Results 1 to 13 of 13
Thread: ViewsoniC VX2260 22 inch Full HD1080p monitor for sell
    • Ic3_STrik3R's Gadgets
      • Gigabyte B8-Gaming
      • Intel Core i5 6400 3.3Ghz 6MB L3
      • G.Skill Trident Z RGB 8GB 2400Bus
      • Intel 530 180GB SSD, 500GB WD Blue
      • Gigabyte GTX 750Ti 4GB Windforce edition
      • Toshiba PB20E 32" HD Ready TV
      • Realtek 32bit Audio
      • SONY MHC-v818 Hi-Fi/Gigaworks T20/Genius HF1800A/Genius HF-1250/Genius SP-960BT/TT Isurus Pro
      • Chinese OEM RGB Mechanical KB
      • GX-Gila / DX-ECO Wireless Rechargeable
      • XboX One Controller x4
      • Thermaltek LightPower 450W
      • Samsung Ext DVD RW
      • Transcend 16GB USB3 PD, Genius NB1020 Webcam
      • Digital X 800VA
      • Not Checked
      • Just building it for work
      • 16 MBPS
      • 15 MBPS
    Ic3_STrik3R's Avatar
    Default ViewsoniC VX2260 22 inch Full HD1080p monitor for sell
    PRODUCT SOLD..!!!
    Want to sell my monitor ViewsoniC VX2260 22 inch Full HD1080p with built in audio in out ports.
    3-4 months warranty left (No problem till now)
    Want to sell because going to get a lcd TV
    Asking Price: 12.5K (Fixed)
    Contact Info
    01719438255
    01730725083
    01850130850
    BTW The panel is totally new cause ucc replaced my panel because of a spot inside the LCD. so count it as new and dont worry for warranty cause i can avail it as long as i want
      • Digital X 800VA
      • Not Checked
      • 16 MBPS
      • 15 MBPS
    Price Reduced
      • Digital X 800VA
      • Not Checked
      • 16 MBPS
      • 15 MBPS
    *bump
    @Ic3_STrik3R I like the way u managed to cramp so many stuff in such a small space.
      • Digital X 800VA
      • Not Checked
      • 16 MBPS
      • 15 MBPS
    thanks bro... i think i should give you a more recent pic... now its a mess and my wife shouts on me all the time for it.
    in this pic my xbox is hidden under the keyboard rack
    • shuvo121's Gadgets
      • Asrock Z77 extreme 4
      • Intel core i5 3570k 3.4 GHz
      • 6 GB
      • 500 GB
      • Evga gtx 690
      • Samsung 21 inch Lcd
      • Microwlab 5:1
      • Tharmaltake smart power 750w
      • Windows 7
    shuvo121's Avatar
    9 hazar hole ame nibo...possible?
      • Digital X 800VA
      • Not Checked
      • 16 MBPS
      • 15 MBPS
    nope not possible last price is 12K
    • gsshaun's Gadgets
      • Gigabyte B75M-D3H
      • Core i5-3450
      • Twinmos 2X4 GB DDR3 1600
      • Sandisk Ultra 64GB SSD+Hitachi 500GB, 7200Rpm
      • MSI GTX 760 OC
      • Sony 42" KDL W654A+Viewsonic VX2260
      • AVR Sony STR DH-520 + Creative Xfi Xtreme gamer
      • Magnat Monitor Supreme 2*200+2*100+1*250 Passive Book-shelf Speaker + JVC HA RX-500
      • Perfect USB
      • Lexma
      • Value Top 500 watt
      • DVD Rom, ASUS
      • Trascend 320 GB HDD, External
      • Windows 7, 64 bit
      • 320 Kbps
    Don't mind but new 22" with 3 years warranty is ~13500 BDT.
    Verified Retailer
    • MDK's Gadgets
      • MSI Z87-G43
      • Core i7 4770K
      • Team Xtreem 8GB x2 2400
      • Crucial M4 120GB, WD Cavia Green 2TB
      • Sapphire AMD Radeon 7970
      • ViewSonic VX2260WM
      • MS Xbox Wired Controller, MS Xbox Wireless Controller
      • Thermaltake Toughpower ST 750W
      • Lite-on DVD-RW, Pioneer BD-RW
      • Genuine Windows 8.1 Pro 64bit with Media Center
      • 158
    MDK's Avatar
    Quote Originally Posted by gsshaun View Post
    hmm, I don't think those has HDMI. they are standard D-sub connection compatible monitors.
    • gsshaun's Gadgets
      • Gigabyte B75M-D3H
      • Core i5-3450
      • MSI GTX 760 OC
      • Perfect USB
      • Lexma
      • DVD Rom, ASUS
      • Windows 7, 64 bit
      • 320 Kbps
    Quote Originally Posted by MDK View Post
    Nope, they are 22" full HD with HDCP supported DVI. And there is no difference in video with DVI or HDMI, they both use same technology to provide video. HDMI = DVI+Digital Audio. Hence, everyone can not afford a Receiver to decode digital audio, so digital audio is useless.
    But, HDMI might be useful for those who wants to connect Xbox or PS directly to a monitor.
    Verified Retailer
    • MDK's Gadgets
      • MSI Z87-G43
      • Core i7 4770K
      • 158
    MDK's Avatar
    Ya, I use HDMI for consoles and Blu-Ray, one of my friend use HDMI for PC and consoles. So, a DVI only monitor is useless for people like us. Also HDCP encrypted Blu-Ray discs won't display anything when played through a DVI monitor.
    but if you are only playing games on PC and have no plan on watching Blu-Ray discs then then, it is up to your preference on which connector you want in your monitor.
    @seller, sorry for getting off topic.
    • gsshaun's Gadgets
      • Gigabyte B75M-D3H
      • Core i5-3450
      • MSI GTX 760 OC
      • Perfect USB
      • Lexma
      • DVD Rom, ASUS
      • Windows 7, 64 bit
      • 320 Kbps
    It's true for old DVI connectors. Today's DVI support HDCP. And now, all of the full hd display of the market has HDCP compliant DVI. HDCP is just an encryption and can be used with DVI, HDMI, DP, GVIF, UDI ports.
    http://en.wikipedia.org/wiki/High-ba...ent_Protection
    This is totally off topic for this thread and sorry for the inconvenience.
      • Digital X 800VA
      • Not Checked
      • 16 MBPS
      • 15 MBPS
    no problem
  1. Sale (Used) AOC 22" inch Full HD LCD monitor for sale
    Last Post: November 30th, 2012, 21:58
  2. Sale (Used) viewsonic vx2253 21.5' full HD monitor
    By abruzzi in forum Shop - Gadgets
    Last Post: October 8th, 2012, 00:56
  3. 40 inch full hd led tv ??
    By nhawk in forum Help - General Shopping
    Last Post: August 5th, 2012, 21:22
  4. Sale (Used) Viewsonic VA2226W 22 inch LCD Monitor
    By Master Chief in forum Shop - Gadgets
    Last Post: May 31st, 2012, 21:52
  5. Replies: 9
    Last Post: May 10th, 2010, 07:03
Page generated in 0.24385 seconds with 15 queries.
