Results 1 to 6 of 6
Thread: AHCI Mode Installation Help
    • fahimspider's Gadgets
      • MSI P67A GD65(B3)
      • TWINMOS 8 GB 1600 BUS
      • Saphire ATI HD 7950 Dual-X
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt E-sports Knucker
      • Tt Theron mouse
      • Razer Nostromo
      • Asus DVD RW. HP DVD ROM
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    fahimspider's Avatar
    Default AHCI Mode Installation Help
    I want to install AHCI mode in my current windows 7 (without reinstalling it). I tried google. Cant get a clear conception. i want to know the steps in simple words.
    And if i want to reinstall windows - do i have to install the driver during win7 installation? kind of confused. I tried to install AHCI mode 1 year back and damaged one of my HDDs. So this time before i do anything stupid i need a clear conception. Thank You guys.
    change hdd mode to ahci in bios. Then Install windows normally. No additional task is required.
    here is an easy to use guide
    http://www.askvg.com/how-to-change-s...lling-windows/
    • SadmanBD's Gadgets
      • Asus VX229H 21.5" LED IPS
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • XFX 850W Core Edition
      • Luminous Solo 1000VA
      • Windows 8.1 Pro WMC
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
    Reinstall na koreo kora jai. Ami korsilam. But vule gesi. Google kore dekhen, ekta registry edit kora lage.
    Pore abar hdd ke removable devices er list e dekhabe Oitar jonne abar arekta registry edit kora lage.
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    www.askvg.com/how-to-change-sata-hard-disk-mode-from-ide-to-ahci-raid-in-bios-after-installing-windows/
    Thanks Bro. i will try this out.
    @SadmanBD the link above dose not mention about a 2nd time use of reg editor. Can you confirm it?
    can you guys how to revert this to IDE mode, if anything goes wrong?
    Thank you guys. My system is flying!!!
      • Newmen E370
      • A4Tech D-70FX
      • Genius F-1000
      • Primary Rig ;)
      • ReignICT
      • 416 kB/s
      • 416 kB/s
    SadmanBD's Avatar
    Jan 2011
      • MSI P67A GD65(B3)
      • HP 18.5 INCH LCD
      • Microlab 2.1
      • Tt Theron mouse
      • Razer Nostromo
      • Apollo 1200 VA
      • WINDOWS 7 64 BIT
      • 7.5 WEI
      • ROCKING
      • SmileBD
      • 300-600kbps
      • 250-450kbps
    Done- Reboot- Successful.
    I love this forum. muah......muah..............
  1. Replies: 7
    Last Post: January 21st, 2012, 00:12
  2. GTA 4 Installation
    By Overlord in forum Action-Adventure
    Last Post: June 24th, 2011, 18:22
  3. SATA in AHCI mode
    By |-<NOSALIS>-| in forum Technical Support
    Last Post: August 6th, 2010, 19:30
  4. Win 7 After-Installation Problem
    By thekoRngear in forum Technical Support
    Last Post: January 9th, 2010, 22:51
  5. Enhanced mode vs compatible mode
    Last Post: September 16th, 2009, 00:46
Page generated in 0.19154 seconds with 14 queries.
