Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 67
Thread: [Auction/Giveaway] Cables, connectors, sound cards, case fans, optical drives etc.
    • avas911's Gadgets
      • Gigabyte GA-EG41MF-US2H
      • Built In Realtek ALC883
      • A4Tech X7 XL-747H 3600 DPI
      • Delta GPS-500AB A 500W
      • Asus 16x IDE DVD R
      • Rahimafrooz 600VA Premium
      • Win7 Ultimate 64Bit
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Default [Auction/Giveaway] Cables, connectors, sound cards, case fans, optical drives etc.
    Aution finished
    This is part of my cleaning the room sell/auction/giveaway.
    All of these are stuff that I have collected over the years. Dont need them anymore and they are taking a lot of space. So selling/auctioning/giving them away. Might help someone else.
    None of them has warranty. And I have forgot where most of them I got from.
    If the item you get is faulty I will refund you within 7 days. If you get it for free, then you are out of luck.
    Winning Bids Updated on 08-Jan-2013 09:14 PM
    Auction Rules:
    1. I will not sell below minimum Bid.
    2. Post your bid clearly mentioning the number of the item.
    3. Have to be equal/over to the minimum or over the current highest bid.
    4. post your bid only in this thread. Do not PM or text me pls.
    5. If you are the only bidder of a 0.00tk minimum bid item you will get it for free.
    6. Minimum bid increment is 10tk. Not enforced strictly.
    7. Do not bid like the "best one of the three" or "any of the two". Bid on one or all.
    8. No conditional bidding. You bid or you dont.
    9. No withdrawl of bids.
    10. Saying again I dont know if these work or not. I will refund if you get a faulty item. Although if you get it for free, I will not take it back.
    11. Do not outbid yourself. Follow this thread. If no one has outbidded you there is no point increasing your own bid.
    1. Old Creative CT4810 Sound Card.
    Not sure if it works or not.
    Pretty sure will not work with Windows Vista/7 for driver support.
    Connectors:
    1x Audio Out
    1x Audio/Line in
    1x Mic in
    1x MIDI/Game port
    Winning bid: 10TK
    Bidder: @faith
ID:	26430Click image for larger version.
    2. Original Intel Pentium 4 mPGA478 Cooler
    3 pin connector
    Winning bid: 30TK
    Bidder: @Alif
    3. 90mm Case fan modded to be connected to a motherboard fan connector
    Winning bid: 10TK
    Bidder: @rrayhan77
    4. 90mm Case fan with Molex male and female headers
    Winning bid: 20TK
    Bidder: @faith
    5. Canon K30081 power adapter for printer
    Dont remember which printer this was for.
    output: 13.5v 1A
    Winning bid: 30TK
    Bidder: @Raj_11
    6. 90mm case fan with no connectors.
    Can be modded to get power from motherboard headers or Molex connectors
    Winning bid: 20TK
    Bidder: @faith
    7. 90mm case fan with molex headers
    Winning bid: 20TK
    Bidder: @faith
    8. Asus 50x IDE CD ROM drive
    Winning bid: 15TK
    Bidder: @Akash434
ID:	26438Click image for larger version.
    9. Scart to Composite Video and Mono Audio connector
    Minimum Bid: 0.00TK
ID:	26440Click image for larger version.
    10. Creative Sound Blaster Live 5.1 Sound Card
    Dont know if it will work with windows Visa or 7
    Connectors:
    1x Digital out
    1x Line in
    1x Audio out
    1x Back out
    1x Mic in
    1x MIDI/Game port
    Winning bid: 105TK
    Bidder: @samiulislam16
ID:	26442Click image for larger version.
    11. xfx 9800GT cooler
    Does not know if it is perfectly fuctional. Has 4 pin connector
    Winning bid: 130TK
    Bidder: @Alif
    12. 120mm Case fan
    Pulled from a psu. Have very short cable. Can be modded to connect to molex or motherboard headers
    Winning bid: 65TK
    13. Red normal SATA cable
    Still packed.
    Winning bid: 20TK
    Bidder: @faith
    14. Red normal SATA cable
    Still packed.
