Results 1 to 8 of 8
Thread: which tv card will be batter for 20" monitor(1600*900)
    • babu.'s Gadgets
      • Gigabyte H81 S2PV/ Gigabyte B75 D3V
      • Core i5 4590/ i5 3470
      • 8 GB Adata XPG 1600 @ CL9/ 8 GB Team
      • 3 TB WD Blue
      • Shaphire R9 270X VaporX
      • LG 22'' mp65HQ/ Dell 17''
      • Altec VS4621, Skullcandy INK,D airphone
      • Tharmaltake TR2 600w/ TT LP 430w
      • Transcend 2TB Portable HDD
      • Windows 10, 7(64 bit)
      • CPU - 7.6, Ram - 7.7, GPU 7.9, HDD - 5.9
    babu.'s Avatar
    Mar 2012
    Khulna
    Question which tv card will be better for 20" monitor(1600*900)
    Which tv card will be better for 20" monitor(1600*900)...........Gadmei TV3860E LCD TV Card or Perfect TV5813E..
    gedmi only support 1400*900 resu where my monitor has 1600*900 (can avermedia tvcard able to maintain aspect ratio on its own?).........any suggestions from personal experience of using any of this tvcard...which one will be better for 20" monitor?
    thanx in advance.
    Batter?
    Batter to ranna-r jinish!
    i am using Kworld TV card with my 22" monitor, working fine.
    • shoryuken-x's Gadgets
      • msi
      • 8gb ( to power black x)
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • Tt toughpower XT 675
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    shoryuken-x's Avatar
    Quote Originally Posted by BABU* View Post
    Which tv card will be batter for 20" monitor(1600*900)...........Gadmei TV3860E LCD TV Card or Perfect TV5813E..
    gedmi only support 1400*900 resu where my monitor has 1600*900 (can avermedia tvcard able to maintain aspect ratio on its own?).........any suggestions from personal experience of using any of this tvcard...which one will be batter for 20" monitor?
    thanx in advance.
    avermedia well reputed brand reliable ...... Gadmei , perfect not bad but u knw lower thn avrmedia in most cases
    abt resolution : all of them should work with resolution u throw in .. tv card er jonno resolution prob nai ... no screen tearing, flickering , aspect ratio issues
    if u can take avermedia , its good choice ... but any chinese brand like gadmei is also fine
    • Arka karlos's Gadgets
      • gigabyte b75m hd3
      • intel core i3 3220
      • twinmos 4gb piano black
      • western digital blue 1tb
      • sapphire 7870 dual x oc
      • dell s2240l
      • realtek onboard
      • Microlab M-590
      • habit HV-G83
      • corsair vs450 cp-9020096-uk
      • samsung s222
      • Ideal 800va
      • windows 7 ultimate 64bit
      • teletalk 3g
      • 100KBps
    Arka karlos's Avatar
    thanx in advance.
    well Gadmei is a very much reliable brand i am using one for more than 2 years and still going on nicely. a month back i bought a Gadmei 2850 model for my friend from star solution. it supports from 720p to 1920x1200 multi resolution. even it supports odd resolution like 1440x900 which is my friends monitor resolution perfectly. it has lots of usefully function. get it . Gadmei is good as avermedia just avermedia has longer warranty period. but from price point Gadmei is best. if you found this helpful you can give me a repu if you wish.
      • msi
      • 1/2 tb
      • Radeon HD 7950
      • 21.5 lcd
      • lagano hoy ni
      • Genius Gx Sw-1250
      • Delux t15s
      • venge gese
      • few here nd there
      • 600va
      • jana nei
      • silent htpc
      • antbd
      • 60+
      • Do
    time nai vai otoshob spelling correct korar moto ... age lekhi pore vabi.... anyway good humour as alaways u do.
    Thannnnnnnks....wish i could give u 10 rep for that ..seriously helpful post.
    :blush
    here is something to make u smile i guess http://banglagamer.com/showthread.ph...ad+unmoderated... hope u like it (well see i posted one )
    • terrygr8_007's Gadgets
      • ASrock z77 extreme4
      • Transcend 2x4GB 1600BUS
      • Seagate Barracuda st 2TB
      • Sapphire HD7850 OC edition
      • built-in
      • CM GX650
      • Windows 7 Ultimate 64bit
    Quote Originally Posted by REVx View Post
    Batter?
    batter mane pidano na? :S
    Quote Originally Posted by terrygr8_007 View Post
    One meaning is 'pitano'.
    Another meaning is:
    Did u eat beguni, peyaju, pakora? First a paste is made and then the begun is dipped in the paste and fried - the paste is called 'batter'.
  1. Suggest me a LCD Monitor 22"/24" from IDB
    By minitt in forum Help - PC Buying
    Last Post: October 28th, 2011, 15:38
  2. 3.5"/5.5" Drive Bay with USB2.0/3.0 ports & card reader
    By s.s.shuvo in forum Others PC Hardware
    Last Post: September 9th, 2011, 02:09
  3. LCD Monitor + TV Card
    Last Post: February 9th, 2011, 06:10
  4. Need help buying a "Monitor"
    By SP.Sn4k3y- in forum Help - PC Buying
    Last Post: January 13th, 2011, 23:21
  5. Want to Buy TV Card for LCD Monitor
    By KinG SRS in forum Shop - Gadgets
    Last Post: December 5th, 2010, 00:18
Page generated in 0.20024 seconds with 14 queries.
