Results 1 to 20 of 26
Thread: Is a 800VA UPS (Battery 1x: 8.2 Amp on +12v rail) enough for my rig?
    Question Is a 800VA UPS (Battery 1x: 8.2 Amp on +12v rail) enough for my rig?
    I just need 5 minutes of backup. My PSU is 380w and Monitor Consumes 25w.
    If PF of ur UPS is 0.6 then it willl give 480W. Seems ok!
    BTW where u found this 8.2Amp battery. Generally sealed lead acid battery rated at 7amp or 7.2 amp, 9amp or 12amp and more.
    8 amp batteries are actually 7.2 amp battery. 9 amp batteries have a different shape hence, can't be used as a direct replacement of 7.2 amp battery. Same goes for 12 amp batteries. @Asif_R
    Using half of the battery load capacity is considered ideal which helps the life span of sealed lead acid batter
    Quote Originally Posted by Asif_R View Post
    SO, will the 7.5Ah ones do the job for 800VA?
    Actually my question is, will a 800VA ups with 7.5Ah +12v battery would be able to handle the first load of load-shedding when the full PC will be running at its full power (i.e. Gaming)??
    if pf = 0.6(480W) & ur psu's efficiency is 65% then ur total system will consume around 538W.
    if pf = 0.8(640W) it should handle.
    • RMS's Gadgets
      • Gigabyte GA-X58A-UD3R
      • Core i7 950 @4.2 GHz Cooled by Corsair H60 Hydro Cooler
      • OCZ Gold (2+2+2) GB + Corsair Vengeance (4+4+4) GB
      • Samsung 1.5 TB + Toshiba (3 +3+ 2) TB + 4 x Seagate 2 TB + Transcend 1TB ext + Adata 1.5TB ext
      • ASUS GTX 950 STRIX OC 2 GB
      • Samsung B2230 + Viewsonic VX2270S
      • Creative X-Fi Titanium, Asus Xonar DG || Fiio E7 USB DAC and Portable Amp || X-Fi 5.1 Pro USB
      • 5x Bowers and Wilkins VM1, Klipsch RW10 || HEADPHONES: Beyer DT990, Shure SRH440, Sennheiser HD 439,
      • Newmen e370 Illuminated Gaming Keyboard, A4Tech G6 Wireless Desktop
      • Mad Catz Cyborg R.A.T. 7 || Logitech G500 || A4Tech Bloody V3, A4tech G6-70D Wireless, A4tech MOP70D
      • Genius Trio Racer F1 Wheel, Genius MaxFire Grandias 12V Wireless Gamepad, BlackCat xbox360 Gamepad
      • Antec VP550P V2 NC
      • Samsung DVDRW, Sony DVDROM
      • AUDIO PLAYERS: Ipod Nano, SanDisk Sansa Clip+ || FLASH DRIVES: Transcend 128 GB, 16 GB, 2x 32 GB
      • APC 800 VA for CPU and Appolo 800 VA for others
    RMS's Avatar
    Sep 2011
    You should get at least 5 minutes backup for that set up.
    I have connected 2 PCs (the PC in my gadget list with monitor except the sound systems PLUS a dual core CPU with a 2 piece logitech small speakers and a 6 port switch) with my Apollo 800 VA ups. If everything are ON, I still get 5 to 6 minutes to shutdown my rigs completely.
    My psu eficiency is 84-86%.
    Quote Originally Posted by RMS View Post
    Whats your battery amp?
    then nothing to worry. im using Power Gaurd's Shitty 1200VA. pf 0.6 only dual 7AMPhr battery. u can atleast get a Mercury smart 1200.
    • RMS's Gadgets
    RMS's Avatar
    Sep 2011
    Don't know actually.
    Let your Battery is 7.2 Amp/Hour and its 12V. So the battery has 7.2X12=86.4Watt/Hour power.
    Now, Let your Computer consume 300W. Then u can expect 86.4/300=0.288 Hour or 17.28 min backup.
    But practically, due to over specification of battery and some lose; u will not get 100% backup from ur battery. U can expect maximum 75%.