    Winning bid: 20TK
    Bidder: @Alif
    15. Northbridge cooler from a motherboard
    probably from a intel or gigabyte 945 motherboard
    Winning bid: 20TK
    Bidder: @faith
    16. iPhone 3G/3GS case
    Has got scratches. But its strong
    Winning bid: 20TK
    Bidder: @Akash434
    17. Asus DVDRW SATA
    Probably will not read all disks
    Winning bid: 50TK
    Bidder: @Raj_11
    18. Asus DVD Rom IDE
    Winning bid: 25TK
    Bidder: @Raj_11
    19. Asus DVD Rom IDE
    Winning bid: 25TK
    Bidder: @Raj_11
    20. Back to back power cable white
    Winning bid: 10TK
    Bidder: @faith
    21. Audio extension cable
    Has 2 stereo connected cables. has male connectros at both ends.
    Winning bid: 11TK
    Bidder: @mr_08
    22. Component/composite RCA video/audio cables
    Winning bid: 11TK
    Bidder: @mr_08
    23. Composite video/audio cable for graphics cards etc
    Winning bid: 11TK
    Bidder: @mr_08
    24. Composite video/audio cable for graphics cards etc
    Winning bid: 5TK
    Bidder: @mr_08
    25. Composite to composite rca video cable for graphics cards
    Winning bid: 5TK
    Bidder: @mr_08
    26. Male to Male stereo audio extension cable
    Winning bid: 5TK
    Bidder: @mr_08
    27. molex to 6Pin PCIe cnverter
    Winning bid: 20TK
    Bidder: @Alif
    28. xfx DVI to VGA adapter
    Winning bid: 20TK
    Bidder: @faith
    29. DVI to VGA adapter
    Winning bid: 30TK
    Bidder: @Alif
    30. AMD DVI to VGA adapter
    Winning bid: 30TK
    Bidder: @faith
    Also @dipanzan has some more SATA cables like item 13/14. He wants to give them away for free. PM him for this
    Once more into the fray
    Into the last good fight I’ll ever know
    Live and die on this day
    Live and Die on this day
    • samiulislam16's Gadgets
      • Core i7 860 2.93ghz
      • Sapphire HD7870 ghz dualX
      • Asus 22 inch LED MS228H
      • Realtech Hd 8 channel Audio
      • Creative 2.1
      • Newmen M560
      • Dilong usb controller
      • Samsung DVD writer
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    samiulislam16's Avatar
    I m gonna bid for : 1, 10, 12, 13 and (4 or 7)
    Guess what??? scan it??:
    Good enough GAMING RIG
    HApPy GAMing
    • Robin Rayhan's Gadgets
      • Gigabyte B85-D3H
      • Intel Core i5 4570
      • Avexir 8GB DDR3 1600MHz
      • 120 + 240 GB ADATA SSD
      • (N/A)
      • AOC 20 INCH LED 1600x900
      • WinnerIT 3.5Mbps
      • 200-500 KB/s International | 12Mbps Local
    Robin Rayhan's Avatar
    Dec 2011
    Dibs on audio cables (No. 21, 22 and 26) and the case fans. Fans I can bid for. Cables, give them away to me please. Thanks you.
    • MaDDy's Gadgets
      • AsRock Z77 Pro3
      • Intel i5 2500k
      • Team Elite DDR3 1333Mhz 8GB
      • Crucial M4 128gb SSD + Hitachi 500Gb Sata2
      • Evga GTX580
      • Asus MS228H 21.5" L.E.D
      • Microlab TMN-3 (2:1)
      • Mercury Multimedia Keyboard
      • Microsoft Intellimouse 3.0
      • N/A
      • Gigabyte SuperB 720w
      • Asus 24x DvD RW
      • Silicon Power 8GB + Corsair Voyager Slider 32GB USB3
      • Windows 8 Pro (x64)
      • Qubee 512 sky**
      • 64 Kbps
      • 15 Kbps
    MaDDy's Avatar
    Dec 2009
    BIDDING 10 taka for Number 12 and 10 taka for number 27!
    Nice bro! Different try!
    XFX 9800GT functions properly (i mean can i use it as a GC) or u just want to sell its cooler? @avas911
    20TK for Number 27!
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Quote Originally Posted by Alif View Post
    20TK for Number 27!
    only the cooler. the card is totally dead. If I am not wrong I might have used some of its MOSFETs to fix other cards
    Ok! 50TK for cooler!
