    Last Post: September 8th, 2011, 00:18
  4. Help to choose
    By S_F.darkzone in forum ISPros
    Last Post: May 1st, 2011, 21:08
  5. help me to choose
    By sm_atuno in forum XBOX
    Last Post: December 7th, 2009, 01:39
Page generated in 0.19906 seconds with 14 queries.