    Another thing due to use day by day, capacity of Battery will reduce and will get less backup!
    Generally most of the 800VA UPS are use one 12V, 7.2 Amp/Hour battery!
    75%? :O it should be much more lower. DC 12V > AC Signal > Transformer as step up to 220V! this procedure burns a lot of energy
    Its maximum 75%. For our chines made UPS/Battery its may be lower
    DC to AC inverting is a non-efficient process but AC to AC converting (Transforming) is a very efficient process
    Bought IDEAL 800VA UPS with single 7AH battery, price was 2,900/=.
    Actually i searched the entire IDB today and unfortunately i found this by opening up the UPS chassis instead of just looking at the label:
    Apollo 800VA----------7AH, 3.2k 1y warranty
    Spark 800VA-----------7AH, 3.1k 1y warranty
    Ideal 800VA------------7AH, 2.9k 2y warranty
    Mercury 800VA---------8.2AH, 3.2k 2y warranty (Dont know whether it is actually a 8.2AH battery or not!)
    RealPower 800VA-------7AH, 3.1k 1y warranty
    PowerGuard 800VA------7AH, 3.3k 1y warranty
    Prolink 800VA-----------N/A 1y warranty
    Rahimafrooz 800VA------N/A 2y warranty
    Luminous 800VA---------N/A 2y warranty
    Micro 800VA------------N/A 2y warranty
    So, i decided to go for the Ideal one. I dont know whether it was a good idea or not.
    Mercury=yes it has a 8.2Ah battery. & a pf of .8. ive used one 1200VA, it had two 8.2Ah battery.
    i would have bought the mercury.
    & asif where the hell the heat comes from??? lol
    Two reasons for what i didnt buy the Mercury one,
    *1. The available product Mercury Elite Pro 800 is a very old model. Currently there is an new refined model of Mercury Elite Pro 850 which is not available in this country.
    *2. The price of 8.2Ah battery should be higher than 7Ah battery. So, when the time would come to replace the battery on my own, my cost will be more which i dont like.
    *** Btw, how was the experience of your previous Mercury UPS?
    1. ooowww ive used the Smart 1200. actually my brother is still using it. ive used that for 3 years 2 months. bought from Global. they offered 3 years warranty that time.
    2. when replacing u can use 7AHr battery without any kind of problem. it was awesome. my cousin used to come to my house for playing computer games. he was way to young to turn of the pc during load shedding so after a few months battery grid broke down.
    now replaced the 8.2Ahr batteries with 7Ahr & my elder brother is using it. still performs better than my New power gaurd 1200VA (bought from rishit)
    na, bollam je 8.2Ah er price beshi na 7Ah theke?
    100/150 taka beshi...
    Mercury 800VA te back port koyta?
    Nobody seemed to answer his main question but since you already bought it, does your PC stay on if power goes out on heavy load?
    I remember my Socomec used to stay on with Furmark running (Q9550 + GTX460) and never restarted when gaming. But I'm not sure if the same can be said after a year or so of use. Whereas the Cyberpower 1350VA UPS I have here in the US restarts when on load...
    I'm guessing it has a lot to do with the response time of the UPS father than the VA? Not sure though, an explanation would be great.
  1. Single Rail Power Supply-- Why it is BETTER.....
    By VANGUARD in forum Others PC Hardware
    Last Post: September 9th, 2012, 15:01
  2. Sale (Used) Appolo 800VA UPS with 6months Battery warranty
    Last Post: May 21st, 2012, 14:52
  3. Sale (Used) Two 7.5A UPS Battery is up for sale (Sealed Lead Acid Battery)
    By minitt in forum Shop - Gadgets
    Last Post: April 21st, 2012, 23:00
  4. Dhaka metro rail route!
    By REVx in forum News
    Last Post: September 13th, 2011, 16:41
  5. Closed Dual Rail 400 watt Psu
    Last Post: January 25th, 2009, 20:40
Page generated in 0.33749 seconds with 14 queries.