    • gsshaun's Gadgets
      • Gigabyte B75M-D3H
      • Core i5-3450
      • Twinmos 2X4 GB DDR3 1600
      • Sandisk Ultra 64GB SSD+Hitachi 500GB, 7200Rpm
      • MSI GTX 760 OC
      • Sony 42" KDL W654A+Viewsonic VX2260
      • AVR Sony STR DH-520 + Creative Xfi Xtreme gamer
      • Magnat Monitor Supreme 2*200+2*100+1*250 Passive Book-shelf Speaker + JVC HA RX-500
      • Perfect USB
      • Lexma
      • Value Top 500 watt
      • DVD Rom, ASUS
      • Trascend 320 GB HDD, External
      • Windows 7, 64 bit
      • 320 Kbps
    11, The cooler. Tk. 80
      • Gigabyte B85-D3H
      • (N/A)
      • WinnerIT 3.5Mbps
    Dec 2011
    No 3, 4, 6, 7, 12: 10 taka for each.
    Bid 30tk for item no5. And 10tk for 15.
    I bid Tk 10 taka each for items 14,13.
    And 20 tk for items 16 and(17 or 18 or 19 whichever drive works best)
    I salute you, this auction thing is a good idea.
    Add the remaining left over stuff I've at your place too Salman Vai.
    I've the exact same SATA cables lying around and they are brand new. These are the cables from my Abit IX38 QuadGT, which were left since there were so many of them that came with the board.
    If Salman bhai doesn't mind, I can give it to him and he can give it away[free of charge]. Don't really like opening another thread for such a small thing.
    • avas911's Gadgets
      • Slow in gaming
      • Link3 512
    avas911's Avatar
    Quote Originally Posted by rrayhan77 View Post
    pls bid on the number. "and the case fans" does not count as bids.
    Quote Originally Posted by Akash434 View Post
    you can not select like this. as I do not know whichever works best.
    considering bid for all three
    Bidder and current bids updated.
    Pls let me know via PM if you notice any mistakes.
    bid on number 10, 10 taka
    wait,what area do you live in?
    And please cancel my bid on items 18 and 19, I skimmed over the text and did not notice they were IDE.
    Very much thank you.
    bid close hobe kobe? cant wait!! khub moja pitase
      • Creative 2.1
      • Newmen M560
      • Sigma 640va
      • Good enough
      • Smile/BDcom
      • 150
      • 200
    20tk for no. 12 and 1st bid for no. 20 @avas911 via
    @rrayhan77 tomar ki shob fan dorkar!!! amake no. 4 or 7 er modhe 1ta dao karon just 1tai lagbe amar taile onnogula tumi emntei paba @rrayhan77
    HApPy GAMing
    • MaDDy's Gadgets
      • AsRock Z77 Pro3
      • Intel i5 2500k
      • Evga GTX580
      • N/A
      • Asus 24x DvD RW
      • Qubee 512 sky**
      • 64 Kbps
      • 15 Kbps
    MaDDy's Avatar
    Dec 2009
    !!!!30 taka for number 12!!!!
    • Devil May Cry's Gadgets
      • |Asrock| z68 Extreme4 Gen3
      • |Intel| Core i3 2100 @ 3.10GHz
      • 8GB |Corsair Vengeance| LP @ 1600Mhz Dual Channel
      • |WD Caviar Black| 1TB (64mb Cache)
      • |Sapphire| HD Radeon 6850 1GB GDRR5
      • |DELL| E1912H
      • |Sony| 5:1 Surround Home Theater
      • |a4tech| GK-85 (Wireless)
      • |a4tech| G3-220N (Wireless)
      • |xBox 360| Original (Wired)
      • 650w |Antec TruePower| TP-650 - 80+ Modular
      • |Asus| DVD-RW
      • |WD 500GB| (Usb 3.0)
      • |RED FOX| - C650B
      • Windows 7 x64
      • Packed on |Antec 1200| USB 3.0 - Full Tower Gaming Case
      • |Robi Sky|
      • 24/KB-30/KB Constant
    Nov 2012
    14) 15 tk
    28) 10 tk - DVI to VGA.. work kore toh ?
  1. about case fans
    By codename5302 in forum Help - General Shopping
    Last Post: April 28th, 2012, 07:13
  2. Intel's new Thunderbolt Optical Cables
    By Trave160 in forum Tech News
    Last Post: March 15th, 2012, 15:18
  3. Replies: 0
    Last Post: November 4th, 2011, 16:05
  4. Loud Case Fans any solution?
    By Rakin the Devil in forum Technical Support
    Last Post: March 19th, 2011, 03:00
  5. Searching Case Fans
    By craNIUM in forum Others PC Hardware
    Last Post: July 3rd, 2009, 11:02
Page generated in 0.36608 seconds with 15 queries.
