Results 1 to 2 of 2
Thread: Resolution Problem
    • S_F.darkzone's Gadgets
      • Gigabyte EG43m-S2H
      • Intel Core 2 Duo 2.66ghz
      • 4 gb twinmos 800 bus
      • 1 tera western digital x2,250gb samsung x1
      • 9600 GT Alpha Dog Edition
      • Dell 23'' full hd
      • Hyundai CjC-960
      • xbox-360 wired controller
      • Thermaltek 420w
      • I don't freaking own a optical drive
      • Windows 7 ultimate pirated edition,yes pirated
      • BCube
      • 120
      • 64
    S_F.darkzone's Avatar
    Nikunjo 2,Dhaka
    Default Resolution Problem
    My 23" dell is on sickbed(pray for it,will ya?).So,currently I am using a 17" crt.
    The thing is dota is launching with 1920*1080 and going out of range for this old crt,whereas other games have readjusted to 1024*768.
    Is there any command line fix or something?
    Live with life in your blood,Die with honor in your name.
    Try editing the resolution through DOTA's ini files if you can, or do a configuration reset my simply deleting it. I never played DOTA so I wouldn't know much about it.
  1. What's your screen resolution?
    By VANGUARD in forum Others PC Hardware
    Last Post: April 18th, 2012, 20:48
  2. Replies: 4
    Last Post: June 28th, 2011, 00:22
  3. Measuring resolution!
    By xeon in forum Others PC Hardware
    Last Post: January 12th, 2010, 23:48
  4. FIFA 09 Media resolution change
    By AurorA in forum Older FIFA Games
    Last Post: May 6th, 2009, 01:42
  5. How Does Resolution affects?
    By Mad Monk in forum Warcraft III
    Last Post: December 9th, 2008, 00:22
Page generated in 0.14740 seconds with 14 queries.
