Results 1 to 2 of 2
Thread: Speaker Problem
    Nov 2012
    Angry Speaker Problem
    I have some CJC speakers. They haven't been used for a long time but I've had them for a while now. Anyway whenever I plug them in I get a buzzing sound emanating from these speakers. This sound goes away If I unplug the speakers OR turn the volume down to a very low level. Please help me in regards to how I can fix this problem. I had it before with my ipod. In that case I used to turn the connecting cable at an angle and this would make the buzz go away. Any idea how I can fix this? If not, then where I could get it repaired from and what would be the price of getting it repaired?
    My speakers: http://www.computersourcebd.com/CJC/...r/380_123.html
    • maheer.dhruba's Gadgets
      • Gigabyte H81 S2PV rev 2.0
      • Core i5 4460 @3.2Ghz
      • Avexir (2x4)Gb 1333Mhz
      • WD Blue 1TB
      • ASUS VX229H 21.5 inch 1080p
      • Creative 5.1 channel
      • Thermaltake Knucker
      • A4tech bloody v3
      • Logitech f310
      • samsung DVD writer
      • Corsair 32GB usb 3.0
      • Windows 8.1 pro 64bit
      • I'm Loving it!!! :)
      • X-link 1Mbps
      • 128 KBps
      • 128 KBps
    maheer.dhruba's Avatar
    Jun 2012
    Narayanganj, Bangladesh
    usually bad contact with the port causes dis prob...
    but in ur case i think its the jack...dhakae jack thik kore kothae sheta to jani na...but porichito electric shop e try korte paro
  1. Speaker Subwoofer problem
    By Rorschach in forum Technical Support
    Last Post: February 24th, 2012, 02:56
  2. speaker problem
    By Salmaan in forum Technical Support
    Last Post: January 22nd, 2012, 13:16
  3. Speaker problem
    By TaherTheRetard in forum Technical Support
    Last Post: September 24th, 2011, 17:30
  4. Need suggestion about speaker
    By shahriar in forum Others PC Hardware
    Last Post: October 1st, 2010, 09:43
  5. Need a new 4.1 Speaker....help me please!!!
    By ArchQuad in forum Others PC Hardware
    Last Post: October 4th, 2009, 20:20
Page generated in 0.14763 seconds with 14 queries.
