Results 1 to 1 of 1
Thread: freezing problem
    Default freezing problem
    Today at afternoon i was playing king of fighter in my pc and just tried to full screen it by pressing altr enter and then my pc became freez but that was not the main problem, i tried to close it but it didnt response. Then i pushed my restart button in cpu but i pushed it too roughly that the button stucks inside and pc booted twice and then the main problem happend. My mouse cursore is working and i can use task manager but when i try to open my computer or want to enter at any folder it freezes. Then i ran safe mode and there everything was working fine again so i moved all inportant files from C drive to another file and re-setuped my os and then everything was working fine even i played some games too. But after installing all drivers and software when i restarted my pc then again same problem appeard , in task manager i can see the system idle uses 99% cpu and my os is windows xp. Never seen this kind of problem in my entire life. Now how can i fix it? And also i am sure that my pc has no viruses and i use eset nod which is servicing me well from the last two years
  1. Battlefield 3 Freezing,Then Stuttering/Loopback
    By TheNutKicker in forum Technical Support
    Last Post: November 19th, 2011, 18:22
  2. Replies: 0
    Last Post: June 26th, 2011, 05:05
  3. Fable III Freezing screen & Only Cursor.
    By Sumit Pramanik in forum RPG
    Last Post: June 11th, 2011, 02:41
  4. Annoying mouse issues - lagging, spinning, freezing
    By Xanadu in forum Technical Support
    Last Post: June 8th, 2011, 07:39
  5. FIFA 11 Tips A Simple solution of "freezing multiplay menu" in game ranger
    By $hr in forum FIFA 11
    Last Post: November 28th, 2010, 02:36
Page generated in 0.14246 seconds with 14 queries.
