Results 1 to 20 of 27
Thread: Please help to bye a graphics card and psu
    • ridowan007's Gadgets
      • MSI 880GMS-E35 (MS-7641) v2.0
      • AMD Phenom II X4 955 @ 3.20GHz (4 Cores)
      • 4 GB
      • 500GB SAMSUNG HD502IJ
      • ATI Radeon HD 4250 512MB (560/667MHz) IGP
      • BenQ V920P 1366x768
      • Realtek ALC887-VD
      • Ubuntu 12.04, Windows 7
    Jan 2013
    Default Please help to buy a graphics card and psu
    I am trying to update my PC's graphics card. I current have AMD 4250 IGP. I want to buy a graphics card. My budget is around 16K but I have default power supply with casing so I might also have to bye a power supply too. Can anybody please suggest me what to buy?
    Now a days I am not so much hard core gamer but still a big fan of Hitman and GTA series. One of the main reseon to buy the card is playing this 2's 5th versions. So I want a card which can support this two games. Obviously graphics quality will be much lower and that is not that matter(finished GTA 4 on amd 4250 IGP and Hitman 4 on nvidia 6200 but sill enjoyed them much) but the games have to run smoothly with low to mid low settings.
    I am also avoiding AMD. I am mainly linux user and use win7 only for gaming and win app developing. Fade up of AMD's driver support on Linux(Specially their abandon of support of pre 5k cards{seriusly? 8xx motherboards are still on sale}). So I am thinking of buying Nvidia this time.
    I searched the ucc and ryans's site and found this 4 cards.
    1. MSI N550GTX-Ti Tk. 12,500.00 http://www.ucc-bd.com/msi-n550gtx-ti...e-ii-1gd5.html
    2. MSI NVIDIA GTX 650 Tk. 14,000.00 http://www.ucc-bd.com/nvidia-gtx-650...vi-d-hdmi.html
    3. MSI N640GT-MD2GD3/OC Tk. 10,500.00 http://www.ucc-bd.com/n640gt-md2gd3-...dmi-d-sub.html
    4. Gigabyte N6500C 2GB DDR5 TK 13,000 http://ryanscomputers.com/index.php/...em_Details/883
    Which one should be better? Or anything else? Also please suggest a power supply(I know quite nothing about psu's brands). Both have to fit on 16k.
    Thanks in advance
    My PC's description
    Processor: AMD Phenom II X4 955 @ 3.20GHz (4 Cores)
    Motherboard: MSI 880GMS-E35 (MS-7641) v2.0
    Chipset: AMD RS880
    Memory: 3584MB
    Disk: 500GB SAMSUNG HD502IJ
    Graphics: ATI Radeon HD 4250 512MB (560/667MHz) IGP
    Monitor: BenQ V920P
    Screen Resolution: 1366x768
    • Franklin's Gadgets
      • Gigabyte z97P D3
      • NIA Wireless Headset
      • A4 tech
      • DS4 Wireless Controller
      • Cooler Master v750W
      • Asus DVD RW 24x
      • Transcend Jetflash v70 8 GB
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    GPU: http://banglagamer.com/showthread.ph...dated-14-11-12
    PSU:
    http://banglagamer.com/showthread.php?23263-PSU-Price-List-Updated-14-11-12
    Edit: Just read that you are avoiding AMD cards.
      • 4 GB
      • Realtek ALC887-VD
    Jan 2013
    Thanks for your reply. But as I mentioned I am trying to avoid AMD.
      • Gigabyte z97P D3
      • A4 tech
      • Asus DVD RW 24x
      • DOT
      • 512 kBps with a B
      • 512 kBps with a B
    Franklin's Avatar
    Jul 2011
    Universe
    Quote Originally Posted by ridowan007 View Post
    Edited.
    • Rawkill's Gadgets
      • Asrock Z77 Extreme 6
      • WD Blue 1TB x 2
      • Creative Sound Blaster ZX
      • Logitech F510 Rumblepad
      • Prolink 1000VA
      • Cooler Master HAF - X
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    Quote Originally Posted by Nikomia View Post
    PSU:
    O AMD card kinbe na agei bolse
    Amd 12.11 drivers are really great for linux and windows os so you can try this new 7xxx series has great driver support as well. But if you are really thinking to buy nvidia then there is not a good options here with this budget so try amd this time
    • Rawkill's Gadgets
      • WD Blue 1TB x 2
      • Prolink 1000VA
      • 550-600 KB/s
      • 200-2500 KB/s
    Rawkill's Avatar
    All of the cards are more or less the same but I would recommend the 550 ti and this power supply:
    http://www.ucc-bd.com/litepower-500w-atx-2-0.html
    Your cost: 12.5k + 4.6k = 17.1k
    Considering your budget its best you buy an AMD card. You will get a better deal for your money
    @ridowan007 contact me after 2 days.
    Gigabyte Gtx 560 9 month used 14k 1 month warranty left
    Quote Originally Posted by bangla-_-gamer View Post
    worst suggestion ever.
    what will the best price for this gpu bro?
    ~11k-11.5k
    ~11k-11.5k
    than i will sell it for 12k need money for gtx 660.
      • 4 GB
      • Realtek ALC887-VD
    Jan 2013
    Ok bro.
    Thanks for the offer but I was trying to bye something which has more warranty(like 6month or more). Have terrible luck with devices(had to claim warranty 10+ times, almost most of my buying).
    Ok bro.
    it has 3 months warranty left 9months used typing mistake
    Gtx 560 will be a very good offer but you also need to have at least 6k psu which means 12+6=18k
    @ridowan007 dont bye a graphics card, please buy a graphics card
    From ur list no2 GTX650 will good but for proper gaming i suggest u to buy a 660!
    @ridowan007 tell me first, do u plan to upgrade ur monitor in near future?
      • 4 GB
      • Realtek ALC887-VD
    Jan 2013
    No unless its broken. Brought it just 1.5 year ago.
  1. Replies: 2
    Last Post: August 31st, 2012, 19:06
  2. Sale (Used) Graphics card and PSU
    By Raj_11 in forum Shop - Gadgets
    Last Post: April 14th, 2012, 14:54
  3. Closed I want to buy a graphics card.
    By jigsaw in forum Shop - Gadgets
    Last Post: February 24th, 2010, 16:49
  4. I need a Graphics card and a PSU
    By jigsaw in forum Others PC Hardware
    Last Post: February 14th, 2010, 13:08
  5. Replies: 2
    Last Post: April 10th, 2008, 17:17
Page generated in 0.29808 seconds with 14 queries.
