Thread: How to get sound from a monitor
    • gamefreak's Gadgets
      • Gigabyte H55-S2V
      • Core i5-760 2.8GHz
      • Micron 2GB DDR3 x 2=4GB
      • Samsung 500GB 5400 RPM SATA
      • Gigabyte ATi Radeon HD 5750 1GB GDDR5
      • Samsung SyncMaster 793DF 17'' CRT
      • Creative Inspire 2:1
      • A4 Tech AntiRSI
      • A4 Tech
      • Xbox 360 Wired Controller For Windows
      • Gigabyte Superb 550P
      • Samsung DVD-RW
      • Rahimafrooz 800 VA
      • Win7 32-bit
      • bought it a month ago....going pretty well....thanks to BG....
      • 16-18
    Solar System
    Default How to get sound from a monitor
    my friend bought SAMSUNG S22B300 22" LED monitor to play ps3. But how does he get sound after connecting the ps3?
    he provided me the following link for better info:
    http://www.ebay.com/itm/New-SAMSUNG-...-/140696450175
      • Asus P5KPL-AM
      • Dual Core E5400
      • Built-In
      • AOC F22 22"
      • Realtek
      • Delux
      • BUSTED !
      • Transcend 16GB
      • DigitalX 650VA
      • Windows 8 Pro x64
      • IS PROS
      • Average: 24 Kbps
      • Average: 24 Kbps
    йЦммєя³¹'s Avatar
    Apr 2009
    It has HDMI!
    As far as I remember, u have to go to the settings and then choose Audio and select HDMI as your audio output
    Verified Retailer
    • MDK's Gadgets
      • MSI Z87-G43
      • Core i7 4770K
      • Team Xtreem 8GB x2 2400
      • Crucial M4 120GB, WD Cavia Green 2TB
      • Sapphire AMD Radeon 7970
      • ViewSonic VX2260WM
      • MS Xbox Wired Controller, MS Xbox Wireless Controller
      • Thermaltake Toughpower ST 750W
      • Lite-on DVD-RW, Pioneer BD-RW
      • Genuine Windows 8.1 Pro 64bit with Media Center
      • 158
    MDK's Avatar
    Quote Originally Posted by gamefreak View Post
    When you plug in the PS3 using the HDMI cable you should hear audio from the monitor's build in speakers. if not, they are muted in the settings and you'll have to change that. But, built-in speakers are of very low quality. So, I suggest you use the audio out port(usually situated at the back of the monitor near other connectors) of your monitor(if there is one in your mentioned monitor). If you have a 4:1 or 5:1 speaker there should be 2 audio connection cable with the speakers. Just connect one of them with the audio out port and other one with the PC. You'll get stereo sound on Console and PC and they will not overlap with each other, or just use a dedicated speaker specifically with the audio out port.
    Thanks for the info
  1. Sale (Used) Creative Sound Blaster X-Fi Titanium PCI Express Sound Card
    Last Post: December 30th, 2012, 17:27
  2. sound
    By [iTS]pishach in forum Complaints & Suggestions
    Last Post: April 7th, 2012, 17:34
  3. Sale (Used) Creative Sound Blaster AUDIGY Value 7:1 Sound Card
    By Reventon in forum Shop - Gadgets
    Last Post: February 10th, 2011, 17:22
Page generated in 0.16112 seconds with 14 queries.
